Old 07-14-2019, 09:42 AM #1
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
Oil filter housing upgrade question
Recently bought the parts to upgrade the plastic housing to the aluminum style. Figured I'd have everything on hand including the tool for when I finally have to do my own oil changes.
Anyway, per all the threads, I ordered the following housing:
PN 15620-31060.
Also purchased the recommended Motivx housing removal tool..MX2320
was checking to see if the tool would work on the new housing and the keys aren't lining up...
Was the tool mislabeled or am I just overlooking something really simple?
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 10:15 AM #2
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Amazon? Waiting on the filter housing, wont be here until tuesday. I will let you know, if you dont get an answer before then.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 10:15 AM #3
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
PN 15620-31060.
No filter housing is the wrong one, I believe people have bought that one it’s for a rav4 and used it on the 4runner by swapping out the center tube from the plastic one. But you would need the rav4 filter wrench.
Arnezie is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 10:42 AM #4
Charlievee's Avatar
Charlievee's Avatar
Just checked the tool and it lines up with the cheep one i picked up from the box store.
Old 07-14-2019, 10:50 AM #5
KarrotJuice KarrotJuice is offline
KarrotJuice is on a distinguished road
I have the exact filter cap and removal tool. I've been using both on my 2018 SR5 for the last year. No problems at all.
Three slots on one side..the middle slot and the single slot on the other side should line up. If not, removal tool is defective.
KarrotJuice is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 11:22 AM #6
kjbenner kjbenner is offline
Real Name: Kevin
kjbenner is on a distinguished road
Real Name: Kevin
Did you try rotating the filter wrench 180°? I have the same housing and wrench, and I'd have to check but I want to say it only goes on one way, because either the notches on the wrench or the ribs on the housing are different widths (one fat one and one skinny one).
2015 Trail Edition w/ KDSS
TRD forged wheels, Cooper AT3 4S (P265/70R17)
kjbenner is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 01:43 PM #7
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
it's the exact same combo referenced in the this Trail4R write up and his works fine..
Metal Oil Filter Housing Upgrade + Motivx Tools Oil Filter Wrench
Old 07-14-2019, 01:44 PM #8
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
that's what I thought, going to check again..may have to send this tool back.
Old 07-14-2019, 02:10 PM #9
Charlievee's Avatar
Charlievee's Avatar
I ordered the same housing, will confirm or deny any issues in tuesday.
Old 07-14-2019, 05:18 PM #10
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Did mine this way, no problems.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 08:04 AM #11
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Somethings clearly not right with the tool. Tried position every possible way on the housing and no luck. Going to run up to the Autozone near my house and see if they have one of the tools there to try. The one I have is going back.
Old 07-15-2019, 09:14 AM #12
Charlievee's Avatar
Charlievee's Avatar
Does it fit the filter on your truck?
Old 07-15-2019, 09:50 AM #13
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
haven't tried the housing on my vehicle just yet, but the P/N is correct..I was looking through some of the posts on Amazon where I bought the wrench and one guy had the exact same problem. Something about a bad batch of wrenches. They sent him a new one and it worked fine.
Old 07-15-2019, 12:29 PM #14
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Great customer service from Motivx. This was the response I got from them..
It sounds like you got a defective wrench. It's rare, but occasionally during manufacturing the lower portion of the wrench becomes slightly rotated and no longer correctly indexed with the 64mm hex portion above which causes the problem you're describing. I was able to find your order that you placed on Amazon on 7/5/2019, just confirm for me that the shipping address is still good for you and I'll have our warehouse send you a replacement out today for you at no charge. I'm also including a pre-paid return shipping label for you to send the defective wrench back, we would like to inspect it to make sure that's the issue. Just print it out and attach it to the box and drop it in the mail. Let me know on the address and if you have any additional questions. Thanks and sorry for the inconvenience. -Motivx Support Team
Old 07-15-2019, 05:20 PM #15
Charlievee's Avatar
Charlievee's Avatar
Glad you got it worked out. Got my parts today and the tool i recieved works as does the cheap one i already had.
housing , oil , recommended , tool , upgrade
Oil Filter Housing Mack1611 5th gen T4Rs 10 05-31-2019 09:20 AM
WTB - 4TH GEN 06 V8 air Filter Housing groove4u Want to Buy/Trade 5 03-15-2016 06:31 PM
WTB: 3rd Gen Air Filter Housing Run 4 Fun Want to Buy/Trade 6 02-26-2016 02:51 PM
Tacoma Air Filter Housing 4Dunner Maintenance/Detailing 0 03-08-2013 06:48 AM
Where to buy new oil filter housing sandwich 5th gen T4Rs 3 06-23-2011 02:08 PM
