Originally Posted by Whoknows
Use quad lock already for bicycles - love ur idea. Would you mind sharing details? Which motorcycle mount is that how did you attach it.
I used the ram mount instructions from here:
5th Gen 4Runner iPhone/ Droid Phone Mount - 4Runner Phone Mount
Bought a 1/4” hex bolt and washer from my local hardware store then these online:
RAM Ball Adapter with 1/4"-20 Threaded Hole:
https://www.amazon.com/dp/B006RKF1X8/
RAM Mounts RAM DBL SOCKET ARM A-LENGTH Body Other Bases BLK- RAM-B-201U-A:
https://www.amazon.com/dp/B002L9LW00/
Quadlock Motorcycle 1” Ball Adapter:
Motorcycle - 1" Ball Adaptor – Quad Lock(R) USA
So washer and hex bolt go through the dash from the inside, connect ram ball adapter to that on the outside, connect ram double socket arm to that, then quadlock to the other side of the double socket.
As far as drilling the hole and lining it all up, I basically just shoved the whole mount when put together as far back into the dash area as it could go, then scooched it up and out a bit so there was clearance around ram ball adapter and marked it with a sharpie on the painters tape. Pulled the dash out, used that to place the mount setup back on the marking and finish marking out exactly where it would go. Drilled a pilot hole at the center of my marking then finished with a 1/4” bit.
