Old 07-20-2019, 09:41 AM #1
GreyhoundGuy's Avatar
GreyhoundGuy GreyhoundGuy is offline
Real Name: Joel
GreyhoundGuy is on a distinguished road
Real Name: Joel
Question Replace Complete Alternator for Failed Voltage Regulator?
Good morning, all. I have a question I'm hoping you can help with.
We've been having problems starting our 4R. Clicks over and sometimes catches to start, sometimes doesn't. I got it running and took it to O'Reilly Auto (nearest place that could test). They ran a test on the battery and the battery came back fine. He continued testing and said the starter also checks out fine. He continued testing and said that the voltage regulator failed, so we are going to need a new alternator. (I should add that I have no reason to not trust them. They've helped a lot in the past in diagnosing problems, so I'm assuming what they're telling me is accurate.)
Is the voltage regulator part of the alternator assembly, or is it separate? I'm wondering if it's something I could take care of without having to remove or swap out the entire alternator. If I do have to do the entire alternator, no worries. I've got a couple days this next week I can work on it once the part is in.
Thanks in advance for your help. I appreciate it.
-Joel
Save an Athlete. Adopt a Greyhound!
2010 4Runner Limited
GreyhoundGuy is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 11:03 AM #2
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Typically you swap the whole alternator. Had it happen on a Honda but I would assume the T4R is the same.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 11:45 AM #3
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
I'd rather rebuild an OEM alternator than buy a low quality 'rebuilt' alternator from a box store. If you don't think you can rebuild it yourself, take it to a local starter/alternator repair shop.
DougR is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 11:51 AM #4
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
If you are capable of replacing it yourself, then you should be able to test it yourself. Just hook up a meter to the battery and start engine. Voltage should be just above 13.3v. Turn on high beams, A/C on full blast to put alternator under a load. Does it drop below 12.5v?
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 03:46 PM #5
Friggin Idiot's Avatar
Friggin Idiot Friggin Idiot is offline
Real Name: Luke
Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice
Real Name: Luke
Might go for an upgrade while you're at it.
DC Engineering 270A Alternator - Group Buy (Closed)
DC Power & Engineering HO Alternators
"But what do I know.... I'm just a Friggin' Idiot!"
The Idiot Thread - 2014 Trail Premium w/KDSS & some mods
2018 BMW 340xi M-Performance 6MT
Friggin Idiot is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 05:33 PM #6
Real Name: Joel
Real Name: Joel
Thanks, all! I appreciate the help.
Old 07-20-2019, 05:59 PM #7
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Alternators are pretty easy to rebuild if you can find a kit for them. Kits usually come with new brushes, bearings, and diode/regulator assy. The new brushes will need to be retained by a pin (because they are usually spring loaded) until you get the case back together - then pull the pins out. I looked and looked for a kit for my old Nissan and never found one - ended up getting a rebuilt one.
Old 07-24-2019, 12:24 AM #8
Real Name: Joel
Real Name: Joel
Thanks to @harper7 for posting info about the alternator swap in the service manual in the stickies section. I was able to download everything and am ready to go tomorrow.
After our daughter was born (she's almost 4 years old), our 4Runner quickly changed from an offroad-wannabe to a daily driver with a carseat in the back. I don't need anything crazy in terms of alternators, so I went with a rebuilt one from a local parts shop.
Hopefully all goes well tomorrow.
-Joel
alternator , entire , part , regulator , voltage
Alternator Voltage Question derekl123 4th Gen T4Rs 12 07-09-2020 01:46 PM
Bad voltage regulator on new alternator? KCscout 4th Gen T4Rs 9 06-23-2019 08:14 PM
Anyone Replace Voltage Regulator in Alternator? Bandit Runner 3rd gen T4Rs 11 12-09-2017 02:04 PM
Voltage regulator upgrade popsmoto 3rd gen T4Rs 4 01-03-2014 12:52 AM
Voltage Regulator on the Alternator Question snowbrdr033 4th Gen T4Rs 3 10-24-2011 08:38 AM
