Old 08-01-2019, 08:00 AM #31
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
Originally Posted by Muzzle of Bees View Post
In your pic the metal housing does not line up with the metal removal tool notches.
But I think I get the issue if the internals needed swapped to work.
I am surprised that the fit was that far off though.
I see what you're saying..not sure if you read back in the thread where I had to send the tool back because it was defective. Something went wonky in the casting process of that batch and caused the key holes for the housing to be off.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 09-25-2019, 01:24 AM #32
Snacks Snacks is offline
Snacks is on a distinguished road
Originally Posted by 57HotrodVW View Post
Yep. Written by yours truly...
Metal Oil Filter Housing Upgrade + Motivx Tools Oil Filter Wrench
To reinstall the tube, first insert the bottom plate, with the domed side facing up. Put the spring inside the tube. Insert the tube into the housing at an angle, placing the tabs of it under the “feet” inside the housing. Push in at the bottom of the tube, while applying pressure at the top. Once installed, the tube should have spring tension on it. Press down on it a few times to ensure that it moves freely, and does not come out of the housing.
So I was helping the brother in law with his oil change and I noticed he did not swap out the tube from his old plastic oil filter housing onto the new metal one. He's probably driven the car 20K miles like this, should he be concerned? We have since swapped the longer tube onto his metal housing but he's a bit worried he may have damaged his engine by not filtering the oil properly. From my understanding, the metal tube is where the filtered flows back into the engine after oil has passed through the outside of the cartridge filter. As it flowing back up tube, even though the tube is shorter, the oil is still flowing back into the engine because it's flowing inside of the inner walls of the cartridge filter right? The difference in height is negligible.
Snacks is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 08:40 AM #33
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Haven't gotten around to doing this swap, but I thought it was a clearance issue..If the housing went on with the other tube without issue, I can't imagine any damage was done.
Old 09-30-2019, 09:11 AM #34
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Glad you bought the Toyota approved filter housing. I bought one from NAPA Auto Parts and it leaked. I put the plastic one back on and no problems.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
housing , oil , recommended , tool , upgrade
Oil Filter Housing Mack1611 5th gen T4Rs 10 05-31-2019 09:20 AM
WTB - 4TH GEN 06 V8 air Filter Housing groove4u Want to Buy/Trade 5 03-15-2016 06:31 PM
WTB: 3rd Gen Air Filter Housing Run 4 Fun Want to Buy/Trade 6 02-26-2016 02:51 PM
Tacoma Air Filter Housing 4Dunner Maintenance/Detailing 0 03-08-2013 06:48 AM
Where to buy new oil filter housing sandwich 5th gen T4Rs 3 06-23-2011 02:08 PM
