Old 07-30-2019, 09:21 PM #16
osideplayer osideplayer is offline
osideplayer will become famous soon enough osideplayer will become famous soon enough
Originally Posted by T4R_KAI View Post
If you have money for Kings, go with them. Hands down.
Can I adjust Kings to 2 in the front and 1 in the rear?
My budget is 2500 for parts
osideplayer is offline   Reply With QuoteReply With Quote
Old 07-30-2019, 10:47 PM #17
That'll take the entire budget. you can adjust the fronts to 2". the rear will require a coil spring or a spacer to get 1" of lift. But nothing rides like a king.
eibach kit is what 1k? and that's for everything you need. Leftover for wheels.
Old 07-31-2019, 12:31 AM #18
So I think I am going to go with Kings in the front and 5160s in the rear
Old 07-31-2019, 12:43 AM #19
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Hmm correct me if I'm wrong but would it be less comfortable to match a linear shock to a digressive rear? Possible to just save up for a full kings set?
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 09:16 AM #20
Toffees's Avatar
Toffees Toffees is offline
Real Name: Micah
Toffees will become famous soon enough Toffees will become famous soon enough
Toffees's Avatar
Real Name: Micah
$2,500 budget for parts isn't small. Will a King OEM set get the job done or are these not adjustable in that range?
Toffees is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 09:55 AM #21
From what I’ve read they can be.
Old 07-31-2019, 10:07 AM #22
csommers's Avatar
csommers csommers is offline
csommers will become famous soon enough
csommers's Avatar
+1 for Dobinsons.
2500 will be enough for suspension, UCAs, and install (this will vary, but you might even end up with some of that money left over).
2018 Nautical Blue TRDORP w/KDSS, Dobinsons(F:302/700,R:723/705), Camburg UCA
csommers is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 01:21 PM #23
So I was going to get the TRD pro fox suspension. Then realized I could get something way better for 2500
Old 07-31-2019, 01:34 PM #24
ManhstuhT4R ManhstuhT4R is offline
ManhstuhT4R is on a distinguished road
Sent you a pm sir let me know what I can help with!
ManhstuhT4R is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 04:38 PM #25
tacoyota tacoyota is offline
tacoyota is on a distinguished road
5100s up front and daystar in the rear. Rides better than stock! My next upgrade down the line will be kings with custom valving.
2017 TRDORP White | 275 KO2 on Stock Rims | Stock Stereo with JBL GX302/GTO638/938, Kenwood KSC-SW11 | DDM 35W HID Ultra | Shrockworks Step Sliders | FR 5100s @1.75 RR Daystar 1.5 | Victory 4x4 Rack
tacoyota is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 06:11 PM #26
Globetrotter78's Avatar
Globetrotter78 Globetrotter78 is offline
Globetrotter78 has a spectacular aura about Globetrotter78 has a spectacular aura about
I just recently bought a Icon 2.5 Coilovers w/Reservoir, Icon 2.0 Rear Shocks, JBA UCAs(beautiful), and Dobinsons rear springs. Its a very solid system and should fall within budget or very close!
*DONT PAY SOMEONE TO INSTALL! The install can be done in your garage VERY EASILY will basic automotive tools and a few hours time. An extra set of hands is needed for the UCA install but the rest can be done by you alone if necessary. Take your time and enjoy turning the wrenches yourself.
The everyday driver lift-20190630_202703-jpg  The everyday driver lift-20190706_094202-jpg
*2018 White SR5 4x4, Icon 2.5 Exten Travel w/ res, JBA High Caster UCAs, 1.25 Spidertraxx, SSO Sliders and Bumper (on route), Icon Rebounds and 285/70 Falken Wildpeak A/Ts
*2013 Maserati GranTurismo Sport
*2013 Fiat 500 Abarth- the rocket powered go-kart!
Globetrotter78 is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 08:48 PM #27
Id definitely not do 5160's. Go Fox 2.0 remote resi or just the normal 2.0.
I still vote for Eibach or a 6112 setup.
Old 08-02-2019, 10:25 AM #28
been some reports of premature leaking on 5160s. might as well go fox king icon 2.0s.
Old 08-02-2019, 12:30 PM #29
DavidR1's Avatar
DavidR1 DavidR1 is offline
DavidR1 will become famous soon enough
DavidR1's Avatar
With a 6112 front what would you suggest for the rear in place of the 5160?
The 6112/5160 seems to pair quite well.
Also, the 6112 description states it is designed for an additional 15-200 lbs added to the front. How well does this ride without additional weight in the front?
DavidR1 is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 03:47 PM #30
like i said, fox 2.0. It is a killer shock for the price.
Rides fantastic with zero extra weight up front.
don’t , easy , inch , lift , rear
3rd gen on dirt everyday cstmg8 3rd gen T4Rs 5 10-02-2018 10:45 AM
You Learn Something Everyday ajspagna 3rd gen T4Rs 7 12-26-2010 11:01 PM
you don't see this everyday mistaj0hnny 3rd gen T4Rs 14 07-16-2010 06:54 PM
What's in your pockets everyday? 97RunnerSR5 Off Topic 29 02-27-2010 01:38 PM
do lift kits prevent damage for everyday drivers??? shakey1378 4th Gen T4Rs 10 02-20-2004 09:11 PM
