Old 07-24-2019, 08:36 AM #16
rwrobs777's Avatar
rwrobs777 rwrobs777 is offline
Real Name: Rob
rwrobs777 is on a distinguished road
rwrobs777's Avatar
Real Name: Rob
Originally Posted by Fialdj View Post
I did new plugs, then put the old back in. dealer saw only 2 hits on Cyl #2, so I replaced that coil with factory. still does it.
You said the miss occurs whenever the AC is on...a failing AC compressor can cause a miss...anything the can cause the crank to slow down !!...PCM uses the crank sensor to detect misfires...I'd take it to diagnostic shop and let them scope the injectors and secondary ignition...may be even mechanical related !!...watch the first few minutes of the video !!...does it happen with the AC off ??
https://www.youtube.com/watch?v=D0LXtvY3Qdg&feature=youtu.be&t=6m50s
rwrobs777 is offline   Reply With QuoteReply With Quote
Old 07-24-2019, 08:41 AM #17
rwrobs777's Avatar
Real Name: Rob
rwrobs777's Avatar
Real Name: Rob
Originally Posted by Jivewalker View Post
I'm at 176,000. I blame the slight rough idle on mine on the aging AC compressor. might be wrong, definitely wouldn't cause a miss. I'm interested in what you find as well. could be anything, bad gas, wires, injectors, etc.
A failing AC compressor CAN cause a misfire !!
Old 07-24-2019, 11:48 AM #18
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I learned something new today! Don't think mine is failing, maybe just wearing, it has some miles on it for sure!
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 01:41 PM #19
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
So dealer got back to me about my miss fire and so far it sounds like a spark plug got over torqued and cracked. They replaced it. Let see if that fixed it. Will report after I get the truck back.
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 02:22 PM #20
Fialdj Fialdj is offline
Fialdj is on a distinguished road
It does it more often with AC on. but also when off. it posted a cyl #4 misfire P0304. but that has only happened once. I ordered 2 coils for #2 and #4 and 6 new plugs. it's running like shit right now. but has been good the past 2 weeks. I think an electrical connection gremlin somewhere?
2011 Toyota 4Runner Trail
2006 Ford Mustang GT Convertible
Fialdj is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 11:49 AM #21
Unhappy
well, the P0304 code has come up 2 more times. so I'm hoping the new coil and plugs will help. I also went to Advanced Auto and had them test the batt/alt. Battery is good, but alternator is questionable. only 13.0 volts when loaded. I verified this using my ODB reader and TORQUE app. only between 12.8 & 13.2 volts. so I'm going to bad an alternator too.
Old 08-17-2019, 12:28 PM #22
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
I had a similar problem with my Tundra a few years back. I chased it for a while until I figured out I had 2 coil packs bad. Swapping them around just confused things for a while.
Old 08-17-2019, 03:19 PM #23
callihan_44 callihan_44 is offline
callihan_44 is on a distinguished road
I had a miss once that was hard to find in a chevy truck, I happen to pop the hood in the dark and found what was causing it..one of the plug wires had a small crack in the insulation and was throwing a spark about 2 inches in length to the block...couldn't see this during the daylight hours
callihan_44 is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 09:51 AM #24
well, plugs and 2 coils came in. I found the #4 plug had 2 cracks in it. I had the #2 plug crack last year. replaced all 6 plugs and the coils on #2 & #4. my truck is running much better. I believe the alternator issue is now a different problem, but because I get a 13.1 reading at the ECM I will replace it too. it just came in.
Thank for your help.
PS I asked NGK why the plugs would crack. the guy told me it's because I used a tool to install and they didnt go in straight. that would mean I cross threaded them, which I didnt. I used the socket and extension to turn the damn thing. any of you know why a spark plug would crack?
Old 08-26-2019, 01:13 PM #25
themaestro's Avatar
themaestro themaestro is offline
themaestro will become famous soon enough
themaestro's Avatar
Did you torque to spec? I can't remember off the top of my head what it is, but I know there's a torque spec for the plugs. It's not that much if I recall.
themaestro is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 01:32 PM #26
headpaneer's Avatar
headpaneer headpaneer is offline
headpaneer will become famous soon enough
headpaneer's Avatar
The torque spec. is 13 lb⋅ft according to the Antman thread.
5th Gen Spark Plugs- Photo Tutorial. So easy a 6 yr old girl can do it...
'16 Magnetic Grey SR5 Premium - FN 6-Shooters, 265 KO2s, TRD CAI, various other do-dads
So happy to be back in a 4Runner again! Previous Toys - '87, '89 and '93 4x2 Pick Ups, '03 4Runner, '08 Sequoia
headpaneer is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 01:48 PM #27
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
It was probably cracked before it was installed, dropped on floor, quick look, it's ok (not!). I had one once that was driving me nuts and as I pulled a plug to look at it as I turned it electrode up I thought I saw something move, it was the insulator around the center electrode that was broken and when I would flip it over to install it the porcelin would slide down and rest against the side electrode and shield it from firing. Strange things can happen!
Old 08-27-2019, 09:35 AM #28
scarpozzi scarpozzi is offline
scarpozzi is on a distinguished road
I've never had a plug crack in 25 years of working on my cars. I blame poor manufacturing... =P
scarpozzi is offline   Reply With QuoteReply With Quote
codes , displayed , engine , happening , miss
2010 engine miss Skraler 5th gen T4Rs 10 02-06-2014 08:56 PM
engine miss brianbu Problems & Warranty Issues 6 07-13-2012 06:28 AM
engine miss LAUREN.6 Classic T4Rs 4 10-09-2010 06:27 PM
engine miss 03vrod Classic T4Rs 2 10-31-2009 02:25 PM
Engine Washing/Engine Miss!!! suprdtydvr 3rd gen T4Rs 4 03-20-2008 11:25 PM
