Old 07-16-2019, 08:48 PM #1
Ripper238's Avatar
Ripper238's Avatar
Check engine trac off green blinking truck
Not sure what this is or why this happened. I'm also not getting the miles per gallon green Eco light now for some reason.
What could this be am I going to kill it if I drive it home?
Sent from my SM-N960U using Tapatalk
Old 07-16-2019, 09:08 PM #2
Jarheadoo7's Avatar
Jarheadoo7 Jarheadoo7 is offline
Jarheadoo7 will become famous soon enough
Jarheadoo7's Avatar
I'm pretty sure any time the CEL comes on it shuts down the VSC/ Trac off by default...
Jarheadoo7 is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 09:11 PM #3
Ripper238's Avatar
Ripper238's Avatar
When I put it in reverse the brackets around the (R) blank and it seems to be slow to the ingage in drive. This is a 2019 with 500 miles on it.
Old 07-16-2019, 10:12 PM #4
Ripper238's Avatar
Ripper238's Avatar
Takes a few seconds to go into drive and clunks into gear.
Not sure if it's safe to drive or if I should get a tow?
Old 07-16-2019, 10:13 PM #5
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
#1, go get an obd2 code reader.
#2, if the cel isn’t flashing, then it’s generally a “go get it looked at but is driveable”. Maybe not optimal as VSC/Cruise/etc may be unavailable, but not imminently catastrophic. If the cel is flashing, then pull codes/tow it to minimize damage. You should be under warranty, so give the dealership a jingle.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 10:49 PM #6
Ripper238's Avatar
Ripper238's Avatar
The green truck is flashing. Multi-terrain select.
I got a remote start and alarm put in so that must have been what caused it. I have AAA so I guess I'll have them tow it.
Thanks
Old 07-16-2019, 11:20 PM #7
DarkPassenger's Avatar
DarkPassenger DarkPassenger is offline
DarkPassenger is on a distinguished road
It’s worth asking: Get gas today? Check the cap. A loose cap will trigger the check engine light, which disables traction control, multi terrain select, etc.
If a loose cap caused the problem, it may take some time for the ECU to register and return normal functionality. You’ll may still need to clear the codes with an OBDII dongle, which will clear the dash lights and restore all functionality.
DarkPassenger is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 11:33 PM #8
Thanks
Green truck flashing shouldn’t be a big deal. The CEL is the real one to watch. Maybe something official in the vehicle manual, but I’m away at the moment so can’t tell ya.
Old 07-16-2019, 11:54 PM #9
Ripper238's Avatar
Ripper238's Avatar
I got gas three days ago with no issues and I double checked the cab a few times.
In the manual the CEL didn't really help since most of it seems to be emissions and other things. My biggest worry is the delay in engaging the transmission and the lurching forward when it goes into gear.
I'll get it checked out one way or another tomorrow.
Sounds like I should invest in an OBDII.
Old 07-17-2019, 12:20 AM #10
Ripper238's Avatar
Ripper238's Avatar
Do you guys think if I disconnected the negative battery terminal for a bit then reconnected it would solve all this? Or should I just get it towed and tested?
Old 07-17-2019, 08:26 AM #11
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
If this error immediately followed the installation of the remote start kit, it's your suspect.
waypoint is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 08:36 AM #12
Ripper238's Avatar
Ripper238's Avatar
almost. I drove about 30 miles parked it and then when I started it up again it gave me the error of course. It couldn't have happened while I was there....
Yeah definitely. Apparently they can check stuff so I'm having it towed there just to be safe. Clunking into drive is concerning.
Just so weird would have such a horrific reaction to whatever they did. and I bought this truck because it was simple, apparently the electronics are fairly sophisticated. Lol
Old 07-17-2019, 08:51 AM #13
bobdacat bobdacat is offline
bobdacat is on a distinguished road
possibly the neutral safety switch. a little electric box thats on the outside of transmission. Had the similar issue. Hard to shift and the eco light goes off, and pretty sure it wasnt shifting into 5th gear. It wasn't on all the time, got it to dealership when CEL little offroad light were on, the took it off examined it and put more of the dieletric grease and sealed it up. no further issues.
bobdacat is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 09:58 AM #14
Ripper238's Avatar
Ripper238's Avatar
Tested with OBDII and it gave a bunch of transmission errors which is strange?
Transmission range sensor circuit?
Old 07-17-2019, 10:52 AM #15
Ripper238's Avatar
Ripper238's Avatar
Thinking it's the neutral safety switch?
check , drive , green , kill , reason
Check engine light, VSC TRAC & TRAC OFF lights crainmain Maintenance/Detailing 120 11-22-2023 07:11 PM
Check engine light on + Trac off light on + 4LO blinking= ?????? RiDE 5th gen T4Rs 26 05-04-2021 02:42 PM
check engine & VCS Off light blinking lonkelm 4th Gen T4Rs 23 08-21-2020 07:51 PM
Check engine light vsc trac & trac off lights come on piptraderfx New Members 5 03-14-2014 07:47 AM
Check engine + VSC/TRAC blinking after install baz Engines / Suspension / Wheels / Tires / Audio / Accessories 3 08-03-2008 08:14 PM
