Old 09-06-2019, 07:57 PM #76
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
Originally Posted by pumacat24 View Post
People!
2 - POSSIBLE BIG NEWS MAYBE A FUTURE TSB!?!
Look what is NOW available for 5th gens... STEERING WHEEL DAMPER:
2018 Toyota 4Runner TRD Off-Road Premium Steering Wheel Damper. Damper, Steering SHAKE. Brakes, Suspension - 4571360070 - Genuine Toyota Part
This steering wheel damper was only still available for 4th gens when I looked for one 2 months ago.
The dealership is now waiting on this part to arrive. The bad news is that they have no ETA yet as I assume I must be one of the first to receive it from Japan.
While I don't have the steering wheel shakes anymore, I still feel some buzz on the steering wheel. I'm not sure if I have some other problem or it is just the tread of the KO2 tires causing because it depends on the road surface.
I went ahead and ordered the 45713-60070 damper to see if it will help. It was only $20 because of the labor day coupon code from Toyota. I ordered it 3 days ago and surprisingly it shipped today.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 09-06-2019, 08:40 PM #77
LimeLED's Avatar
LimeLED LimeLED is offline
LimeLED will become famous soon enough LimeLED will become famous soon enough
LimeLED's Avatar
Be sure to let us know how it goes!
2023 4Runner TRD Pro, Midnight Black
2022 4Runner TRD Pro, Lime Rush
2022 4Runner TRD Off-Road Premium, Magnetic Gray (SOLD)
2018 4Runner TRD Off-Road Premium, Super White (SOLD)
LimeLED is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 01:52 PM #78
I tried to install the steering wheel damper today. After removing the air bag, here is what I surprisingly found.
The Good News
It already comes from the factory with the damper. It looks exactly like the one I bought, even to the paint markings.
The Bad News
There is one less solution to the problem.
However I’m not sure if all 5th gens come from the factory with the damper or it started at a certain year.
So that was a waste of $20
TRD Pro wheels
Old 09-14-2019, 03:20 PM #79
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
The Good News
The Bad News
Interesting comment about the KO2s. Did you have that buzz before the KO2s? And what suspension do you run?
I always had a steering buzz with KO2s on my Subaru and never with my DD tires. It was obviously the tires as my KO2 was a trip tire so I switched regularly and it was definitely related to the tires. But the KO2s were also LTD and very heavy compared to the stock tire so I never really thought of attributing the buzz to the tread.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 09-14-2019, 04:26 PM #80
LimeLED's Avatar
LimeLED's Avatar
The Good News
The Bad News
Bummer! Thanks for trying and posting your findings for us.
Old 09-14-2019, 06:21 PM #81
I had stock Dunlop AT20 and Goodyear Ultraterrains. Both tires gave the steering wheel shakes. The BFG KO2 gives no shakes but some buzzing which is still much better than before.
Suspension is still all stock.
TRD Pro wheels
Old 09-14-2019, 06:26 PM #82
I wonder if people with other years can remove their air bag and check. It is held in place by only 2 torx screws.
TRD Pro wheels
Old 09-15-2019, 09:16 AM #83
O2RunnerSR5's Avatar
O2RunnerSR5 O2RunnerSR5 is offline
O2RunnerSR5 is on a distinguished road
Did not read this entire tread but when I installed my OEM cross bars on my roof rack I immediately got steering wheel vibration at highway speeds. I plan on removing them soon.
17 SR5
O2RunnerSR5 is offline   Reply With QuoteReply With Quote
Old 10-02-2019, 11:19 PM #84
three0 three0 is offline
three0 is on a distinguished road
New to the forum, first post. Looking to purchase a 2019 Limited for a cross country trip and wherever after that. Worked for the big three in powertrain, worked in the off-road transmission and axle business.
This stuff happens. I’ve seen models shipped with lead wrapped steering columns to conceal the vibration. Much like a steering dampener “fix”. A lot could cause a vibration. But, I’ve read this has been going on for near 15 years with the same widespread fixes and, often no resolution. This I have never seen. The problems get fixed, usually during the first year of production.
It’s discussed at times as a right of passage to 4Runner ownership. How widespread is this issue? I’ll be spending a lot of time on highways, probably often in the 60 - 70 mph range. And I’m certainly not inclined to spend my life at dealers along the way. I’ve owned Cherokee's and GC's along with 30 years of driving German cars. I'm quite familiar with spending time at dealers and Lemon Law settlements. I’m buying a Toyota first and foremost for reliability. As in no unscheduled stops due to the vehicle. Is this vibration issue something that I should pretty much count on?
three0 is offline   Reply With QuoteReply With Quote
car , fix , issue , steering , toyota
Steering Wheel Vibration fdbyrne 4th Gen T4Rs 22 06-02-2018 09:51 AM
Steering Wheel Vibration rnguyen95 5th gen T4Rs 4 08-30-2015 07:15 PM
Removing Sway Bar with Upgraded Susp, Thoughts? Bala de Plata Off-Roading 31 05-21-2008 02:46 PM
For those with upgraded susp. and larger tires; how often do you hit WOT? T?@\7 Off-Roading 9 04-19-2008 07:31 PM
Vibration in steering wheel danieladrian 3rd gen T4Rs 1 08-26-2007 12:59 PM
