Old 07-26-2019, 12:32 AM #1
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
Those with JBL systems - What have you done for direct replacement speakers?
I know there are threads on direct fit speaker upgrades, but they mostly focus on the non JBL systems. Buried in them there may be some comments from those with JBL, but I thought I ask specifically for those with JBL. I have seen a thread with JL Audio 3.5” put in dash with good results.
I am looking into replacing my head unit to a Kenwood Excelon and considering changing the speakers also. But I am not going to add amps and make mods to fit speakers.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 08:45 PM #2
GunRock0811 GunRock0811 is offline
Real Name: Sam
GunRock0811 is on a distinguished road
Real Name: Sam
I just did the tweeter/dash replacement in my 2010 LE (JBL equipped) yesterday. It was badly needed!
I used the JL Audio C2-350x (3.5in) speakers. They sound incredible!
You’re going to have to chop the factory adaptor off and crimp standard speaker connectors on in order to complete the install. The adaptors I’ve seen online are focused on the door speakers and will not work on the tweeters (I didn’t know that when I bought them).
The front passenger side speaker area is too small to make a decent bracket, I used zip ties and it seems to work fine.
The non-JBL wiring setup is made so the front door speakers are run off of the tweeters, that is not the case with JBL.
GunRock0811 is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 08:52 PM #3
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
I'm not sure what ther complaint is here with JBL system.
I have a Kenwood deck installed, replaced the 8in sub with a Kicker shallow mount and a small amp to drive it. The rest of the system is stock speakers and JBL OEM amp and sounds just fine.
Kenwood has a interesting component set:
Kenwood Excelon KFC-XP6902C 6"x9" component speaker system designed for select Chevrolet, Dodge, GMC, and Toyota vehicles at Crutchfield
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 10:06 PM #4
matoolie's Avatar
matoolie's Avatar
Did you notice drastic improvement with change in head unit only? I will be changing my head unit and thought to upgrade the OEM dash and door speakers at same time for more improvement. Maybe the OEM sub while still using the OEM amp. I am not going to install aftermarket amp and run wiring. Those days are over for me. Not looking for killer system, just improvement with a change in headunit.
Michael
Old 07-26-2019, 10:25 PM #5
rushrunner rushrunner is offline
rushrunner will become famous soon enough rushrunner will become famous soon enough
Nothing. No need for perfect sound because you will have all windows open, especially the back window.
Past:1991 Lumina Euro 3.1, 1994 Cutlass SL 3.4, 1999 Intrigue GL, 2003 CTS, 2006 Saab 97x, 2009 4Runner SE (should of never traded it in), 2012 SRX, 2015 Charger Rallye. Current: Mine: 2018 4Runner Limited (glad to be back), Wife's: 2020 4Runner Limited (glad she finally joined the club).
rushrunner is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 10:32 PM #6
matoolie's Avatar
matoolie's Avatar
Lol. True. Use the back window everyday this time of year to bleed off the heat of summer when getting in.
Michael
Old 07-26-2019, 10:38 PM #7
Sorry, I did it all at once. The dash speakers are different from non JBL speakers though. Used Maestro RR module to integrate into OEM amplifier.
Old 07-26-2019, 11:04 PM #8
Bclark69120 Bclark69120 is offline
Bclark69120 is on a distinguished road
LE Speaker replacement
I replaced my dash and front door speakers with a Memphis Audio Component Set. Tweeters in the dash, 6x9 in the doors. I also sound matted the front doors at the same time. Replaced the stock Sub with a shallow mount Pioneer and a dedicated amp for the sub with the knob control mounted in my dash. I have been very pleased with these additions and the only other thing I might add is to replace and sound mat the rear doors. Only thing to note with replacing any stock speakers is that the stock speakers are like 2.3 ohm so when you replace them with 4 ohm speakers, it takes a little more volume to get the sound to where I want it.
Bclark69120 is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 05:04 PM #9
marcelor73 marcelor73 is offline
marcelor73 is on a distinguished road
Those are 4 ohm speakers and the factory ones are 2 ohm. Did you notice a significant decrease in volume?
Thanks!
marcelor73 is offline   Reply With QuoteReply With Quote
direct , fit , jbl , speakers , systems
Direct replacement switches Swimmerboy2112 3rd gen T4Rs 13 04-05-2020 12:04 PM
Direct fit Speakers Cree 3rd gen T4Rs 1 01-26-2019 06:25 PM
which pioneer speakers are the best direct fit replacement currently? floatingkiwi 3rd gen T4Rs 11 02-15-2017 05:05 PM
Best Foglight Bulb Direct Replacement? CO4x499 4th Gen T4Rs 1 03-01-2015 03:24 PM
Speakers different 2011 to 2012 (in 8 speaker systems)? H2O_Doc 5th gen T4Rs 25 04-14-2012 08:48 PM
