Old 07-31-2019, 11:41 AM #16
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
One of my former vehicles had an oil pressure sensor that turned off the fuel pump with low/no pressure. Too bad it's not a standard item on all.
Too many stories like this.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 12:05 PM #17
gp55445's Avatar
gp55445 gp55445 is offline
gp55445 is on a distinguished road
gp55445's Avatar
That is really bad. After the dealer cross threaded my skid plate after the oil change I started doing my own.
gp55445 is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 02:43 PM #18
jimmied jimmied is offline
jimmied is on a distinguished road
This same dealership that forgot to replace his drain bolt, sold me my 2016. I changed the oil right away and found 2 cross threaded bolts that refused to give and heads gave way. Only serviced at Price so it goes to show this dealer service department is often not doing the right thing. I will add the the buying process was great though.
Current - 2016 Mag Gray SR5, 3rows - diode dynamics fogs, tint, FalkenAT3W, blacked out badges, more to come
Old - 2008 Black sr5 v6 - Bilstein 5100s, FJ rears, black counter steers, xenon depot h11 hid kit, Scion Radio upgrade (touchscreen), BHLM, tint, Cooper AT3s.
jimmied is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 09:13 PM #19
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Originally Posted by whitetiger View Post
Went to my local Toyota dealership today for a oil change during my break. On my way home from work, started to hear an odd noise in the cabin.
I'd say the minimum you want is an extended warranty on the engine. Maximum you want is a new engine.
It's likely from the sound you recorded that the hydraulic lash adjusters de-pressurized. Best case is no damage, worst case is cam lobe and/or rocker arm damage plus bearings at the crank mains and rod journals. If they're damaged, metal (iron, chromium, aluminum, lead) will usually show up in used oil analysis and be at higher levels than baseline.
Blackstone Labs, NAPA are both reputable oil analysis services in the ~$25 range.
waypoint is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 01:57 AM #20
whitetiger whitetiger is offline
whitetiger is on a distinguished road
Originally Posted by jsun_2k View Post
no warning light up?
As I was driving, no. When I pulled over and turned it off/on, then only did the oil light come on.
whitetiger is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 02:28 AM #21
Thanks waypoint for the input. I will be sitting down with the GM tomorrow to review the documentation they have prepared. I’m not fully mechanically incline so your suggestions of possible damages is greatly appreciated I will make sure that this is discussed in the documentation.
I had a brief phone call with him today. I mentioned if they did an oil analysis which they said no and do not do. After hearing that, I asked to meet in person as them assuring me no damage was done went out the window.
Do you recommend any other test to perform for documentation purposes? I have the kit from Blackstone Labs being mailed so I will make sure an oil analyst gets done.
Old 08-01-2019, 06:42 AM #22
waypoint's Avatar
waypoint's Avatar
Other than any new audible engine noise, used oil analysis is your only useful diagnostic.
In your meeting, I'd push for the extended warranty on the engine.
If the meeting doesn't go well I'd contact Toyota corporate and open a complaint. This will document the defective work leading to the oil leak, engine noise, and oil pressure warning light...those 3 are your only actual issues at this point. If you later find additional problems such as new engine noise and/or abnormal wear metals in the used oil analysis, these data points support your original complaint and provide a cause of action.
It's very likely that the engine incurred no damage from this, and there will be no further issue. You'll just need to increase your diligence for the next few oil changes via lab analysis, and be listening for ticking/knocking noises that weren't there previously.
Old 08-01-2019, 09:25 AM #23
WNY PAT WNY PAT is offline
WNY PAT is on a distinguished road
Did you call or email Blackstone Labs? The guys there are super responsive and super knowledgeable, and if you haven’t yet, I would contact them before your meeting with the GM. Ask them what intervals they would recommend at this point to monitor for any possible engine damage. Once you inform them of this, I’m sure they will not only personalize your OA write up but provide specific guidance for the frequency and duration of the tests. Then you can ask the GM to foot the bill for the tests and for (what I am assuming will be) more frequent oil changes for awhile. Blackstone has been around a long time and I’m sure they’ve dealt with this before. I’m really curious as to what the findings will be. If you’re willing, please post the OA results here someplace. Fingers crossed for you!
2018 4R SR5 Premium Package Faux Pro Clone (Stolen By The Kids)
2013 Lexus LX570 (Wife’s New Mall Crawler)
2017 Tundra Crewmax Limited TRD (Mine)
WNY PAT is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 09:40 AM #24
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
I cringe when I hear stories like this especially since I've got one more complimentary oil change through the dealership..makes me not even want to use it..
Regardless of what happens with the dealership, I'd still lodge a complaint with Toyota corp, just to get it on record. They can put a lot more pressure on the dealer.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 12:38 PM #25
CavPro's Avatar
CavPro CavPro is offline
CavPro has a spectacular aura about CavPro has a spectacular aura about CavPro has a spectacular aura about
CavPro's Avatar
Do you have any idea how much oil was lost? Did the oil still register on the dipstick? How far did you travel before you discovered the leak? Of the videos you shot and posted, which one was recorded first? You don't need to post up the answers here if you don't want to but you better be ready to answer those Q's at some point. If you didn't get any of this before the dealer got their hands on it, well, good luck.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
CavPro is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 12:55 PM #26
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
Given the nature of the **** up, I'd ask for extended warranty on the engine that covers it up to 120K miles. Heck, I'd even push for lifetime warranty on the engine. Argument is that it's a 4runner and the engines should last foreeeeeeeever if properly maintained. So, they should warranty it up to a reasonable point where they expect the engine to at least live to.
If the engine doesn't die, nothing comes out of their pocket. If they are 100% sure that no damage has occurred, imo, they should have no issue giving you the extended warranty.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
the_fornicator is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 02:39 PM #27
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Another example of why I do all my own maintenance.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 03:07 PM #28
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Most important thing right now is getting everything documented to a T. They ****ed up big.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 04:01 PM #29
fubarovich fubarovich is offline
fubarovich is on a distinguished road
skip the free maintenance offer?
So after reading posts like this one (sorry for your trouble OP), do I even bother with the free maintenance that comes with my new 4runner ORP? Current vehicle mileage is 2k and I'm going to do the first oil change myself at 2.5k but was then hoping to use the free dealer changes starting at 10k.
fubarovich is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 04:07 PM #30
rb92673 rb92673 is offline
rb92673 is on a distinguished road
If the low oil pressure light did not come on, then there was oil pressure withing factory specifications while it was running. If it was me, I would change the oil again after 5,000 miles and send a sample to Blackstone to verify wear is similar to other 4Runners.
rb92673 is offline   Reply With QuoteReply With Quote
dealership , home , leaking , oil , toyota
What should I do - dealer botched oil change DanD General Discussions 34 05-12-2019 04:02 PM
Left Front Axle Leaking. Replace at dealer? Lolaya 4th Gen T4Rs 24 01-27-2019 07:27 PM
Dealer oil change left the cap off desch 5th gen T4Rs 11 01-01-2014 06:07 PM
Leaking valve cover gasket and dealer response rra640 4th Gen T4Rs 5 04-02-2009 11:59 PM
Dealer oil change at only 1000miles KMX3060 Problems & Warranty Issues 25 10-11-2005 10:40 PM
