Old 07-13-2019, 03:46 AM #1
hb216 hb216 is offline
hb216 is on a distinguished road
Switch-Pro 9100 power module mounting location
All, I could use some help. I searched and searched but couldn't find a thread that discussed the below issue.
I purchased a Switch-Pro 9100 and am about to get it installed in my 2017 4Runner. My installer, a highly reputed shop owner at the overseas location I'm at, suggested that he mount the power module inside the cab and under the driver's seat.
My question is whether that's (1) even possible and (2) a good idea. I know that Switch-Pro wants you to mount the module vertically. Notwithstanding that, what do those of you who have mounted this system think? The thinking here is that the module is "out of the elements" and inside the cab of the truck instead of the engine bay.
Be gentle, this is literally my first thread post.
hb216 is offline   Reply With QuoteReply With Quote
Old 07-13-2019, 09:23 AM #2
SnowYeti's Avatar
SnowYeti SnowYeti is offline
SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough
SnowYeti's Avatar
Well I think mounting inside of the cab negates how easy it is to add new accessories and how clean everything can be done right under the hood. Having to run every wire through the fire wall is exactly what I wanted to avoid.
I use a Power Trays. There is some adjustment to it, so mine is angled slightly inward. But really even if it was level I don’t get the concern. It is mounted above the intake, in an area that will see very little water, if any (other than washing your engine bay) in an area that is hot so water won’t last long, and...I think having the water shed down and away from the seals makes a lot more sense than a horizontal shedding of any water. Plus having also done searches I could not find anyone that had issues with horizontal. Maybe I am missing something.
Anyway whatever you do horizontal or vertical mount it in the engine bay, plus power from your battery has to go directly to it, neg and pos. And those cables are pretty thick. Under the seat sounds like a complete PITA.
I also did the Power Trays with the single ARB compressor. So clean and convenient. Though very little info on how to do it even on their sight. I should have done a DYI on it in hindsight.
Also on the 4R rubber seal for the harness going into the cab there is a nub (looks like a mushroom at the 1 o’clock position), if you cut off the top of the mushroom it is a molded in pass-through the perfect size for the Switch Pros controller cable, tight and waterproof. Much better than cutting a slit.
Any questions let me know, or photos, etc. Do it right and you will love it!
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
SnowYeti is offline   Reply With QuoteReply With Quote
Old 07-13-2019, 09:41 AM #3
Seriously? Seriously? is offline
Seriously? is on a distinguished road
Thumbs down Seems odd
I guess it's possible, but that seems like an odd location to me. There should be plenty of room in the engine bay to mount it in a couple of different locations. Unless you've added a bunch of stuff under the hood already.
Seriously? is offline   Reply With QuoteReply With Quote
Old 07-13-2019, 11:05 AM #4
Desid's Avatar
Desid Desid is offline
Desid is on a distinguished road
Desid's Avatar
Just line Snowyeti said it would be difficult to be adding all the accessories you would still have to run the wiring back into the cab of the vehicle, plus you would also have to run the power cable from the switch pro into the cab too. Honestly there's no harm in either getting a power tray to mount it to and if you're worried about water getting into the connector you could always mount it vertically in the engine bay. The switch pro is pretty water resistant for the connector. Plenty of people mount it horizontally without issue including me. Not worth the hassle to run it into the cab to be honest with you.
Desid is offline   Reply With QuoteReply With Quote
Old 07-13-2019, 04:05 PM #5
Thanks, all. Appreciate the quick feedback. Just an update in case someone was considering this now or in the future. I wrote Switch-Pro and they wrote back right away - on a weekend, no less. (That's good service). They pointed out that the battery cable is only 24" long and therefore wouldn't reach inside the cab. If you did need a longer cable, they'd be able to sell you one. If you use your own, you void the warranty. It's a quality control issue for them.
I'm going to mount it vertically inside the bay on the driver's side using the SDHQ mounting plate.
Old 08-02-2019, 11:17 PM #6
SD Offroad SD Offroad is offline
Real Name: Derek
SD Offroad is on a distinguished road
Real Name: Derek
People have definitely did post on a failed Power Module, I'll see if i can find it and will post a link.
Check out this vertical Mount Tray just becoming available...
Switch Pro 9100 Vertical Mounting Solution
SD Offroad is offline   Reply With QuoteReply With Quote
inside , location , module , mount , switch-pro
Switch Pro 9100 Vertical Mounting Solution NC[4]Runner 5th gen T4Rs 114 04-27-2022 12:26 PM
Switch Pros horizontal mounting of the power module jayhat 5th gen T4Rs 3 08-02-2019 11:06 PM
Switch Pro 8100 mounting location MadeInMaine 5th gen T4Rs 53 11-24-2017 04:06 PM
HDH Wired Switch Panel - Mounting Location kenski 5th gen T4Rs 3 09-20-2013 05:42 PM
Need 1986 4runner Master power window switch armrest location Iceman14 Want to Buy/Trade 0 06-19-2013 10:33 AM
