Old 07-21-2019, 02:15 AM #1
TheNormsk TheNormsk is offline
TheNormsk is on a distinguished road
Push button start: Restarting the engine without switching off the radio?
One thing I don’t like about push button start is that there is no cycle to it like a key: off > accessories > ignition (start) > accessories > off. So you can go from running the engine to engine off (accessories on) back to engine on again without ever losing power to the radio. Truly useful when waiting to pick up kids....
With the push button start it has three start up modes:
1) off > ignition (and start with brake pressed).
2) off > accessories > ignition on > engine running (when pressed again with brake pedal)
3) off > accessories > engine running (when pressed again with brake pedal)
2 and 3 are sort of the same.
Now switching off is easy. Single press while in park will switch off engine, ignition and accessories. To keep the accessories on, shift to neutral before pressing the button and apply the foot brake. I find if I shift to park, it’ll then cut power to the accessories and this is annoying.
What I can’t figure out is if there is a way to restart the car without losing power to the accessories. Putting foot on the brake and pressing the button will restart the car but as soon as I do this the radio “reboots”. Truly annoying. I’ve tried times pressed of the button as well. No luck. Ideas?
TheNormsk is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 05:29 AM #2
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Hi TheNormsk,
There is a way to accomplish this! NEEDED: One 12V, SPDT (Single Pole Double Through) 10A or Higher relay. Next: One AOBSW800 "Latching" Control switch, (be sure that fits your 4Runner year dash knock-offs)!
Now remove the Head-Unit from the Dash. There are two wires that feed the HU: One Gray wire and One LT Blue wire. The Gray wire is the (Intermittent) circuit; this is the one that cuts power when you shut off the engine! The Blue wire (fuse size is 30A). This wire remains HOT to preserve your radio presets when the vehicle is off!
What you wanna do is energize the "Gray wire" using the AOB switch and the relay. So you must feed the Gray wire, using the relay's N/O (Normally Opened) contacts. Next: you need to decide on a HOT-AT-ALL-TIMES power source to run through the N/O contacts to feed the "Gray wire" when the truck is shut-off!
You can use the positive battery terminal to run this circuit, but I would rather TAP the HU's (HOT at all times) Blue wire to feed the Gray wire when the switch is in the ON Position, so you don't need to run a long line and use an IN-LINE fuse to protect that new circuit; because both of those wires are already fused, follow(?)!
Now you need to cut the LT Blue & Gray wires that feed the radio; I'd use male & female "Stake-On's" to connect the LT Blue & Gray wires; "See below":
Now that, that's been addressed, install and connect your AOBSW800 switch in the dash. ALL of my AOB switches are tied into the center console cigarette lighter; to prevent any (Aftermarket) lights or Sub-woofer amplifiers from being left on after the truck is turned off!
You can go to the AOB website and upload the wiring diagram for your particular application, and order the switch: Toyota Push Switches for Prado, Landcruiser, FJ Cruiser, Hilux, Rav4 and HiAce "Best to you"
rig
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 12:59 PM #3
Agent_Outside's Avatar
Agent_Outside Agent_Outside is offline
Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice
It’s called load reduction, pretty much every vehicle will cut power to accessories while it cranks.
Agent_Outside is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 06:48 PM #4
Shadytype Shadytype is offline
Shadytype is on a distinguished road
nevermind.. crummy post so I deleted it.
Shadytype is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 11:42 AM #5
Originally Posted by rigtec View Post
Hi TheNormsk,
rig
I think my mind just exploded reading this. That seems more work than I want to do, but thanks for the details.
Old 08-01-2019, 12:26 PM #6
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
hot damn.. how bout just wire a small capacitor between the power wire.. one sized large enough to keep the radio going for the 3 seconds of startup.. that way when you shut the car off and walk away the radio will just die off on its own after 3ish to 5ish seconds
any electricians wanna chime in? I've been wanting to do this for a long time since my aftermarket alpine takes for-****in-ever to re-start whenever i fire up the engine.. its really annoying too because bluetooth switches from radio to phone and i gotta juggle my phone to switch back to bluetooth.. most annoying when youre in a call..
1jzgte is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 04:29 AM #7
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
Originally Posted by 1jzgte View Post
"...any electricians wanna chime in?..."
I just did, lol!
The idea is to keep the HU powered up (temporarily) when the truck is shut-off. So... the Lt Blue wire is HOT at all times; that's to preserve the memory of the radio presets when the vehicle is off!
The Gray wire is the Main power source to the hu, but goes dead when the truck is shut-down... so the hu goes off, follow? So, it's just a matter of maintaining the power supply with the truck shut-off through the AOB Switch.
This will achieve the task of preventing the HU from 'Rebooting' if the vehicle is switched off for short durations with the "Key//Push-button" turned off! And if your going to be finished using the truck for the day... simply turn the AOB Switch off "BEFORE" getting out of the truck!
To me, that's the simplest way: just connecting those two wires together using the AOB Switch; no need to pull any wires through the dash or the firewall, cause these two wires are just inches apart on the rear of the hu! 'Best to you',
rig
Old 08-02-2019, 09:17 AM #8
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
Pull the accessory fuse, Find another that has power during on and crank with a meter. Install an add a fuse to that one. Run wire to the non hot side of the original radio acc fuse location.
https://www.google.com/search?q=add+...hrome&ie=UTF-8
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 10:59 AM #9
requires a switch.. there's gotta be a more automated method such as a small capacitor.. i just dont know enough maths to determine how large of a cap
accessories , brake , button , engine , start
Steering wheel lock (push button start) 'immobilizing the engine? rigtec 5th gen T4Rs 5 01-08-2020 11:05 PM
Push button start NomadM3 5th gen T4Rs 10 02-23-2015 11:27 AM
RFID Keyless Entry, Push Button Start and Remote Start BFLAN 5th gen T4Rs 41 04-17-2012 09:36 PM
Those with push button start 4ShoreRunner 5th gen T4Rs 7 06-30-2011 03:44 PM
