Old 08-10-2019, 11:45 PM #1
doxiedad's Avatar
doxiedad doxiedad is offline
Real Name: James
doxiedad is on a distinguished road
doxiedad's Avatar
Real Name: James
When to change front diff oil?
So I changed front/rear/t-case oil on my 2016 4Runner @ 20K miles. She's at 60K miles now. I changed out the rear diff fluid today, Using Mobil 1 Synthetic 75W90 Gear oil again.
Do I need to change the front out as well? I don't get to use 4X4 nearly as much as I'd like.
thanks
2016 SR5 Premium 4x4 Nautical Blue
doxiedad is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 05:10 AM #2
pahaf91 pahaf91 is offline
pahaf91 is on a distinguished road
I would. Its only $12.99 a quart where i am at. I would do Front and Center diff together. Cost is $39 plus tax. Why not have the extra protection?
pahaf91 is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 11:55 AM #3
pointman pointman is offline
Banned
pointman will become famous soon enough pointman will become famous soon enough
Banned
Simple DIY? Simple as a flush and fill?
pointman is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 11:56 AM #4
doxiedad's Avatar
Real Name: James
doxiedad's Avatar
Real Name: James
Yeah pretty simple. I've done it before. Problem is it's August in the South east so hot and humid as hell for a couple more weeks.
May wait till a little cooler weather.
Old 08-11-2019, 11:57 AM #5
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Nope. I changed my front diff and T/C at 48k then at 94k. Should be easily able to do 60k intervals if you don’t do water crossings. Up to you.
1000MPH is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 02:42 PM #6
Yes it is. For the center diff, it's a 24mm plug for drain and fill.
Front diff is a hex key. And you have to remove the front skid plates to get to them. The only issue.
The front and center diff both take about 1.5 quarts.
Old 08-11-2019, 08:20 PM #7
Banned
Banned
Perfect detail. Thank you!
Old 08-12-2019, 08:16 AM #8
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
I get lazier on the front diff than on the T case and the rear. The rear gets nasty by 30K, the T case, well, that's so easy why not do it when doing the rear. The front though, it always comes out perfectly clean so I go a little longer. Same for the wifes ride.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 10:32 AM #9
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
I changed my diffs and TC at around 60k. Rear diff and T-case were dark. The front diff was pretty clean though. I'll probably end up changing all again at around 100k.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 11:52 AM #10
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I agree with this, I like doing my own maintenance. However, on a selectable driveline, you don't need to change the front now. You're in a good spot to drive 30,000 miles, then do both.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 04:27 PM #11
Shingo Shingo is offline
Shingo is on a distinguished road
Had a little whine in the rear diff in my 2018 SR5.
Changed lube at 15k miles using Valvoline synthetic 75w-90 (highest MIL Specs). Really surprised there was almost 1/8" of babbit on magnetic drain plug. Rear end pretty quiet now,.. will do front & transfer case at 30k miles as an insurance policy. Transmission @ 50k miles and will add aftermarket cooler (or earlier if I start to tow).
Good luck!!
Shingo is offline   Reply With QuoteReply With Quote
change , diff , front , miles , oil
Front and Rear Diff fluid change Mijfwb23 5th gen T4Rs 615 07-09-2023 10:27 AM
Which fluids for transfer case, front/rear diff change? hawkcharmer 3rd gen T4Rs 23 02-07-2021 02:40 PM
Change front diff to match the rear gearing Angry_4runner 3rd gen T4Rs 5 02-10-2019 05:40 PM
Front diff gear ratio verification - diff removed and no vehicle info SDmtnbkr 3rd gen T4Rs 6 07-26-2017 09:39 PM
front and rear diff fluid change Tombguardgirl 3rd gen T4Rs 7 06-10-2014 02:51 PM
