Old 07-17-2019, 04:27 PM #1
Greenlawnracing Greenlawnracing is offline
Greenlawnracing is on a distinguished road
50K maintenance checklist - free mechanic for a few days
I pride myself in doing my own work, but unfortunately have fallen behind on giving my wife's mall crawler the love it deserves.
We are heading out of town tomorrow, but her parents are coming to stay with my daughter while we are gone. He is a lifelong farmer who has pretty impressive mechanical abilities. I've turned wrenches with him on many industrial machines.
I haven't done anything beyond changing the oil, and it just hit 50K. I figure I should leave him the following instructions and have him perform the below tasks with the transmission being the priority. Can you guys keep me honest?
Transmission fluid:
Do this one first, and follow the instructions below. I assume he can get a nice synthetic fluid at the auto parts store of his choice. Looks like he'll also need three gaskets from the dealership, and if he can't find my bottle pump he'll want to buy a new one.
Transmission Fluid Change procedure - Toyota 4Runner Forum - Largest 4Runner Forum
Torque specs:
Drain plug - 180 lb-in/15 lb-ft (14mm)
Overflow plug - 180 lb-in/15 lb-ft (5mm hex)
Fill plug - 27 lb-ft (24mm or 15/16")
Parts:
~4 qts (per drain) Toyota ATF WS fluid - Toyota part # 00289-ATFWS
Manual says 3.2 qts for a drain and fill, but on my other Toyota I've always gotten more than what the manual said and ~4 qts has been reported in the 4th gen forum
Drain plug gasket - Toyota part # 35178-30010
Overflow plug gasket - Toyota part # 35178-30010
Fill plug gasket - Toyota part # 90301-15004
Special tools:
Toyota SST 09843-18040 (basically you just need a wire to jumper two OBD ports)
Bottle pump (to use for filling)
Transfer case:
Use the instructions below. I assume he can buy the gear oil at the auto parts store, and doesn't need the Toyota stuff.
Torque specs:
Drain plug - 27 lb-ft (24mm or 15/16")
Parts:
SAE 75W Toyota Genuine Transfer gear oil LF or equivalent - Toyota part # 08885-81080
1.1 qts (part-time) or 1.5 qts (full-time)
Drain plug gasket - Toyota part # 90430-A0003
Fill plug gasket - Toyota part # 90430-A0003
Tips:
1) Ensure you can remove fill plug before draining
2) After filling, leave plug out and let sit ~5 minutes and re-check, add if necessary
3) Diff and xfer case gasket kit
Front and rear differentials:
Follow this thread - Front and Rear Diff fluid change - Toyota 4Runner Forum - Largest 4Runner Forum
Buy about five quarts of this from Advance Auto Advance Auto Parts - Down for Maintenance
And buy this from Toyota while he is getting the gaskets for the transmission.
x3 12157-10010 (Silver)
X1 90430-24003(Copper)
Accurate? Did I miss anything?
Greenlawnracing is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 05:57 PM #2
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Looks good, you might not find the 75W transfer case oil at the dealer. Amazon has it.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 04:43 PM #3
ellroy2 ellroy2 is offline
ellroy2 is on a distinguished road
Wouldn't recommend touching the transmission with only 50k miles. I changed the fluid on my old 4th gen when it had 100k miles. It was a pain. These things have solid transmissions.
Get Mobil 1 for the diffs and transfer case. I was just at the dealer the other week buying gaskets for my differential oil change and I asked about the Toyota transfer case oil and he said they only have it in 5 gallon barrels.
'16 TEP w/KDSS Super White, TRD PRO grill and front bumper valance
ellroy2 is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 04:53 PM #4
PaulB-2006 T4R's Avatar
PaulB-2006 T4R PaulB-2006 T4R is offline
Real Name: Paul
PaulB-2006 T4R will become famous soon enough
Real Name: Paul
forget the maintenance have him install this...
50K maintenance checklist - free mechanic for a few days-s-l640-jpg
2016 Trail MGM. P265 70/17 Falken Wildpeak AT3W. Matte Black TRD Wheels. Leveled with 2" spacer. Heated Front Seats. All LED interior. Mud flaps deleted. TRD Air & Oil Filter. TRD Oil Cap. FJC Shifter. Subaru Kicker tweeters. Hikari LED Low Beam. Cougar Motor LED DRL/High beam. Hood "scoop" and lower door wrap.
2006 SR5 4WD V6 - Owned from July 2009 with 38,200 miles to March 2017 with 150,100 miles.
PaulB-2006 T4R is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 06:35 PM #5
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
I bought a 56K camry which was slipping from 3rd to 4th really bad at high rpm. I thuoght the transmission was toast. Started looking for parts to swap transmission. Then decided to try the cheapest repair which was DIY full 8 quarts fluid swap. Valvoline Maxlife synthetic.
Immediately shift quality was restored. Slippage was completely gone. Shifting was a bit notchier and solid but not in a bad way. It grabbed like it was supposed to.
So I've come to the conclusion that:
1. OEM fill was meant to deliver smooth seamless shifting. Because that's what new buyers expect from a brand new vehicle off the lot right?
2. The break in metals have finally contaminated the fluid to the point where unwanted slippage has occurred.
So a fluid swap is in store for the 4runner @ 75k but its definitely not that EASY if you're not familiar w/ the methods to check and adjust proper transmission level.
If your mechanic is old school it isnt just a flush and dipstick check.
1jzgte is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 08:19 PM #6
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
I enjoy working on cars, but if I was coming to stay with the grandkids I would not appreciate a work order list.
I would be there to give them cake for breakfast and ice cream with every meal and a later bedtime.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 01:42 PM #7
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Drop it off at the dealership on your way out of town, along with your "honey do" list and a pre-authorized credit card. Include instructions to call when the work is finished. When they call you about 2 hours later, you can call the father-in-law and ask him to pick it up for you..........
nglayton is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 11:56 PM #8
DougEFresh2 DougEFresh2 is offline
DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough
ALL FUIDS GUIDE: Beginner Fluid Maintenance
Hope this helps. I keep a copy of this in my glove box just in case something needs changed or flushed soon when I'm out and about!
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
DougEFresh2 is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 11:59 PM #9
meltdown meltdown is offline
meltdown will become famous soon enough
How many of these old threads are you going to revive?
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
meltdown is offline   Reply With QuoteReply With Quote
drain , fill , part , plug , toyota
Severe service and free maintenance littlehandegan 5th gen T4Rs 20 02-02-2016 05:50 PM
Free AutoCheck for 30 days beezee General Discussions 20 08-18-2013 07:36 PM
Pre-timing belt maintenance checklist juggernaut 3rd gen T4Rs 5 03-11-2012 05:28 PM
Question about 2 yrs free maintenance program beamer4prez 5th gen T4Rs 21 06-10-2011 01:06 PM
2 year free maintenance hofs05 5th gen T4Rs 9 06-03-2010 09:41 PM
