Old 07-12-2019, 10:15 PM #1
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Yet ANOTHER Cargo Lighting Mod
I installed my version of cargo dome lighting in the back headliner of my 18 ORP. I got inspiration from these threads that document the process through text and photos as how to run cabling from the hatch door into the headliner.
@DATX 15' Limited Cargo Light Mod - Toyota 4Runner Forum - Largest 4Runner Forum
@Snooperstyle Cargo area LED light mod!
@gmoney35c Cargo Dome Light Install - Toyota 4Runner Forum - Largest 4Runner Forum
And of course @Antman
I wanted the light overhead in the headliner, not surface mounted on a side panel. And I wanted a switch to provide the typical ON-DOOR-OFF function of the other interior lights. I did not want to cut a big hole in the headliner to install a Toyota OEM dome light module, so I used a flush mount Oznium bolt LED 3W. It only needs an 11 mm hole poked into the headliner with an exacto blade. This thing is very bright but it gets rather hot to the touch if it’s powered on for a while, so I mounted it with a stainless washer and to an aluminum plate above the headliner to act as a heat sink.
LED Bolt Flush Mount Lights | Bright + 12 Volt | Oznium LEDs
There’s about 1-2 inches of room above the headliner in the angled area near the rear window to do the install. It was a long reach and I didn’t want to crinkle the headliner fabric with my arm in there, so I used a long flexible grabber tool to position the backing nuts on the LED threads and a wooden dowel rod to spin them on and snug them up to the aluminum plate. Kind of like robotic surgery.
It’s not a difficult mod but it took me a few days to accomplish it, being very careful and deliberate, since I’ve never dug into this area of the truck before. Fishing the cable wires through the hatch door, through the rubber boots, into the headliner and down into the rear brake light access panel took a good amount of time.
I made three solder connections to the driver side hatch door light wires instead of wire taps like others have used. I hate wire taps. Especially in the hatch door which takes a lot of impact when being slammed shut. The LED/switch circuitry is connected in parallel with the hatch door switch/light. All wires and cables are sleeved and tie wrapped/taped for abrasion protection and to look OEM.
Cable sleeve TechFlex https://www.amazon.com/TechFlex-F6N0...y&sr=8-1-fkmr2
Tesa Tape 51036 https://www.amazon.com/Tesas-Advance...gateway&sr=8-3
The switch (ON-OFF-DOOR) is mounted in the driver side brake light access cover and wired through a pin/socket connector for ease of removal.
The switch is a small ESwitch SPDT (ON-OFF-ON) RB145E1100 from DigiKey https://www.digikey.com/product-deta...748-ND/2116227
The switch and LED work well. It lights up when the hatch door opens and fades out when closed. It also provides on/off control of the headliner light for nighttime illumination when sleeping in the back.
The previous thread postings and the photos below tell the story.
Yet ANOTHER Cargo Lighting Mod-9f1e75ae-6374-4601-b6ec-71eea52221f9-jpeg  Yet ANOTHER Cargo Lighting Mod-348ba2b6-2fb8-4cea-a6c6-4ba9820be9a5-jpeg  Yet ANOTHER Cargo Lighting Mod-8c3b342e-69bc-4ef6-ae78-594107e6fd97-jpeg  Yet ANOTHER Cargo Lighting Mod-694f3aa8-ed6a-4a3a-8036-f7f12a0c4101-jpeg  Yet ANOTHER Cargo Lighting Mod-d7ec2d92-eb1e-4847-9595-9bf2b356db71-jpeg  Yet ANOTHER Cargo Lighting Mod-1a972c6f-e595-4197-82b4-c66e95b40732-jpeg  Yet ANOTHER Cargo Lighting Mod-2f1e4871-3c0e-42b0-af22-6fa7fd6449ec-jpeg  Yet ANOTHER Cargo Lighting Mod-2cb142ec-4185-4571-8ebd-52cacb9d5d7a-jpeg
Old 07-12-2019, 10:20 PM #2
Banned
Real Name: Mark
Banned
Real Name: Mark
More Photos
Here are more photos.
The last pic shows the cargo area lit by the overhead LED only, not the hatch lights.
Yet ANOTHER Cargo Lighting Mod-a99fe611-8443-4f85-91e4-09556a4725cb-jpg  Yet ANOTHER Cargo Lighting Mod-3765ce4b-e118-4931-b0fe-6c4c3914f1b5-jpeg  Yet ANOTHER Cargo Lighting Mod-c5434fc8-69ac-4f07-9348-11324da26377-jpeg
Old 07-12-2019, 10:56 PM #3
Bugser's Avatar
Bugser Bugser is offline
Real Name: Bob
Bugser will become famous soon enough
Bugser's Avatar
Real Name: Bob
Great mod...now on my to do list!
2018 TRD ORP, MGM, Xpel 35% Tint, Xpel Clear Bra, In-Dash 2m/70cm Icom Radio, Dual-band 1/4 wave antenna with Rago Mount, sPod Bantam, 2 x 32" behind the grille LED lightbars, Cali Raised 3-way Fog Lights.
Sold: 2011 SR5
Bugser is offline   Reply With QuoteReply With Quote
Old 07-12-2019, 11:24 PM #4
mbumpus11's Avatar
mbumpus11 mbumpus11 is offline
Real Name: Bump
mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about
mbumpus11's Avatar
Real Name: Bump
Dang - no love for my install?
Cargo LED Lighting Actually Done Right - Toyota 4Runner Forum - Largest 4Runner Forum
I do like your solo dome light with the higher power light if I was going to go the route with one light. Looks cleaner than some of the other options out there.
Lots of people have thought mine are stock cargo lights!
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
mbumpus11 is offline   Reply With QuoteReply With Quote
Old 07-13-2019, 01:26 AM #5
Banned
Real Name: Mark
Banned
Real Name: Mark
Hey, yours is a great looking mod! Up high and it provides a lot of illumination. Clear directions. I just never found it in my search.
Thanks go out to all the innovative modifiers on this forum.
Old 07-13-2019, 09:00 PM #6
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
That's one bulb? Nice!
Ezlife45 is offline   Reply With QuoteReply With Quote
door , hatch , headliner , light , switch
Cargo LED Lighting Actually Done Right mbumpus11 5th gen T4Rs 22 03-18-2020 02:33 PM
Cargo cover and lighting dipNrip 5th gen T4Rs 1 09-30-2018 12:39 PM
Rear cargo lighting option jham 3rd gen T4Rs 5 04-30-2017 08:09 PM
Footwell Accent Lighting/ Ambient Lighting cleger 4th Gen T4Rs 4 02-27-2013 10:02 PM
