Old 07-22-2019, 08:07 PM #1
SnoRnR's Avatar
SnoRnR SnoRnR is offline
SnoRnR will become famous soon enough
SnoRnR's Avatar
ARB Compressor Bandi Mount Switch under hood
Evening All,
I am finally looking to install a dual ARB compressor. I will be using the Bandi mount with a SMOG relocate (Shockworks, dual battery coming in the future). I have changed my idea and will install the switch under the hood. In the future, I am hoping to install the sponsored by wifey kit.
Could a front locker be powered by the wifey kit?
Also, should I look for a non ARB switch for under the hood?
If this is going to be a hassle I will install in the cab. Although, I also want a switch pro in the future (so will move the switching to this).
Thanks
SnoRnR is offline   Reply With QuoteReply With Quote
Old 07-28-2019, 11:32 PM #2
xmatox xmatox is offline
xmatox is on a distinguished road
I have almost this exact setup, but mine is hooked up to my SPOD. I have the wifey kit. It is only for airing up and down the tires as far as I know and what I use it for. You may be able to run a locker line off the manifold, but I can't say for certain because every hole but one is taken already on the manifold (Maybe different manifold?). Also, the ARB switch under the hood will work just fine unless you want a different switch for your own personal reasons. Ultimately, the switch pro will make it all easier but isn't necessary.
2018 Super White 4Runner ORP - Icon 3" lift, Icon tubular UCA's, Icon rear trackbar - Method NV 305, KO2 285's - SSO Hybrid Front Bumper w/ 20" baja spot/driver combo - Shrockworks rock sliders - SPOD - Offgrid Engineering Dual Battery w/ yellow top - RGB Rock lights - ARB Twin Compressor w/bandi mount - LFD 7/8 Rack - Hi-lift w/mount - Jerry Cans (Fuel) w/ roof rack mount, maxtraxx, plano gun case for extra recovery gear - Cobra CB - Rago Antenna mount - Rago Storage mount - Full ARB Recovery kit - Xenon depot HID - ARB Diff breather - KC Underhood lights - SSO Hybrid front bumper, Smittybuilt winch, Baja designs S8 lightbar, Factor 55 Ultra hook* - Automatic dimming switch mod -
xmatox is offline   Reply With QuoteReply With Quote
Old 07-29-2019, 02:37 AM #3
CF_Machete's Avatar
CF_Machete CF_Machete is offline
CF_Machete has a spectacular aura about CF_Machete has a spectacular aura about
CF_Machete's Avatar
Originally Posted by SnoRnR View Post
Evening All,
Thanks
How will you run your locker if the compressor switch is under the hood? are you going to run a switch in the cabin as well? or stop and pop the hood every time you want them to engage?
For the wifey setup, what kind of terrain do you primarily tackle? I decided against it b/c its mostly mud, soil, and water by me... so I'd get caked in shit when I would use the system. Making a 4 hose system for my needs is just more practical, cheaper and easier... but if you're mostly on rocks/ sand, then its probably a good option.
Troner envy... the struggle is real!
CF_Machete is offline   Reply With QuoteReply With Quote
Old 07-29-2019, 09:16 AM #4
MisplacedTexan's Avatar
MisplacedTexan MisplacedTexan is offline
MisplacedTexan is on a distinguished road
Switch under the hood seems....odd. you can get switches that fit the blank knockouts on the lower dash inside.
And if you are running the ARB compressors they already have a spot on the manifold that is attached to the compressor for the locker solenoids. It's pretty plug and plug.
And the wifey kit is pretty much geared at airing tires up and down. Trying to tie the locker into that system would just complicate the whole thing.
2010 SR5 | ARB | Baja Designs | SCS Ray 10 | Falken Wildpeak 285/70 | Shrockworks | OME | SPC | Blue Sea | Hella Horns
MisplacedTexan is offline   Reply With QuoteReply With Quote
arb , future , hood , install , switch
Gauging Interest: 4th Gen V8 under hood ARB air compressor mount blackoutt 4th Gen T4Rs 22 11-24-2018 12:34 AM
Thank you bandi for the 5th gen ARB compressor mount toppyjai General Discussions 5 04-11-2016 03:10 AM
4th Gen TJM Air Compressor Mount Under Hood Trabs00 4th Gen T4Rs 4 10-18-2015 04:08 PM
