Old 08-04-2019, 11:43 AM #16
teotwaki's Avatar
teotwaki teotwaki is offline
teotwaki is a jewel in the rough teotwaki is a jewel in the rough teotwaki is a jewel in the rough
teotwaki's Avatar
Good job!
Jim _ My Adventure Blog:http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
teotwaki is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 12:41 AM #17
Whoknows's Avatar
Whoknows Whoknows is offline
Whoknows will become famous soon enough
Whoknows's Avatar
Similar clunk feel (more than sound) on very small bumps only at very slow speed. Started after install of King coil overs and SPC upper control arms about a month ago. I’ve been hoping it would settle out. I’ve suspected its bolt on UCA, but haven’t yet tried tightening it.
19 TRD ORP w/KDSS
Super White
Whoknows is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 08:42 AM #18
93civEJ1's Avatar
93civEJ1 93civEJ1 is offline
93civEJ1 is on a distinguished road
93civEJ1's Avatar
glad yours was figured out. I went out to look at my same sway bar drop to check mine. Mine looks all ok, so I dont believe that is my issue on mine. Time to keep going at the drawing board.
93civEJ1 is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 12:33 PM #19
ScarfaceT4R's Avatar
ScarfaceT4R ScarfaceT4R is offline
Real Name: Christoph
ScarfaceT4R will become famous soon enough
I'm kind of shocked that the "nutsert"/inner-threading within the frame even has the ability to break free from the frame. I mean it holds the damn sway bar onto the vehicle... Smh
Now I'm going to be paranoid of it working itself loose again.
But now that people who read this knows that the bracket has the ability to be the cause of a clunk issue, hopefully it'll help out someone else out there.
3" lift up front courtesy of 5100 Billys & Toytec HD coils + top hat spacers, 5160 Billys in rear w/ Toytec Superflex 2" coils, front Wheelers bumpstops/2" rear Toytec bumpstop drop, TRD Pro skid, Icon UCA's, Pelfreybilt sliders, HID's & LED's galore, full MBRP Catback, K&N CAI, Fuel Tactic 17x9's -12mm , 285/70/17 Cooper STT Pros, Total Chaos BMC kit, etc..etc..blah, blah
ScarfaceT4R is offline   Reply With QuoteReply With Quote
Old 08-06-2019, 08:37 PM #20
Tj900 Tj900 is offline
Tj900 is on a distinguished road
@scarface - looks like you have spacers between your sway and frame. Wondering if that is recommended. I put on a level kit on the front to raise 2" and did not use a sway spacer. Wonder if I should add? I have KDSS - it was a serious pain reconnecting the sway on the front.
Tj900 is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 10:33 PM #21
black bnr32 black bnr32 is offline
black bnr32 is on a distinguished road
bump for future searchers (non-KDSS application)
Mine was also sway bar bushings. It sounded just like bad struts or worn end links. The bushings looked perfect and everything was tight. However, if you unhook one end link and give the bar a good push/pull, you can feel the bar moving back and forth. I think this is what caused my clunk. During removal, I noticed the inner face of the bushing was indented/crushed a slight amount. Just enough to cause a ~1/8" gap between the bushing and the axial stops on the sway bar. I flipped the bushings around 180 degrees. Flipping the bushing removed this gap and the clunk. This stuff isn't visible without skid plate removal.
Now just to find some darn bushings, which seem rarer that unicorn tears for some damn reason.
black bnr32 is offline   Reply With QuoteReply With Quote
Old 11-17-2022, 03:15 PM #22
Dat1trd Dat1trd is offline
Dat1trd is on a distinguished road
Ever figure out your issue? I too get a slight knock(feel) from driver side. I can manually turn my wheel left to right (the amount you get with truck off and ignition off) and hear/feel knocking noise. I can put my hand over the upper control arm and turn the wheel left to right and feel the knocking on control arm. I re torqued everything upper cross bolt and spherical bolt(total chaos uppers) and still get noise. Alignment shop did a "diagnostic" although I didn't ask for one and said it was my wheel bearing (they wanted $860 to replace a long with alignment), after alignment I went picked up a new wheel bearing and replaced it even though the stock one looked and seemed fine and still getting that slightly knock. I too recently installed king coilovers and upper Total chaos arms about a month ago. I'm stumped 🤔
Dat1trd is offline   Reply With QuoteReply With Quote
Old 11-17-2022, 04:04 PM #23
Captain Planet's Avatar
Captain Planet Captain Planet is offline
Captain Planet will become famous soon enough
Makes sure the LCA alignment bolts are torqued to spec. They might look tight, but i've had this cause issues before of the alignment tech didn't do it. The spec is pretty tight.
Captain Planet is offline   Reply With QuoteReply With Quote
Old 03-09-2023, 03:21 PM #24
I ended up figuring out my issue. It was the spherical bearing on total chaos upper control arm. Only had about 4k miles on them since new. I removed it and everything looked good minus a small strand of the Teflon peeling out. But it still seemed firm and stuff. As soon as I installed new bearing, noise went completely away. Fast forward 700miles and noise is back. I mentioned this to Total chaos and he told me that it's normal, that I have to put about 5,000 mi on them to break them in which seems kind of odd. I removed it and it looks good as new, no slop or play. So I'm just going to rock with it for now and see if it goes away but seems like it's part of the cons when running aftermarket parts 😆
clunk/knock , front , pass , side , sound
Question about Troubleshooting knock / clunk over bumps - Jivewalker 5th gen T4Rs 10 03-15-2019 09:41 PM
Steering clunk... clunk over hard bumps kruegs 3rd gen T4Rs 30 12-12-2017 03:50 PM
Front End Clunk Over Bumps? Brake Caliper? BRUIN8124 4th Gen T4Rs 19 09-07-2017 08:54 PM
clunk going over bumps on drivers side front freshley 3rd gen T4Rs 3 07-27-2012 04:18 PM
[WTB] 4th Gen Front Bumper/Pass. Side Fender bigburch422 Classifieds - buy & sell (no commercial ads please) 1 05-03-2011 01:15 PM
