My dealership called yesterday and both the Southeast Regional Tech and Toyota NA tech will be here on Tuesday AM to look at my car.
I have requested/insisted that I have a meeting with them. They said no problem.
No doubt, some people actually had bad tires and were able to fix it, but there's a large number of us whose tires/wheels are in perfect condition and still have this vibration. I will be bringing this thread and maybe a few others printed out, along with the Lexus SB.
So if you guys have any legit questions you think I should ask the Toyota NA tech, let me know by tomorrow!
I will be asking about what the regional tech did (alignment, road facing, suspension re-torquing, etc.) and what their plan of action is now?
I will report back after the meeting and hopefully with a positive update and fix for everyone else who is losing it over this same issue.
Mine has generally had the steering wheel vibe at 60mph (with KDSS, stock suspension). It was minor to not noticeable with the OEM tires, but with the more aggressive duratracs it is more noticeable (stock size, LT load range C). It is temperature and tire pressure dependent. Cold mornings it is generally not noticeable, but hot afternoons it will become more prominent. I believe this to be primarily a tire balance issue for my vehicle. The tire balancers did their work at stock tire pressure blissfully unaware that the LT tires should be run on the street at a higher pressure. If I drop the tire pressure to the stock levels, the vibration goes away, matching the road force balancing work a bit better. It also gets better when I rotate my tires and shows up again after about 2.5k miles or so.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers | 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
2018 TRD Off Road with KDSS
This vehicle is completely stock
My husband and I have been dealing with shaking in the steering wheel since we pretty much got the car. I have been back and forth with Toyota on multiple occasions (we filed a claim with Toyota and it's ongoing since the issue has not been resolved), several wheel balancing, road force balancing, test drives, swapped tires with wheels and tires from new vehicles off the lot and still we are having the SIGNIFICANT vibrations at roughly 60mph. We were hoping it was just a simple balance issue, but after reading several forums and going through everything, it looks like there might be an ongoing issue with no solution. Our local dealership also said that it was a "normal characteristic" of these vehicles. They even said they test drove two of their brand new 4runners on the lot and have the same shimmy. When we asked to go for a drive in those vehicles, suddenly everyone was too busy to come with us...
I made this account specifically for this post. I'm hoping your meeting can get some answers because we are extremely frustrated as well. We are open to providing you with any other information about our experience.
I just had my KO2's road force balanced and the issue is fixed for now. The guy at Discount Tire made a comment about not being able to put weights on both sides of the wheel (because mine are aftermarket) can be problematic. Not sure if that is true or not, but sounds maybe reasonable.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, wind fairing, and Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers.
I know there have been lots of replies, but, mine has zero vibration. Ran stock tires for about 45k miles with zero vibration, have some new Coopers on it, zero vibration, stock size.
This wobble thing is the only part of the 4R that has me a tad concerned about the future. How significant is the wobble? Does it make the drive feel dangerous? Or is it just a slight vibration that one can tolerate? Thank you
My 5th gen does not have any steering wheel shake. My 3rd gen had it at 60mph just like the 5th gens have. The solution for the third gen was this finger plate adapter. Use this during balance. I don't believe road force is necessary. Use the finger plate adapter and the corresponding short centering collar to mount the wheel flat to the balancing machine. Also a good idea to clean/scrape any rust etc. off the wheel hub, where the wheel studs are before remounting the balanced wheel.
May want to bring in this TSB and ask what they think about it. attached as a PDF below
2015 4runner Limited
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
I have had a slight steering wheel vibration ('19 TRD ORP no KDSS) that got much worse once I passed the magic 5000 mile mark. Appointment next Tuesday so it will be interesting to see what they tell me compared to what has already been discussed here.
Will update as info is available.
If they fix it, I will request a TSB for everyone else’s sake.
Or I’ll send you my paperwork as proof if it helps get work accomplished on your T4R.
I'm sure we would all appreciate it.
Mine is so intermittent I really can't tell if it's just the road on my commute or not. Need to find a good stretch of road to run in multiple conditions to confirm if it's road surface dependant or not.
I have a 2011 TE with KDSS. I got it new in 2010 and put around 130k miles on it. I have not changed or repaired any of the suspension and have always ran the OEM tires. The only time I had any vibration in the wheel was when the tires were getting near the end of their life. Once I had new tires put on it went away.
