Old 07-16-2019, 01:53 AM #1
toyo808 toyo808 is offline
toyo808 is on a distinguished road
Need advice for Bilstein 5100 and toytec rear coils
I did some searching but it seems like everyone has a different set up or gen then my runner. Is anyone with a 5th gen running Bilstein 5100 max front and back with Toytec RCC2.0P. Any pictures and what is the final ride height? 2 or 2.5 lift? Thanks
toyo808 is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 08:50 AM #2
billnourse's Avatar
billnourse billnourse is offline
billnourse will become famous soon enough
billnourse's Avatar
I have a Toytec Ultimate that includes 5100 bilstein's with 650# front springs, and Toytec Superflex rear coils with extended length Bilstein 5100's.
Need advice for Bilstein 5100 and toytec rear coils-20190517_061055-jpg
billnourse is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 09:05 AM #3
4runnin4mylife's Avatar
4runnin4mylife 4runnin4mylife is offline
4runnin4mylife has a spectacular aura about 4runnin4mylife has a spectacular aura about
There are quite a few people running that combo. Bilsteins set at 2.5" up front and a toytec 2" lift spring in the rear. Of course you will still have some rake only taking out .5", but at least you will get rid of some. Can't help you on pics, but i don't think you would be disappointed... just remember that some rake will still be left! That's why you see people that go 2.5" up front usually go 1.5" in the rear, unless they carry equipment, etc. quite a bit.
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
4runnin4mylife is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 11:16 AM #4
do you think i should also change out the front springs to toyotec also to help with the rake? Any model in general I should look at? I wanted a more level look and I figured going coils in the long run was better than spacers.
Old 07-16-2019, 11:28 AM #5
Stephencovar Stephencovar is offline
Stephencovar will become famous soon enough
Just out of curiosity, have you considered the Eibach Pro Truck Lift? It comes with front and rear springs and shocks. The front is 2.75” and rear is 1”. The front is also adjustable for when you had more weight. It’s all engineered together so you know that everything is designed to work together. Check out the Eibach Lift thread. I have pictures of my lift on my 2019 TRD ORP.
Stephencovar is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 11:35 AM #6
[QUOTE=Stephencovar;3322747]Just out of curiosity, have you considered the Eibach Pro Truck Lift? It comes with front and rear springs and shocks. The front is 2.75” and rear is 1”. The front is also adjustable for when you had more weight. It’s all engineered together so you know that everything is designed to work together. Check out the Eibach Lift thread. I have pictures of my lift on my 2019 TRD ORP.[/QU
I wanted to keep the bilstien 5100 since they are less than a half a year old. Im also planing on buying another 4runner soon so the Eibach could be a option for that. thanks bro for the advice and pics looks good
Old 07-17-2019, 09:38 AM #7
Coils are definitely better than spacers. If you wanted to keep the bilsteins at 2.5" up front and use coils (which is definitely better than spacers), I would look at Wheelers coils or Dobinsons coils. If you aren't stuck on having 2" lift in the back they have 1.5" options, if i'm not mistaken, and it would get your rake where you want it, along with doing it correctly with coils.
Old 07-17-2019, 11:07 AM #8
ManhstuhT4R ManhstuhT4R is offline
ManhstuhT4R is on a distinguished road
Just really depends what you are wanting to go with but I have seen a lot of our customers go with this option. You just might want to pair the back with toytec boss ones since it accommodates for 1 to 3 inches of lift. Let me know if I can be any assistance, I'm Anthony over here at toyteclifts.
ManhstuhT4R is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 11:43 AM #9
ScarfaceT4R's Avatar
ScarfaceT4R ScarfaceT4R is offline
Real Name: Christoph
ScarfaceT4R will become famous soon enough
I have the Toytec Superflex 2" rear (RCC2.0) paired with Bilstein 5160's. I don't really mind the rake with the approx. 3" front lift I have - but it's def noticable IMO. Anything less than 3" up front, paired with the 2" lift in the rear will be a lot more noticable.
My gripe with these rear springs/shock combo, is the nasty hop it has while going over bumps. My intention is and always has been to purchase a steel rear bumper/swing away tire carrier. But how it rides right now, you basically have to bring it under 5mph so the rear doesn't bounce like crazy!! - unless you like that sort of thing
If I could to it all over again, I would have gone with the 1.5" springs by Bilstein pictured below my rig...
Need advice for Bilstein 5100 and toytec rear coils-rake-jpg  Need advice for Bilstein 5100 and toytec rear coils-capture-jpg
3" lift up front courtesy of 5100 Billys & Toytec HD coils + top hat spacers, 5160 Billys in rear w/ Toytec Superflex 2" coils, front Wheelers bumpstops/2" rear Toytec bumpstop drop, TRD Pro skid, Icon UCA's, Pelfreybilt sliders, HID's & LED's galore, full MBRP Catback, K&N CAI, Fuel Tactic 17x9's -12mm , 285/70/17 Cooper STT Pros, Total Chaos BMC kit, etc..etc..blah, blah
ScarfaceT4R is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 11:56 AM #10
Thanks for the advice! yeah, I'm thinking about changing the front to toytec also to match the back and add the top spacer they sell. My only concern is that both the wife and I use the car so being 3' off the ground is uncharted waters. I also didn't want to spend the cash for UCAs if I didn't need too. The runner is mainly a work and Sunday beach car here in Hawaii. I hate to say it but its a pavement princess
Old 07-17-2019, 11:59 AM #11
Aloha Anthony, if I upgrade my front and get the spring with the top hat wont I need to change my UCAs? That was my only concern about going that route. Whats the cost for the front springs with the top hat shipped? Is there a discount for forum members and since I live in Hawaii shipping is a huge concern. Can you please pm me a quote?
Old 07-17-2019, 12:07 PM #12
I say if it's mainly for pavement, then don't worry about the UCA's. I bought the UCA's in the chance that I may swap out front suspension with beefier coilovers & wanted that clearance + articulation.
It all really matters about what your end game thought process is. Are you planning on running larger tires than the stock 265's? With any lift over 1.5" up front, I sure hope so.
Old 07-17-2019, 12:51 PM #13
Yes to bigger tires. Im looking at doing 275/285 in the future. But i plan to run the stocks for now to make use of the tires and save some money. So in the end I wanted to
1-lift my runner 2'-3'
2-have a leveled look
3-go with bigger tires
4-not replace the UCAs if possible
set up in a week will be Bilstien 5100 1.75 front w/stock springs and UCAs. Bilstiens in the rear w/toytec super flex rear coils, getting rid of the daystar rear spacer.
what you guys think?
Old 07-17-2019, 01:20 PM #14
I vote 1.5" rear springs - especially with 1.75" lift up front. It'll be more level looking rather than a$$ high.
Old 07-17-2019, 03:36 PM #15
Looks like I’m going to be buying toytec front springs and plate to match the rear coils. You guys think I need new UCAs? I was also going to run 275/285 tires with TRD wheels. I can’t have my runner ass high 🤔🥺
5th , bilstein , gen , rcc2.0p , toytec
2nd Clip Bilstein 5100 with Toytec HD coils? ScarfaceT4R 5th gen T4Rs 5 05-03-2024 09:24 AM
How much will my new lift settle? Bilstein 5100 +Toytec/SAW Coils.... Keith_PDX 5th gen T4Rs 23 07-21-2020 10:07 AM
FS: 4th GEN Bilstein 5100 with toytec coils extrmsob293 For Sale: Suspension/Wheels/Tires 6 11-13-2013 12:07 PM
Toytec/Eibach Coils & Bilstein 5100's jrebolloso 3rd gen T4Rs 7 05-23-2011 11:23 PM
