Old 07-20-2019, 07:27 PM #1
Shabang's Avatar
Shabang Shabang is offline
Shabang is on a distinguished road
Shabang's Avatar
Lightbulb Cartrimhome Marker Lights Installation
Hey ya'll. If you don't already know, there's a really cheap and nice company in China that makes stuff like the TRD pro grille and blackout letters for the 4Runners. It's a great company but they're a little lacking on instructions, and as someone who struggled to put these lights in correctly, I've made this hopefully useful "guide"
I don't have any pics of the inprogess but I have finished pics and those should be enough.
Here I'm just going to talk about the Marker Lights themselves
So assuming you already put in the TRD grille, or you're just installing these with the base model grille, the first thing you're gonna wanna do is some modifications to the wires themselves.
This is the part that I had to do some thinking about, being quite a novice myself at car modifications
So in the kit, you should get a fuse holder. The kit has 3 marker lights, a looooong wire that connects those three, and the fuse holder. What you're gonna wanna do is on the end of the long wire where the positive and negative wires stick out: they stick out maybe 2 inches and then there's a black cover for the rest of the distance. You're gonna peel back that black insulation wire about 12 inches. This is because the negative wire is going to have to be grounded on the ground wire near the battery, and the positive wire has to go behind the firewall.
Ok, you've peeled back the cover. Now, there is a bolt that holds in the ground wire on the driver side wheel well, you need to loosen that. Here is a little piece of information that is very important. On the bolt, there is a washer and then behind that washer there is the round piece of metal (the ground). You need to strip your negative (black wire) back about half an inch. The now stripped wire goes BEHIND the washer so it makes contact with the ground metal itself. Whew, that was a lot to process, hopefully this pic will help you out.
Alright, now your black wire is grounded. Here's a tricky part. The positive wire goes into that blue crimp you'll see coming out of the fuse holder. You need to strip the red wire about half an inch so there's good contact. Now, push the red wire into the hole inside of the blue crimp, and push it as far as it can go, though not forcefully. Once that's done, you could crimp it, but I taped mine at first just to test it out.
Here is the most annoying part: the firewall seal. Ugh it gives me shivers just thinking about it. So that fuse holder, the oddly shaped black box has to go through two layers of incredibly strong rubber. Just poke a hole in it and really squeeze it through, you might have to go back and forth between inside the car and outside in the engine bay.
And here is the final and possibly the most important part of this whole process. The black box that you now have hanging in the foot well (the fuse box) has two slots on it. In the kit you will receive a 5 and 15 fuse I believe (someone correct me if I am wrong) but for simplicity I am going to use the colors they have. So bear with me on this description: The fuse holder has two slots, and one slot is closer to the silver fuse connector that sticks out. Place the RED fuse in the slot closes to the connector, and place the brown fuse in the remaining slot. Word of warning, I placed mine like this as a complete guess, there were no marking for which went where. I am only instructing you to place your like this because it worked for me and no fuses blew out.
Ok, now you have the extra fuses installed. Now you may ask, where do I plug the entire thing in. Well I saw a couple diagrams from similar kits. Once you take the cover off of the fuse box, there is a diagram that shows a number (or type) of fuse that is plugged in. On the diagram there are two slots labeled "10A" and directly above those slots, there are two empty slots. I placed my fuse holder in the empty slot right above 10A and it works fine for me, but please correct me if I am wrong.
And viola, double check to make sure all connections are secure, bolts are secure, and you should be good to go. Give that ignition a turn!
Cheers ya'll and have fun!
Shabang is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 07:53 PM #2
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Yea we know of this company and the paid shills that accompany it
Depending on what u buy quality is hit or miss
Old 07-20-2019, 10:51 PM #3
teamjawbox's Avatar
teamjawbox teamjawbox is offline
teamjawbox is on a distinguished road
teamjawbox's Avatar
Dang. I've only made one purchase from them which was the TRDP grill clone. Guess I was fortunate as it turned out great. Sucks for those that weren't so lucky.
Sent from my SM-G950U using Tapatalk
teamjawbox is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 12:08 AM #4
Shabang's Avatar
Shabang's Avatar
True, but now that it is installed I honestly can't complain, looks pretty damn good for my eye. But I can see how some products could be a little worse
Old 07-21-2019, 10:24 AM #5
pointman pointman is offline
Banned
pointman will become famous soon enough pointman will become famous soon enough
Banned
Thanks for the write up on your install! Bookmarked for potential future use!
Cartrim is not good? I was going to buy some of their interior trim pieces.
pointman is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 01:29 PM #6
Shabang's Avatar
Shabang's Avatar
I think they're actually pretty nice, I bought the TRD grille and the lights and I can't complain. My only recommendation with the TRD grille install, is to take out the 3M tape they have and go buy some thicker 3M tape that has better hold, the grille tends to stick out a little so the thicker the tape, the better it will stick. I do recommend them though, cheaper than buying the Toyota made grille!
Old 07-21-2019, 07:38 PM #7
AKutzer AKutzer is offline
AKutzer is an unknown quantity at this point
Some updated information
They have a YouTube video on the product page on their website for the amber grille lights showing an installation. You do not need to go through the firewall because you can simply run the fuse holder into a fuse slot in the engine bay fuse box.
AKutzer is offline   Reply With QuoteReply With Quote
Old 07-22-2019, 12:05 AM #8
Shabang's Avatar
Shabang's Avatar
oh woa I didn't even know that, damn man thanks for callin that out.
Old 07-22-2019, 08:15 AM #9
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
lol did you just wedge a stripped wire under a washer for the ground? take the 5 seconds and at least crimp a ring terminal on that
for the fuses- if it was an empty slot on the fuse block then you only need the 1 fuse for your tap, you don't need the second fuse (the second fuse won't hurt anything though)
jhguth is offline   Reply With QuoteReply With Quote
black , fuse , holder , slots , wire
DIY marker lights in grille peakbaggerwolf 5th gen T4Rs 16 01-27-2022 02:39 PM
Front Marker Lights tombob55 4th Gen T4Rs 9 02-02-2019 08:36 PM
LED Marker Lights with Daytime Running Lights bigbadpoppa 5th gen T4Rs 6 03-26-2018 07:06 PM
ARB Marker/Fog Lights. Need help Chreaus 4th Gen T4Rs 4 02-18-2013 09:11 PM
Side Marker Installation 4Runner2000 4th Gen T4Rs 15 03-01-2008 01:35 PM
