Old 07-15-2019, 12:22 AM #1
bepuvu88 bepuvu88 is offline
bepuvu88 is on a distinguished road
ABS/Traction Control Lights
So over the weekend I had a friend that is a mechanic for VW help me install my lift kit. We got it all installed however it appears that I have multiple lights on now.
The ABS, Traction Control and some other lights are on my dash. Any suggestions? Could we have had the ABS sensor damaged by accident?
bepuvu88 is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 12:47 AM #2
GripT4R GripT4R is offline
Banned
GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light
Banned
Have you looked at the ABS sensors?
GripT4R is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 01:26 AM #3
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
What are the other lights?
I doubt it was anything like my issue but if your steering light is on could be a damaged spiral cable in the steering wheel. I want to say unlikely though.
You could try the zero point calibration for starters to see if that clears it. Not difficult at all.
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
Old 07-15-2019, 03:14 AM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Also check the wire going to each ABS sensor. There have been threads where people doing lifts or other suspension work have stretched or broken ABS wires.
Old 07-15-2019, 09:26 AM #5
These are the lights that are on.
Old 07-15-2019, 09:32 AM #6
Multi-terrain Select indicator warning light (flashes continuously)
ABS
4WD indicator warning light (flashes rapidly)
Slip indicator light
Old 07-15-2019, 09:38 AM #7
Verast Verast is offline
Verast is on a distinguished road
I had this same issue when I installed my lift kit as well. I started going over my head about what didn’t look right when I installed it and remembered how much tension was on my abs sensor wire harness when I was trying to install the front.
I checked my abs wire harness connection at both ends and everything was still connected. No damage to my sensors either. Then reading around a lot here I decided to change out the wire harnesses on both sides and that took away my lights as soon as I cranked on the 4Runner.
Hope this helps. The harnesses aren’t too costly and the install is very easy.
Verast is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 09:30 PM #8
mtwyi66 mtwyi66 is offline
mtwyi66 is on a distinguished road
Just had the same issue come to find out it was due the LEDs I put in my fog lights
mtwyi66 is offline   Reply With QuoteReply With Quote
Old 06-16-2020, 07:41 PM #9
GO_USN's Avatar
GO_USN GO_USN is offline
GO_USN is on a distinguished road
GO_USN's Avatar
mtwyi66 Just had the same issue come to find out it was due the LEDs I put in my fog lights
Did you find a fix for it? I just had my OEM headlights replaced with LED lights and having the Brake, ABS, and VSC lights come on, although intermittent.
2011 SR5 4WD (Magnetic Gray). ICON Stage II W/Light Racing UCA's. 20" Ultra Gauntlet with 285/55/20 Nitto Terra Grapplers. Satoshi Grille Mod with Grillcraft and FJ40 Logo (Painted Dark Gray). Trail Edition Foglight Bezels. INTERIOR - ROSEN NAV/Entertainment System (Factory Look). Weather Tech Floor and Cargo Liners.
GO_USN is offline   Reply With QuoteReply With Quote
Old 06-16-2020, 08:31 PM #10
GO_USN's Avatar
GO_USN's Avatar
How did you find out it was the LED lights? I have the same issue as soon as I installed LEDs but was wondering if you found a fix other than going back to halogens
Old 06-17-2020, 06:49 PM #11
Mack1611 Mack1611 is offline
Mack1611 is on a distinguished road
Do this... Yaw Rate and Acceleration Sensor Zero Point Calibration
Mack1611 is offline   Reply With QuoteReply With Quote
Old 12-12-2020, 10:45 PM #12
Hezael Hezael is offline
Hezael is on a distinguished road
I just had the exact same issue after installing the 5100 Bilstein lift kit.
Dashboard lights that are on are
1. ABS
2. 4WD (flashes rapidly)
3. Slip Indicator light
From what I've read it is most likely the ABS sensor. Wondering where I can buy the part and if I would be able to reinstall it myself with instructions?
Hezael is offline   Reply With QuoteReply With Quote
Old 12-12-2020, 10:47 PM #13
Where did you find the part and what is it called?
Old 12-13-2020, 12:45 AM #14
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
Seems like most people that get these warning lights on are because they damaged the harness to the wheel speed sensor. It’s a 10mm bolt that holds the sensor in place and it’s comes right out so you don’t yank on the harness. I’ve seen so many post where they say not to remove it but that’s a lie.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
abs , abs/traction , control , lights , traction
VSC on/off, VSC Trac, Traction Control AND ABS Lights on. RunnerJeff 4th Gen T4Rs 40 08-03-2022 06:16 PM
TPS and traction control lights !? swegen 4th Gen T4Rs 9 04-10-2018 03:36 PM
Check engine, vsc and traction control lights all on? medgell Problems & Warranty Issues 2 08-23-2017 06:37 PM
VSC/Traction Control/ABS/VSC TRAC lights ccvortex 4th Gen T4Rs 7 06-11-2016 04:18 PM
vsc/vsc off/and traction control lights Jason02 General Discussions 12 04-28-2014 12:18 AM
