Old 07-14-2019, 10:31 AM #1
Clrems77 Clrems77 is offline
Real Name: CJ
Clrems77 is on a distinguished road
Real Name: CJ
Leveling kit for 2015 Limited
Please excuse me in advance for this rookie question.
Looking to level out the front of my 15 LE and put some TRD Pro wheels on. Can anyone suggest what leveling kit would be good and if the rear needs anything? Thanks!
Clrems77 is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 11:02 AM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
5th Gen 4Runner Lift Buyers Guide - Toyota 4Runner Forum - Largest 4Runner Forum
5thGen level info??
Leveling/lift kit
Which Leveling Kit
Leveling Kit Questions
Leveling Kit Question???
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 11:23 AM #3
Real Name: CJ
Real Name: CJ
Thank you sir. Actually sifted through most of those which confused me a bit more. Im hoping to use simple spacers on the front only. Toyotec seems to be the preferred brand, but will the spring need to be compressed or not? Couldnt find the right answer to that question. Also need to know which height (1.5,2,2.5") for that even look.
Old 07-14-2019, 11:42 AM #4
Bossman's Avatar
Bossman's Avatar
Best lift or spacer kit for mainly urban driving with a little off roading
Lift or Leveling options
What to expect from spacer lift ( Daystar)
Cornfed 1" front spacer to level only...
Toytec 3" Leveling Kit review.
Old 07-14-2019, 12:02 PM #5
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Cornfed ones don't require strut disassembly. They go on top of the strut. I run the 1" in front only and it's about perfect.
Drives fines, caster is OK, rides the same, looks better, cheap and easy install.
Note that the "1" lift spacer" really only measures a half inch but gives a 1" difference due to the IFS suspension setup.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 01:13 PM #6
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
I had this Toytec spacer installed when Toyota replaced my xreas. TOP1-T Front Top Plate Spacer Kit It gave me one inch lift and makes the 4runner look much better.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 02:00 PM #7
Nice thing about doing the cornfed 1" is that it uses the stock studs. You just get different nuts with the kit. Easier install.
Old 07-14-2019, 03:40 PM #8
I just used this because my dealer installs a lot of toytec lifts and deals with them a lot. The struts were disassembled anyways.
Old 07-14-2019, 06:16 PM #9
Nick B Nick B is offline
Nick B is on a distinguished road
Did you do an alignment after the install ?
Nick B is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 07:47 PM #10
Yes. Didn't really need it though. I always would just to double check
Old 07-15-2019, 10:32 AM #11
Here's mine with the Cornfed 1" in front and loaded the way I usually travel for work - about 100-150 lbs in the rear. Bring the wife and a kid or 2 on a trip and their gear and it sits completely flat real quick, almost to the point of being low in the rear. It's a good place to be. Glad I didn't go higher in front unless I was messing with the back too.
Old 07-15-2019, 10:49 AM #12
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
I used a cornfed 1" spacer lift up front on our '15 Ltd., drives more like a truck with the chin up a bit from stock, still has a bit of rake so the rear isn't lower when fully loaded, install was a breeze, do get an alignment after though.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 02:25 PM #13
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
Take a look at the Eibach kit. Looks great with pro wheels.
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 06:56 PM #14
MrGainzz's Avatar
MrGainzz MrGainzz is offline
MrGainzz will become famous soon enough MrGainzz will become famous soon enough
MrGainzz's Avatar
I went with a full suspension kit since I didn’t like the idea of using spacers and it’s sitting perfectly levelled now.
MrGainzz is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 11:29 PM #15
Stephencovar Stephencovar is offline
Stephencovar will become famous soon enough
You can’t go wrong with the Eibach kit. It looks so good and rides even better. Personally, I wouldn’t go with spacers.
Stephencovar is offline   Reply With QuoteReply With Quote
kit , leveling , pro , put , trd
2015 Leveling Kit / Rear Sag CaptainJJD 5th gen T4Rs 13 08-04-2017 09:15 AM
Thoughts- 2015 Leveling Kit WheelJack 5th gen T4Rs 19 09-21-2015 08:55 PM
2015 4runner sr5 leveling for 33s toddsatre 5th gen T4Rs 6 05-19-2015 06:08 PM
Leveling kit and Warranty On 2015 TRD Prp Downthetrail 5th gen T4Rs 15 05-09-2015 08:41 AM
Leveling kit for 2015 Trail and 33's? B.strouse 5th gen T4Rs 4 03-06-2015 01:21 AM
