Old 07-16-2019, 02:57 AM #1
mr.walleye mr.walleye is offline
mr.walleye will become famous soon enough
dealer alignment question
I took my 2018 in today for my 20,000 mile service, they said I failed my front wheel alignment because of excessive toe in and they wouldn't rotate the tires, they said it's best to leave the good tires on the back. I think they are full of crap and should of rotated them (I plan on doing it myself later today). anyone ever hear of this, I know the wear isn't that bad by the report they gave me (never mind the date, it's wrong). I'm also wondering what caused this. I've added an odyssey 34R battery (54#'s) which is heavier than the factory Panasonic, a set of RGS tube sliders and 4 Goodyear duratrac tires, same size as factory tires, 265/70r/17. they said for $90 they'd fix the alignment problem then rotate the tries. are they trying to rip me off? I refused the alignment because I'm just trying to figure out what UCA I want for my lift (Toytec/Bilstein 3") which I already purchased and it's sitting in my garage. I'm not paying for 2 alignments a few months apart. any thoughts?
dealer alignment question-img_6588-jpg
mr.walleye is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 06:48 AM #2
johnbt's Avatar
johnbt johnbt is offline
johnbt will become famous soon enough johnbt will become famous soon enough
johnbt's Avatar
https://m.tirerack.com/tires/tiretec....jsp?techid=52
The new tires or good tires go on the rear. I wasn't raised that way, but that's what research proves.
Why is your front end out of whack? Potholes. You hit a curb. You hit a rock. Bad luck.
My dealer has automatic laser-blah-blah-blah-equipment and they do free alignment checks every time you show up. The free report shows every measurement in fractions of degrees, etc. It's not just a checklist.
Mine has been out of spec twice in 25k and I'm due for my free 30k oil change in a month.
My wife's '16 Avalon Touring wore out the cheap 18" factory tires in 20k and needed another alignment - at Firestone - when I had the Michelin Premiers installed.
Alignments happen.
2023 TRD ORP w/KDSS. Red again.
This is a big step up from the 1986 Subaru GL wagon I used on the Outer Banks beaches for 14 years. That thing would go anywhere in the sand on 185/70-13 tires. Dual range 5 speed, factory skid plate, 3 position manually adjustable rear shocks and armored exhaust. All factory, including the white spoke wheels. The front sub frame finally rusted apart.
johnbt is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 01:23 PM #3
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
Alignments should be considered regular maintenance. Your tires will thank you.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 12:42 PM #4
wsgoat's Avatar
wsgoat wsgoat is offline
wsgoat has a spectacular aura about wsgoat has a spectacular aura about
wsgoat's Avatar
How often do you have your vehicle aligned?
*2017 4R TRD Pro, 01H5 Cement w/ Shrockworks dimpled tread plate sliders, Moroso oil catch-can, black powder-coated roof rails. (summer runner).
*2005 4R Sport Edition w/ Bilstein 5100's, Gen-5 brake upgrade, K&N cold air intake, cabin air intake mod, Falken Wildpeak AT3. (winter runner).
*1965 Pontiac GTO convertible, 4-speed w/tri-power, PHS documented. (born in Freemont CA).
*1962 Chevrolet C-10 (short-step) pickup, 4-speed, survivor. (born in Oakland CA).
wsgoat is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 12:59 PM #5
cb1111's Avatar
cb1111's Avatar
That's a slightly difficult question to answer as it depends on your car, your driving style and the roads you drive on.
Barring any unforeseen events, I have my car aligned annually when I swap from winter tires to summers.
Old 07-18-2019, 05:51 PM #6
Alignments happen.
nope, haven't hit anything and nobody else drives it. just trying to figure why it out of alignment.
Old 07-18-2019, 07:13 PM #7
cb1111's Avatar
cb1111's Avatar
It may never have been in alignment to begin with.
I complained about the alignment on my new TSX - one dealer said "not covered" and the other said "these things get tied down on the boat then bounced around, so most of the cars from Japan and Europe need an initial alignment.
alignment , factory , rotate , tires , today
Alignment question KWSRStorm 5th gen T4Rs 7 06-08-2018 08:58 PM
Alignment Question tamadabee128 5th gen T4Rs 9 07-01-2015 05:26 PM
Alignment question AZrunner11 5th gen T4Rs 2 06-02-2014 10:18 AM
Warning: Dealer Alignment Check on Limited Chrisinvermont 5th gen T4Rs 0 07-31-2013 11:00 AM
alignment question robb1887 3rd gen T4Rs 15 04-25-2013 01:32 PM
