10-10-2018, 01:56 PM
'19 TRD PRO Slight Lift Question w/ new Fox suspension options
I have a Black TRDP on order and should be here in about a month. I'm thinking about a 2/1.5" lift level kit, but not sure if there are any that kits out there that will be compatible with the new Fox suspension. Does anyone know? Also planning on running 285 KO2's on SCS ray10's.
CURRENT: 2019 TRD PRO, BLACK EMBLEM OVERLAYS, BLACK CHROME EXHAUST TIP, TRD LICENSE PLATE FRAME, WINDOW TINT, AND CLIFFORD REMOTE START
PAST: 2015 LTD 4X4 NAUTICAL BLUE 3RD ROW CLIFFORD REMOTE START.
PAST: 2010 SR5 4X4 BLACK
10-10-2018, 03:50 PM
Real Name: Tom
Real Name: Tom
If the lift you are contemplating is compatible with a SR5, it should also be compatible with the Pro setup. Mounts should be identical. FWIW I would leave it stock for a bit as I have heard the Fox setup works really well. Good luck and congrats on the new ride! Post up some pics when you get her, we all like pics!
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
10-10-2018, 05:38 PM
I'm think I just want to do a cornfed spacer lift like others have done on their PRO w/ the Bilstein setup. The Fox set up is different though and not sure if those spacers will work.
10-11-2018, 08:31 PM
I am new to the 4Runner world, but the general consensus is spacers are a waste of time. I have no experience with them but it makes sense..
You have to remove the spring from the strut, why not at least install a lift spring? Dobinson has a taller spring with the same rating for around $200
Just something to think about.
What color did you order??????
10-11-2018, 08:36 PM
wonder how much those fox cost ...kinda interesting
10-11-2018, 08:52 PM
$2k at least but toyota won't sell them.
10-11-2018, 10:55 PM
give it time, camburg, sdhq etc will probably come out with a collar spacer like they have for the raptors.
10-12-2018, 11:50 AM
I don't know how much homework you've done on this, but I'll offer a little from my experience. I just picked up my 2018 Cavalry Blue about 8 wks ago. Went with Cornfed 1.5" in the front and Wheelers T13 coil springs on the rear, which gave 1" of lift. The wheelers was supposed to increase the spring rate, which I wanted as I knew I would be loading it down some. As it sits right now, it's about 1/2" higher in the rear, but with even 100-150lbs in the rear, it sits level to nose high. That said, if I had it to do over, I would have done the same lift on front (1" spacer on front) and rear to keep approx 1" rake. Hope this helps.
10-13-2018, 03:03 PM
I think I saw around $2700
10-13-2018, 03:33 PM
Was that a private sale? Because the new fox suspension is a 2019 trd pro priviledge.
10-13-2018, 03:45 PM
I work at a Toyota store and I think I saw a price in some corporate email about it being around $2700.
This has to be a pretty great suspension system and that's why I want to keep it and add spacers so I can fit 285's. I won't be doing much rock crawling since I live in the midwest and it'll be my daily driver.
10-14-2018, 10:20 PM
2017 SR5 4WD - Blistein 5100s - Cooper AT3s - HID Lows - LED Fogs
2003 SR5 V8 - Sold
10-14-2018, 10:58 PM
Originally Posted by borgzman
Why would you buy a Pro if you plan on messing with the suspension? get an ORP and order an Icon stage 1 or two set up. buy the pro rims and bigger tires of your choice and sell the ORP rims on here or CL. you can install the suspension yourself or pay an org member in beer to do it. While you are installing the suspension, paint the front an rear valances so they dry while you work. TSO is a much cheaper alternative to the pro grill garninsh.
You will be in for less $ and you will have puddle lights and a sun roof... KDSS as well if you choose.
Troner envy... the struggle is real!
10-15-2018, 12:01 AM
Do we have the compressed and extended length of this TRD Pro Fox shocks? Its hard to think of other lift options aside from spacers considering the mounts are the same with other models as mentioned earlier.
Or you can wait for suspension vendors to come up with a compatible lift kit for your TRD Pro Fox.
If I'm on the situation and budget is not an issue, I'll buy ahead a good aftermarket suspension that will give me the amount of lift I want. Take off and sell the fox when it arrives while they're still hot.
2003 SR5 V8 - Sold
10-15-2018, 02:15 AM
You buy a Pro for the color and for the 19's it's the JBL premium sound system that makes it worth it along with the color.
Last: 2016 Trail in Super White
Current: 2018 TRD Pro in Cavalry Blue
Mods: C4 Fabrication sliders, Gobi Rack with ladder, ICON 2.5 CDCV, Total Chaos UCA, Falken AT3W 35/12.5R17 , RCI Gas Tank Skid, Artec Bumper, Victory 4x4 Rear with swingout
Instagram: @Houlds41
