Old 09-11-2019, 10:07 PM #1
Ykket Ykket is offline
Real Name: Russ
Ykket is on a distinguished road
Real Name: Russ
Question What material to make a platform from?
Hey folks,
I am looking to make a platform to mount a fuse block, relays, etc. What is a good material to use that is heat resistant and a can be used for something like this? I was trying to find some sort of plastic but haven't had luck figuring it out yet.
Thanks
Ykket is offline   Reply With QuoteReply With Quote
Old 09-11-2019, 11:57 PM #2
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
Powdercoated aluminum or steel
llDemonll is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 08:39 AM #3
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
you could use ABS sheet assuming it's not crazy hot, the thickness you need would depend on the size and what you're mounting to it but it's all pretty cheap
or if you want to get fancy the perforated metal used inside electrical cabinets to mount everything
jhguth is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 09:56 AM #4
mscot mscot is offline
mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light
Antman used a cutting board. Check his build thread.
Build thread
mscot is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 10:31 AM #5
SlickTRD SlickTRD is offline
SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about
HDPE plastic
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
SlickTRD is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 11:26 AM #6
Real Name: Russ
Real Name: Russ
Thanks guys. I saw Antmans thread and really liked that idea and was thinking of doing something similar. I currently have a Slee ARB mount with a single compressor. I am looking to make a platform that goes over the stock fuse box and on the free space of the mount, basically an L shape. I would mount everything so it could be disconnected easily to access the stock fuse box. I made a cardboard template that fits pretty good and have an idea for the mounting. The temperature under the hood is what worries me with certain materials.
I'll take a look at all the suggestions, I appreciate the information.
Thanks
Old 09-12-2019, 11:38 AM #7
mbumpus11's Avatar
mbumpus11 mbumpus11 is offline
Real Name: Bump
mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about
mbumpus11's Avatar
Real Name: Bump
I followed Antman's lead and used a cutting board as well. Zero issues and it has been many months through the Texas Summer.
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
mbumpus11 is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 01:07 PM #8
Real Name: Russ
Real Name: Russ
That's what I like to hear, what kind of cutting board did you use?
Old 09-12-2019, 01:20 PM #9
boyguan boyguan is offline
boyguan is on a distinguished road
abs sheet. tap plastics is located in many places and can cut for you. you can also heat and bend with just a heat gun
boyguan is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 01:27 PM #10
plastic cutting boards are made from HDPE because it is stable and food safe.
Old 09-12-2019, 01:34 PM #11
kso818 kso818 is offline
kso818 is on a distinguished road
Order a piece of HDPE off amazon.
IG: ksotrdpro
2015 Inferno Red TRD Pro | Piaa Platinum LED Headlights | Shrockworks Dual Battery Relocator | National Luna Dual Battery Kit | Optima Yellow Top | SPOD SE | ARB Air Compressor | Rago MSP | Expedition Essentials T4RPAM | C4 Fab Rock Sliders | C4 Fab Dual Swing Rear Bumper | Frontrunner Slimline II Rack | KC C-Series Lightbar | Cooper Discoverer STT Pro 285/70/17 | Dobinson C59-701V | Fox 2.5 Shocks with Remote Resi and DSC | ProComp 2.25" Front Spacer
kso818 is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 04:33 PM #12
mbumpus11's Avatar
Real Name: Bump
mbumpus11's Avatar
Real Name: Bump
Literally went to Walmart and bought the small $0.89 cutting board.
A little thinner than most would like with a little bit of flex, but you can see how I installed it in my build thread, and it is rock solid. Easy to custom shape with a jigsaw as well!
Post link: https://www.toyota-4runner.org/3287213-post49.html
Old 09-12-2019, 04:45 PM #13
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Get a sheet of 1/4 inch aluminum. You can cut it with a band saw or jig saw. Or by hand. Clean up the edges with a file, smooth with sandpaper. Paint it or not. Don’t use plastic. Yuk.
Old 09-12-2019, 07:53 PM #14
Godfr33 Godfr33 is offline
Godfr33 is on a distinguished road
Marine Starboard. Color options galore
Godfr33 is offline   Reply With QuoteReply With Quote
find , make , material , platform , sort
FS: 4th gen storage platform + fold-out sleeping platform (Boston, MA) xxaarraa For Sale: T4R Items 18 05-15-2019 10:32 AM
OEM pad material? niz55 4th Gen T4Rs 1 04-20-2019 11:09 PM
What is the best material to use for a sleeping platform?? martin.1991911 Off-Roading 8 05-01-2013 10:34 AM
Anyone know the name of this material? MeBe4running 5th gen T4Rs 17 04-23-2012 03:07 PM
What platform was used to make this site? Daron-t4r General Discussions 2 10-03-2011 11:14 PM
