Old 07-16-2019, 04:12 PM #16
Dame-O's Avatar
Dame-O Dame-O is offline
Dame-O is on a distinguished road
Dame-O's Avatar
Originally Posted by pumacat24 View Post
Ah, unfortunate news
I guess yours is not enough to bother you?
That's also a strange thing, I test drove 2 TRD ORP off the lot, no KDSS, and they were vibrating too, one worse the mine and one better. But then there are others that don't have it. So very strange.
It was pretty bad when I first got my KO2's. I took it back to the tire shop and they were slightly out of balance. After getting them perfectly balanced I only notice the steering wheel shake at 60mph and pretty much goes away past 65mph. It doesn't bother me too much since I don't usually keep a highway speed right at 60. If there's a permanent fix I'd definitely get it done though.
2018 TRD Offroad
Eibach pro truck stage 1
Method 703 titanium wheels 17X8.5 0 offset
285/70/17 BFG KO2’s
Dame-O is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 04:23 PM #17
Rusty Spuds Rusty Spuds is offline
Rusty Spuds is on a distinguished road
2013 TE/KDSS Stock, never had any vibrations or any wandering with the dunlaps or michelin ltx.
It rides like it on rails. Good luck ,I hope you find a fix.
Rusty Spuds is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 04:47 PM #18
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Same here, although mine were fine at first and gradually felt the slight shake at 60. After a road-force balance the issue went a way for a thousand or 2 miles and came back. Not a big deal really. It's time to get another balance. The feel is classic out of balance feel, but is it the tire or is the 4Runner, we may never know.
NOTE: Never had any vibration issues with the stock tires and still didn't after I got my Toytec Boss lift installed. Had it 15,000 miles before I put the KO2's on. So if I were troubleshooting, I would suspect the tires, but it seems like the issue occurs with other tires too.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 07-16-2019, 04:48 PM #19
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
I have KDSS and have a vibration from 50-60mph. I have stock size KO2 and they have been a ***** to balance from day 1 and i'm pretty sure that is the culprit. I'm hoping to replace the tires in a Labor day sale soon.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 05:16 PM #20
Furagwa Furagwa is offline
Furagwa is on a distinguished road
2018 TRD OR w/KDSS. No lift. 10k miles. Stock tires. No vibration.
Furagwa is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 06:24 PM #21
mteolus's Avatar
mteolus's Avatar
Just doing a google search shows a lot of KO2 balancing issues and it seems like 60 mph is a common theme.
Old 07-16-2019, 07:58 PM #22
nils.walk nils.walk is offline
nils.walk is on a distinguished road
Not sure if I'm having the same issue or not but sounds very similar. 2018 off-road w/KDSS, stock was fine. Lifted with 33s and there is a vibration around the 50-60mph range but it comes and goes. It seems to be there after the vehicle has sat for a bit, and then goes away after I've taken a couple of decent corners at highway speeds that load up the suspension. Leaving my house and onto a hwy to head into town I climb up a hill and it is pretty consistently there when I accelerate to over 50, but then there are two sweeping corners that if I take at close to 60, the vibration will settle down, often to the point of being completely gone.
nils.walk is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 01:02 AM #23
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
2018 ORP with kdss. Completely stock. Zero vibration. Now at 8k miles.
Does your vibration feel tire induced? Not all tires are the same. Not all tires are round. Have you considered temporary use of Equal Balance Bead for test purposes? Removal of driveshaft? Flir imaging for unusual heat spots?
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 04:30 AM #24
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
2011 TE with KDSS, zero vibration on the stock tires.
When the stockies wore out, I replaced them with KO2's a size larger (275's) on the TRD PRO wheels. Still zero vibration and it was cheap @$$ Costco that did did all the work. (no ALIGNMENT)
10K give or take miles later I added a lift, (got it aligned then) still no vibrations before or after.
It did wander at highways speeds like a lost dog, until I had it aligned after the lift.
nglayton is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 09:23 AM #25
4runnin4mylife's Avatar
4runnin4mylife 4runnin4mylife is offline
4runnin4mylife has a spectacular aura about 4runnin4mylife has a spectacular aura about
2016 Trail w/ KDSS
No wheel vibration what so ever with a few different setups over the years.
Three different suspensions: Stock, bilstein 5100's @ 2.5" with rear spacer and stock UCA's, and now Icon Stage 2 with JBA UCA's.
3 different tire sizes and load ratings: Factory 265's, BFG 275 E-rated, BFG 285 C-rated.
Factory weight and weight added: Factory ride and 150 lbs up front consisting of bumper, winch, air comp. etc.
Hope this helps and good luck!
If the vibration was that bad where it put me through all it has with you, I would take up the guy at the dealership and just get in a new one and not look back. Seems like the best option to just put this all behind you. Not to mention the extra time and less stress you will have!
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
4runnin4mylife is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 10:23 AM #26
slprciv slprciv is offline
Real Name: Nick
slprciv has a spectacular aura about slprciv has a spectacular aura about slprciv has a spectacular aura about
Real Name: Nick
2018 ORP with KDSS and lift...no issues
'18 TRD Off Road Premium w/KDSS.....and Kings, etc...
slprciv is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 12:25 PM #27
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
To OP:
Just as another thought: can you ask the dealer that have your truck to swap the wheels and tires from another 4Runner that is definitely vibration free… like that TRD Pro you drove? As this will completely remove wheels\tires as a culprit.
When I had my 4th gen, one of the OEM wheels would cause slight steering wheel vibration, and it was the wheel not the tire… took me around a year and two sets of tires to figure that out, wheel would balance with no issue and had no damage… go figure…
Also, to add to my first response, when I did my lift I kept stock UCA so my caster is not optimal, but 4Runner is still buttery-smooth and tracks straight.
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 07:14 AM #28
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
2015 with KDSS here. No real vibration issues in general. I did have a few temporary instances of vibration every now and then for different reasons. Here's what to look for:
1. Wheels/ tires, brakes and bearings: could be defective, unbalanced, or worn out. Unlikely at low mileage, but worth looking into. Bad rotors or brake pads can also cause vibration, especially while braking. IMO 90% of vibration issues are somewhere here
2. UCA/ LCA bushings: my LCA bushings wore out at 70k km. it did start some vibration for some time, followed by occasional 'clunks'. You can replace the OEM bushings without swapping the whole LCA, but Toyota will not tell you this
3. Suspension issue: Again, unlikely at low mileage. A horribly worn out or blown damper/ spring will feel like you're driving a bouncy sponge. Visually inspect the shocks for leaks.
4. Alignment: Needs to be DONE RIGHT by someone who knows what they're doing. A bad wheel alignment can cause vibration or it pulls to the sides. Hitting a curb, offroad use...etc. can throw off the wheel alignment
Good luck!
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 01:35 PM #29
csommers's Avatar
csommers csommers is offline
csommers will become famous soon enough
csommers's Avatar
2018 ORP w/ KDSS and lift: zero issues with vibration
2018 Nautical Blue TRDORP w/KDSS, Dobinsons(F:302/700,R:723/705), Camburg UCA
csommers is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 04:19 PM #30
pumacat24's Avatar
pumacat24 pumacat24 is offline
pumacat24 has a spectacular aura about pumacat24 has a spectacular aura about
pumacat24's Avatar
Originally Posted by 4runnin4mylife View Post
2016 Trail w/ KDSS
TRUE!... but if they can FINALLY find a fix for it, then it would help countless others!
2019 TRD Pro | IG: @trdprocat | RSG Sliders | Falken Wildpeak AT3W | Morimoto/XD LEDs | CTX Tint
past: '18 4Runner TRD ORP... RIP, Kaiyo!
'07 4Runner SE... SOLD
'02 4Runner SR5 4WD... SOLD
pumacat24 is offline   Reply With QuoteReply With Quote
car , fix , issue , steering , toyota
Steering Wheel Vibration fdbyrne 4th Gen T4Rs 22 06-02-2018 09:51 AM
Steering Wheel Vibration rnguyen95 5th gen T4Rs 4 08-30-2015 07:15 PM
Removing Sway Bar with Upgraded Susp, Thoughts? Bala de Plata Off-Roading 31 05-21-2008 02:46 PM
For those with upgraded susp. and larger tires; how often do you hit WOT? T?@\7 Off-Roading 9 04-19-2008 07:31 PM
Vibration in steering wheel danieladrian 3rd gen T4Rs 1 08-26-2007 12:59 PM
