Old 07-24-2019, 10:57 AM #16
Globetrotter78's Avatar
Globetrotter78 Globetrotter78 is offline
Globetrotter78 has a spectacular aura about Globetrotter78 has a spectacular aura about
Originally Posted by Titanpat57 View Post
Welcome..
Thanks, man! I swear I must have read through years and years of builds and banter between you and Antman and countless others on this forum MONTHS before I even bought my truck. They were insightful, inspirational and most assuredly hilarious.
*2018 White SR5 4x4, Icon 2.5 Exten Travel w/ res, JBA High Caster UCAs, 1.25 Spidertraxx, SSO Sliders and Bumper (on route), Icon Rebounds and 285/70 Falken Wildpeak A/Ts
*2013 Maserati GranTurismo Sport
*2013 Fiat 500 Abarth- the rocket powered go-kart!
Globetrotter78 is offline   Reply With QuoteReply With Quote
Old 07-24-2019, 01:22 PM #17
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
The real question is, when are you going to paint over that Maserati logo on the wall and put up the Toyota sombrero?
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 09:53 AM #18
Hahahaha I know, I know. I'm holding out hope that Ill have another Maserati soon enough so for now it stays. The other side is adorned as well so I am running out of wall to decorate...or better yet, need a bigger garage and more cars!!
Globetrotter Build!-fb_img_1535903221313-jpg
Old 07-25-2019, 10:06 AM #19
Yesterday was a VERY exciting day!! My bronze Icon Rebounds came in and were mounted on the 285/70 Falken Wildpeaks! I was considering KO2s like many here but I got an amazing deal on the Falkens that I couldn't ignore. Big thanks to Dixie Fab in Roanoke for pulling the order together and getting everything rolling nicely. With the lift, bumper cut and the 1.25 Spidertraxx already done she clears the 285s will little issue. The front mudflaps were removed but nothing else was required. Slight rub somewhere at full lock reverse but I think a few hits with a grider will sort that out.
I am incredibly pleased and REALLY love color of the rims with the Super White body. The bronze catches the eye and gives a bit of pop color in a world of blacked out wheels. The aggressive tread makes the vehicle LOOK as capable as it really is. I am enjoying the hell out of this rig and cant wait to take her offroad and LEARN how to use her to her full potential!!
#ICONbrandwhore
Globetrotter Build!-20190724_150415-01-jpg  Globetrotter Build!-20190725_091703-jpg  Globetrotter Build!-20190724_150533-01-jpg
Old 07-25-2019, 10:56 AM #20
austinquick austinquick is offline
austinquick is on a distinguished road
Dude! You're jumping right in! I'm digging the pictures too.
austinquick is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 06:14 PM #21
sigepbiker's Avatar
sigepbiker sigepbiker is offline
sigepbiker is on a distinguished road
sigepbiker's Avatar
How much custom work went into mounting the Kickers? Is an amp required for the door speakers or just for your 10" sub?
Originally Posted by Globetrotter78 View Post
I have replaced the interior speakers with Kicker 6.5s all around. I also put 3.5s in the dash though that required more work and creative cutting of the factory frame than I think will be justified. The Kickers were affordable and sound great once amplified. My days of building big money stereo systems are behind me so these will suit me fine. I am in the process of building a fiberglass subwoofer enclosure for a 10" CompR into that right hand rear pocket. I will post pics in a bit.
2016 Trail Premium Tires and sliders and some interior mods...
2005 SR5 Silver mod list
FOR SALE: Rear Diff Breather Fitting; 4th Gen Center Diff Switch w/ pigtails
sigepbiker is offline   Reply With QuoteReply With Quote
Old 07-29-2019, 09:54 AM #22
Replacing the speakers was simple once you have the proper bits in hand. You WILL need THE RIGHT adapters plates since Toyota uses different bolt patterns for every frickin model and year it seems. Dont waste your time on amazon with off brand adapters that say "fits your Toyota 4Runner". Unless its a Metra kit its almost certain to be wrong. Went through ordering 2 of them before giving up and spending a few extra bucks on the Metras. You will also need the plugs to attach to the factory harness (they are cheap). The 3.5" dash speaker required a lot of modification and I would NOT recommend going that route. Just stick to factory size and it too will be a simple install. Once you have the right parts it takes a few minutes per door to install and reassemble.
YOU WILL NEED AN AMP(S)! Cheap paper cone OEM speakers will make sound with very little power but will damage and distort at louder volumes...Stronger aftermarket speakers require more power to move them but are much more capable at higher sound levels. Once you install the kickers (or any aftermarket) you will have to crank the factory headunit almost to max to get an equal level of sound. Once amplified properly however, the Kickers will output much more than the factory and with far better sound quality.
I am planning on getting the TacoTunes.com setup (really impressive kit) since its plug-n-play designed for our vehicles and very compact. Both the 400w 4-channel and the 1000w mono fit on one plate under the passenger seat. I'm too old to have giant flashy amps that are all show. Now I just want them to do the job and take up as little space as possible.
Hope that helps!
Old 07-29-2019, 10:04 AM #23
I'm trying, brother! So far I'm loving it. I have learned that I cant drive this with the same "enthusiasm" I did the Maserati but I am definitely a happy man. I am hoping I can find some local outdoorsy types near me to show me where to go to learn how to use this thing now that she is better equipped.
I am STILL waiting on my SSO rock sliders and I will be getting a bit of armor underneath as soon as I get the all clear from the accountant/wife. lol
Old 07-29-2019, 10:55 AM #24
I could understand that, the 4runner is a little less spirited in that regard haha. I'm trying to convince the accountant/girlfriend of the same thing.
Bummer you're not closer to the west coast!
Old 08-01-2019, 12:29 PM #25
sigepbiker's Avatar
sigepbiker's Avatar
Hope that helps!
Thank you! I saw TacoTunes offers speaker adapters too.
Question on the amp: these both say they're 4-ch, but our 4runners have 6 speakers, two in the rear hatch. Pardon my ignorance, but is 4-channels enough?
Old 08-01-2019, 01:21 PM #26
According to my research the 4Runner runs 4 channels though the 8 speakers(dash has speakers too). Dash and Fronts are combined as 2 channels(L/R respectively), Rear doors and Liftgate are combined as 2 channels(L\R)
This is why its a 4 Channel Amp. The Rears/Gate share the wattage of that channel so some will disable the liftgate speakers so full wattage goes to the doors. Im not a fan of this as the rear speakers are mostly just fill sound anyway and I like music to play through the liftgate when its open while camping or whatever.
Old 08-05-2019, 12:28 PM #27
T8 Headunit!! Yeah yeah I know
Ok, so I did a thing this weekend. I bought a T8 Android headunit from a forum member (PatrickBateman) for a price that I couldn't pass up even if the thing was pure junk. I am happy to report that I am absolutely thrilled with the headunit!!!
There are a plenty of people that had negative experiences with these or scoffed at the hardware limitations. I, however, use my headunit as, well, a headunit. It handles anything I would do (listen to the radio, play Pandora, Bluetooth audio from phone, GPS, and even watch movies). I cant imagine 32Gigs of internal storage plus the ability to feed from the usb another 500Gigs being deemed inadequate for really anyone but whatever. I don't multitask on my headunit beyond audio and GPS and 2Gigs of RAM is more than adequate. I have stored 8Gigs of music and a couple movies just for kicks.
I like that I can change the background wallpaper to that of my choosing and download other apps that might be occasional fun, like TorquePro. This particular frame is matte black which I am also very happy about since I'm not a fan of that painted silver nonsense everywhere.
I do have a few qualms, albeit minor but annoying. I cannot FOR THE LIFE OF ME figure out how to get my music files to play in the default radio player(pink music note)!! Not sure where to save them so they will be viewable by the player. I had to download an app to play them. Secondly, the units do not have an accelerometer so neat functions in Torque like pitch/roll, which would be fun offroad, don't work. Expandable storage via SD card would be nice in lieu of using the USB port. Apparently the mic(internal and external) are junk for voice calls but I never use that function anyway.
I didn't bother taking pics of the install since its very plug and play and well documented already on Trail4Runner.com. Safe to say it was just as easy you've heard. All in all I am completely satisfied with this project, its capabilities and certainly the aesthetic aspects of the new unit.
Globetrotter Build!-headunit1-jpg  Globetrotter Build!-headunit2-jpeg-jpg
Old 08-19-2019, 09:49 AM #28
Well I finally finished the enclosure. I had wrapped it in black felt but it looked cheap and out of place given that it was against grained plastic panels (unlike a car truck that is all carpet stuff). I tried to wrap in auto carpet but it still looked weird. I finally settled on vinyl. Vinyl is much less forgiving to inconsistencies in the surface its on but all in all I am much happier. I also relocated the outlets to the face surface of the panel. The outlets are positioned such that I can build a shelf system at some point without concern.
Like I said, I am well out of practice and would do things a little differently if I were to do it again but overall I'm very pleased. I saved several hundred dollars on a custom box and had a neat project to keep me busy for a bit.
Once I get the go ahead from the wife it will house a monster Alpine R.
**EDIT** Wife gave the OK so here's the final (albeit lousy quality) pic with the sub installed.
Globetrotter Build!-20190818_145132-jpg  Globetrotter Build!-20190818_145326-jpg  Globetrotter Build!-capture-jpg  Globetrotter Build!-sub-jpg
Old 08-27-2019, 04:25 PM #29
Ordered my MOLLE panel from Victory4x4 about 10 days ago and it arrived by UPS yesterday. I love this thing!!! Well build, fast turn around time, and perfect fitment! I swear at BEST this took 20 mins to assemble and mount. The longest part of the process was realizing I didn't like the look of the WHITE spacers so I disassembled and wrapped them in electrical tape for a more discreet look. I cant wait to get all kinds of offroad goodies secured to it since the 4Runners have virtually ZERO storage cubbies.
Highly recommend Victory and they will be getting my business soon again once I get the ok from the wife for the front bumper and skids!! Well done gang.
Globetrotter Build!-20190823_201053-jpg  Globetrotter Build!-20190824_164439-jpg
Old 09-20-2019, 10:21 AM #30
Received my SSO sliders and got them painted and mounted. These things are SERIOUSLY STOUT! I was incredibly pleased with the quality of the build and the overall look of these beasts. They installed quite easily with only myself and the help of a floor jack. Once I unpackaged them I set them up to spray on several coats of truck bedliner since these to don't come powered. Upon inspection I immediately panicked as the identical center mounting plate on one of the sliders looked as though it was welded upside and backwards from the other. It looks like someone seriously f-ed up. In faith, I just sprayed my coats of paint (that stuff is awesome btw) and once cured I lined them along the truck for install. Per some YouTube pointers I found, I balanced the sliders on my floor jack and raised it into place, which worked marvelously. The only steps needed for install were to remove some weird little plastic flap at the rear of the rocker panel and to temporarily unbolt a soft line that runs along the frame. Once lined up they bolted quickly and easily despite my earlier panic about the orientation. I love the look and I am incredibly pleased with my purchase.
The ONLY thing I wish was different is that I wish there was a bit more outward projection of the side tube. As it is now, the step does not extent beyond the bow of the door so no door ding protection plus it gives rather minimal tread space for the front step(toes and ball of foot barely). The rear step is PERFECT so if it was just a bit narrower than that up front I expect it would feel more capable as a step(its secondary role I know). Still that aside, A+ for SSO.
Globetrotter Build!-slider-jpg  Globetrotter Build!-20190915_104136-jpg  Globetrotter Build!-20190920_084149-jpg  Globetrotter Build!-20190920_084159-jpg  Globetrotter Build!-20190920_092506-jpg  Globetrotter Build!-20190920_092640-jpg  Globetrotter Build!-20190920_092527-jpg
guy , guys , maserati , time , truck
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
Snow White build 2006 v8 adventure overland apocalypse build Dubs Chops 4th Gen T4Rs 24 04-25-2014 09:25 AM
FS: '67 M416 trailer with Globetrotter Tent wyorunner For Sale: Non-T4R Items 2 05-09-2013 04:38 AM
