Old 11-17-2019, 01:35 AM #46
zonzin's Avatar
zonzin zonzin is offline
zonzin has a spectacular aura about zonzin has a spectacular aura about
zonzin's Avatar
Originally Posted by KP Texan View Post
Now on to my 3D printed 3.5" dash speaker mount project!
How is that project going? Can't wait to see what you come up with.
zonzin is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 11:05 AM #47
KP Texan KP Texan is offline
KP Texan has a spectacular aura about KP Texan has a spectacular aura about
Actually just pulled the dash speakers this weekend, and started working on the design! I'll either start a new thread or post about it in the dash speaker thread/my stereo build thread when I'm done. I'm just hesitant to post un-tested prototypes because I don't want people to waste their time on something that doesn't work/fit.
I've also got to complete the build of my Prusa i3 MK3s and enclosure so I can start printing on my own! It arrived on Friday so I'm pretty excited about it.
2012 Limited, 4WD, Classic Silver Metallic
2018 TRD ORP - Sold
2006 Sport Edition - Sold
KP Texan is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 12:11 AM #48
nerfkhat nerfkhat is offline
nerfkhat is on a distinguished road
I just installed a kenwood as well. Would you sell one of them ? I would like to move my mic up to that oe location too.
nerfkhat is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 10:05 AM #49
Given that my 3D printer isn't set up yet, the easiest thing is to probably e-mail the .stl file over to a local UPS store that does 3D printing (Looks like there is one in Denver: 3D Printing Service Locations | The UPS Store ). They print in ABS as well, so that's ideal here. I got a quote from my local UPS store and it was $6 - pricey for the amount of material, but not too bad since it's such a small part. They were also able to do it within a day. I would honestly have a hard time beating that price if I were to charge you for material only and then pay to ship it to you!
2018 TRD ORP - Sold
Old 11-18-2019, 10:33 AM #50
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
This forum would implode with all the lost revenue in sponsorship selling that $6 part here.
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 12:34 PM #51
zonzin's Avatar
zonzin's Avatar
Actually just pulled the dash speakers this weekend, and started working on the design! ...
Followup question, the STL file has 2 builds for the part, which do I use?
Old 11-18-2019, 12:58 PM #52
There should be two different stl file versions (r5 and r7) on Thingiverse, each with a single part. Are you seeing more than one part in one of those files?
r7 is for if you can pass the connector end of the mic through the mount first (mic goes in from the bottom). I recommend r7 if possible.
On r5, the mic enters through the top, and you don't have to put the cable through first. On this design, the mic fit is pretty tight on purpose since the Kenwood mic has a taper which makes fitment difficult. The mic holding tabs are also prone to breakage on this one if you aren't careful.
2018 TRD ORP - Sold
Old 11-19-2019, 12:45 AM #53
Was looking at my r7 stl and something seemed a bit off - somehow one of the tabs that locks the mount into the overhead console was off by 1mm. It's fixed now on Thingiverse, but I'm sorry if some of you already printed it. I really don't think it would make a difference since I'm pretty sure I printed that same file and installed it myself! It would also be a very easy fix with a jewelers file if you already printed it and it caused an issue. I'm just a bit OCD so I wanted to make sure it was correct.
2018 TRD ORP - Sold
Old 12-30-2019, 11:06 AM #54
8S6RUNNER 8S6RUNNER is offline
8S6RUNNER is on a distinguished road
Originally Posted by matoolie View Post
@KP Texan ..... thanks for work and the file! My local library printed the mount this week for $0.40. The mount fit perfectly. Those of you who have the SOS button in the console should leave the OEM microphone plugged in as unplugging it will result in the red LED next to the SOS button staying on anytime the truck is running as I found it. I just zip tied the OEM microphone to wiring harness And left it plugged in.
Hey, any possibility you can get one for me and ill pay you? thanks in advance
8S6RUNNER is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 01:31 PM #55
Freight_Dawg Freight_Dawg is offline
Freight_Dawg is on a distinguished road
Anybody having issues with the microphone sound? Everybody I call tells me I sound like I am talking thru a walkie talkie or there's an echo. Tried adjusting the mic position inside the overhead console since I have a similar 3d mount, also adjusted few settings on the kenwood head unit but no luck. I am about to replace the mic with a new one.
Freight_Dawg is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 11:39 AM #56
Would some one be able to 3d print me a microphone mount? i really dont have anyone or any place that can do it for me. i tried a place but they were talking about $150 which its crazy! much appreciated. obviously i will pay cost of printing and shipping.
Old 02-21-2020, 02:05 PM #57
zonzin's Avatar
zonzin's Avatar
What I ended up doing was using 3/16th ABS sheet and cutting out a rectangle at the inside dimensions of the place where the factory mic mounts and then drilling a 1/2" hole in it for the Pioneer mic. Used a bit of ABS glue to set the piece in the factory spot and a bit of glue to insert the mic into the hole. Came out perfect, cost next to nothing and took about 20 minutes.
Old 03-08-2020, 11:48 PM #58
dsanford dsanford is offline
dsanford will become famous soon enough
I wonder if anyone has attempted this for a 4th Gen 4Runner. If anyone has, can someone point me in that direction?
dsanford is offline   Reply With QuoteReply With Quote
Old 12-18-2020, 03:02 PM #59
MadeInMaine's Avatar
MadeInMaine MadeInMaine is offline
Real Name: Owen
MadeInMaine will become famous soon enough
Real Name: Owen
Don’t mean to drag up an old thread.....
But
1. I live in Alaska, not many 3D printing options available here. Can I zelle or Venmo someone some cash to print and toss one in the mail for me?
2. Does anyone have a link to instructions/pictures on how to remove the ceiling console to access the back so I can install this?
Thanks guys
Owen
2016 Magnetic Gray SR5 premium 4x4
- Toytec Boss lift, C4Fab LoPro w/ Baja light bar and Smitybilt winch, Baja SpyUtil rack, SwitchPro to control my lights, REDARC Tow Pro elite brake controller, VTX rims, KO2 rubber, T9 head unit, 4.56 gear upgrade
- Turtleback Trailer
https://www.toyota-4runner.org/5th-g...ut-surely.html
MadeInMaine is offline   Reply With QuoteReply With Quote
Old 12-18-2020, 03:28 PM #60
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
I don't know cost, but there are many print-and-ship services online
3D Printing Service | Order Custom 3D Prints Online | 3D Hubs
3D Printing Service | Shapeways
etc.
llDemonll is offline   Reply With QuoteReply With Quote
console , factory , fitted , hold , mic
Installing aftermarket head unit- utilize JBL or use head unit amp nytosc 4th Gen T4Rs 3 07-10-2017 08:43 PM
aftermarket head unit TheCremePuff 4th Gen T4Rs 1 10-11-2016 02:42 PM
Help with Aftermarket Head Unit BlueRidgeRunner 4th Gen T4Rs 0 10-10-2015 09:41 AM
Aftermarket Head Unit? JamesWhite Engines / Suspension / Wheels / Tires / Audio / Accessories 1 02-12-2014 02:55 PM
