User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 07-23-2019, 05:41 PM #1
tchfall15 tchfall15 is offline
Junior Member
tchfall15 is on a distinguished road
Junior Member
Rear passenger door stuck shut
I followed the door actuator motor repair write up https://www.toyota-4runner.org/5th-gen-t4rs/242540-drivers-door-lock-actuator-motor-repair-[step-step-w-pics-]-7.html?highlight=door+will+-open
I did my driver's door perfect. I did the rear passenger and put everything back together except the interior door panel and my door will not open. Did I not align something correctly? Any way to get the door open?
I hooked the fork like thing around the rod of the actuator. I went from the inside to get the panel as class as possible to hook up the two pull wires for the doorlock and the door handle and the handle from the inside doesn't work. I tried moving the rod and nothing. Any suggestions?
tchfall15 is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 05:59 PM #2
badattitude's Avatar
badattitude badattitude is offline
Member
badattitude will become famous soon enough badattitude will become famous soon enough
Member
Just an idea, have you tried pulling on the metal rods? Try pulling on both, one at a time in both directions. That may release the latch so you can access the inside of the door again at least.
Sorry just re-read, you already tried moving the rod.
__________________
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 06:03 PM #3
Junior Member
Junior Member
yea. Can i put something into the doorjam where the latch is?
Reply
Tags
door , handle , inside , open , rear
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Driver's door is stuck shut lnabbster Problems & Warranty Issues 8 09-25-2020 08:10 PM
Help drivers door stuck shut 2cars4turbos 4th Gen T4Rs 7 08-11-2014 09:47 PM
Rear passenger door is stuck shut.... whitewhale2010 4th Gen T4Rs 10 04-10-2011 10:24 PM
Rear passenger doors freezing shut Aspen 5th gen T4Rs 7 02-13-2010 07:16 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
