Old 08-01-2019, 12:31 PM #1
ScarfaceT4R's Avatar
ScarfaceT4R ScarfaceT4R is offline
Real Name: Christoph
ScarfaceT4R will become famous soon enough
Clunk/knock front pass side over bumps - SOLVED!!
Hey there fellow T4R'ers,
Just noticed a pretty gnarly knocking/clunking type sound coming from front pass side when going over anything even remotely close to being a bump. I diagnosed it coming from the front pass side by standing on my slidders and rocking the rig pretty aggresively (gotta say, just another advantage to having those slidders) - & it only happens on the pass side when standing & rocking that side.
After jacking up my 4R & checking all components + searching other related threads - I'm hoping it could be 1 of 2 things. Either my UCA's need a serious amount of greasing (although would the UCA needing grease cause a 'knocking' sound? Or would that be more of a creak/squeek ). OR could this be due to my new sway bar bushing with a little gap in it?? I don't see how the bushing would cause such a knocking sound either though because it's super snug in the bracket & loaded with fresh grease.
These bushings are the 29mm polyurethane bushings by Whiteline (the ones that are recomended for our 5th gens). I don't really want to go back to the OEM ones, but I guess I can do that to help diagnose this issue & see if the clunk goes away. BUT what other size (in mm's) would I get for this sway bar because I want the poly ones?? Anyones else go 30mm, 31mm, 32mm, etc...?? Here's a pic of the gap for reference:
Thanks!!!
*EDIT: this pic was the driver side sway bar bracket. If only I would have concentrated on the passenger side to begin with....
Clunk/knock front pass side over bumps - SOLVED!!-bushings3_50-jpg
3" lift up front courtesy of 5100 Billys & Toytec HD coils + top hat spacers, 5160 Billys in rear w/ Toytec Superflex 2" coils, front Wheelers bumpstops/2" rear Toytec bumpstop drop, TRD Pro skid, Icon UCA's, Pelfreybilt sliders, HID's & LED's galore, full MBRP Catback, K&N CAI, Fuel Tactic 17x9's -12mm , 285/70/17 Cooper STT Pros, Total Chaos BMC kit, etc..etc..blah, blah
ScarfaceT4R is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 12:33 PM #2
Gecko's Avatar
Gecko Gecko is offline
Gecko is a jewel in the rough Gecko is a jewel in the rough Gecko is a jewel in the rough
Gecko's Avatar
It seems like there has been an influx of these "front end knocking/squeaking/popping" threads popping up lately, my own included.
Not sure what's going.
2021 Lexus GX 460 Luxury , Atomic Silver/Black @LandCruiserDNA
Previous: 1999, 2016 and 2019 4Runners
Gecko is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 12:41 PM #3
Do you have aftermarket UCA's, or sway bar bushings by chance?
Old 08-01-2019, 01:00 PM #4
halflife78's Avatar
halflife78 halflife78 is offline
halflife78 will become famous soon enough
halflife78's Avatar
Add me to this list also post lift install.
2016 TRD Pro: C4 Rock Sliders | Victory 4x4 Roof Rack | Ellis Precision Shifters | Blackvue 650s 2 CH | Full Front Clearbra | 20% Tint | Beavertail | Borla S-Type | Pedal Commander | Tail as Turn | DRL LED Foglights | ArcLight Triple State Voltage Booster | Victory 4x4 Front Winch Bumper | Victory 4x4 Front Skid | TRD CAI | SCS Stealth 6 | Dobinsons Lift & UCA | Warn Zeon 10s | Northstar 31m | Factor55 Flat Link | ARCLightLED Hatch/Map/Dome Lights | Lock'er Down Console Safe | XD Door Light / License Plate Bulbs
halflife78 is offline   Reply With QuoteReply With Quote
Old 08-01-2019, 01:10 PM #5
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Double check your UCA mounting bolt - the long one that goes through both bushings. Mine seems to work its way loose about once a year. I don't know why that's the case, but it does. And it makes a slight clunk when it's loose. I really should put a double nut on it with some loctite.
One other area I've found to clunk is the front engine skid plate. If one of the bolts isn't tight it will shift a bit and make a similar sound.
Otherwise I'd just check all the other mounting nuts and bolts to make sure they're tight.
good luck
Old 08-01-2019, 01:39 PM #6
good luck
I will DEFINITELY check that long UCA bolt as I can see that being a potential clunk area. Do you happen to remember torque spec & nut size?
Seems more like the case rather than the skid plate just because the sounds is specific to the pass side only
Old 08-01-2019, 02:15 PM #7
Jetboy's Avatar
Jetboy's Avatar
I don't remember the size or torque. You can't fit a torque wrench in there IIRC. I just go by feel and what the rubber bushings look like. I'd bet it's something like 70 lb/ft. But that's just a guess.
Old 08-01-2019, 04:07 PM #8
93civEJ1's Avatar
93civEJ1 93civEJ1 is offline
93civEJ1 is on a distinguished road
93civEJ1's Avatar
Following this...I picked up my T4R Limited with a Toytect boss on it. I thought it was the XREAS lines that were left on unattached smacking around causing the noise, but I took those out and my clunk on that pass side is still there. I have SPC UCA also. Ive not found anything else loose that I have smacked around on so far.
93civEJ1 is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 01:51 AM #9
Louisiana Overland's Avatar
Louisiana Overland Louisiana Overland is offline
Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough
That long bolt in uca will knock when reversing and braking...more so than going over bumps. Mine worked loose on passenger side. It was a bi-otch getting a torque wrench on it but we did after sdding loctite. If i remember right it was like 125 ft lb?
Louisiana Overland is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 06:44 AM #10
ryan87 ryan87 is offline
ryan87 is on a distinguished road
if you've had a recent alignment i would check lower control arm bolts. i chased a noise on mine for a long time
2012 TE
ryan87 is offline   Reply With QuoteReply With Quote
Old 08-03-2019, 12:20 PM #11
93civEJ1's Avatar
93civEJ1's Avatar
the long bolt that goes through the upper control arm...should the metal washers be completely flat against the mounts? I have SPC uppers, and there is a gap on all of mine...so I have a feeling it should maybe be that way?
Old 08-03-2019, 03:58 PM #12
YouTube
Link to vid I took of the clunk for comparison to everyone else's. I have literally checked the torque on every component mentioned and everything is fine. driving me nuts...
Old 08-03-2019, 10:40 PM #13
teotwaki's Avatar
teotwaki teotwaki is offline
teotwaki is just really nice teotwaki is just really nice teotwaki is just really nice teotwaki is just really nice
teotwaki's Avatar
YouTube
Thanks for the video! Is it possible that the swaybar is hitting the skid plate?
Is it possible the end of the swaybar or the end link is hitting the coil of the coilover?
Jim _ My Adventure Blog:http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
teotwaki is offline   Reply With QuoteReply With Quote
Old 08-03-2019, 11:36 PM #14
mrblah's Avatar
mrblah mrblah is online now
mrblah's Avatar
Can u get another set of eyes to look down there?
mrblah is online now   Reply With QuoteReply With Quote
Old 08-03-2019, 11:58 PM #15
Problem found!!
So I believe this may be a one off issue...
Sway bar def doesn't hit the skid & the sway bar is good & away from the coil & links due to the sway bar relocation kit. BUT that relocation kit was the problem!! After removing the wheel to inspect tie rod ends thinking that could be the prob...nope, thing was super tight and has a lot of life in it - when (super frustrated) about to put the wheel back on, I noticed the spacer used to relocate the sway bar had a little gap at one end & I could even see the bolt in between the frame & spacer!!
*I have circled this in blue in the picture below.
After removing the skid to get to the sway bar bracket/relocation kit easier, I noticed that the problem bolt wasn't tight at all. In fact, while trying to remove it - it would not even spin out!! Turns out the threaded "nut" within the frame broke out of its tacweld or whatever Toyota uses to secure it. I had to pry off the frame plug (also shown in the second picture where the relocation kit/bracket is now fixed) - & stick my finger in the frame to secure the loose nut to get a solid torque on it. Now that it's tight I'm wondering just how long it's going to last BUT it seems super tight now & I made sure to lather it in red loctite.
The clunk is now completely 100% gone . But for how long... Even closed up a little bit of the gap I have on that polyurethane sway bar bushing. For anyone paying attention, I ordered the 29mm bushing as recommended by Whiteline. Measured the sway bar today with my new digital caliper & it reads 30.5mm. Not going to stress the gap for now.
Oh, and R.I.P. frame plug...
Clunk/knock front pass side over bumps - SOLVED!!-broken-jpg  Clunk/knock front pass side over bumps - SOLVED!!-fixed-jpg
clunk/knock , front , pass , side , sound
Question about Troubleshooting knock / clunk over bumps - Jivewalker 5th gen T4Rs 10 03-15-2019 09:41 PM
Steering clunk... clunk over hard bumps kruegs 3rd gen T4Rs 30 12-12-2017 03:50 PM
Front End Clunk Over Bumps? Brake Caliper? BRUIN8124 4th Gen T4Rs 19 09-07-2017 08:54 PM
clunk going over bumps on drivers side front freshley 3rd gen T4Rs 3 07-27-2012 04:18 PM
[WTB] 4th Gen Front Bumper/Pass. Side Fender bigburch422 Classifieds - buy & sell (no commercial ads please) 1 05-03-2011 01:15 PM
