Old 08-02-2019, 10:10 AM #1
xcalbr2 xcalbr2 is offline
xcalbr2 will become famous soon enough
A lil help... perfect alignment but pulls right
Happy Friday to all!
Looking for a bit of help or suggestions. I have a 2012 Limited with Eibach lift, JBA HighCaster uca's, level8 rims and Falken AT3s.
It was lifted in Jan and was fine until recently.
I have had it aligned twice at two different shops now and alignment is good.
However, it pulls right when you let off the accelerator.
I have checked the front brakes (removed pads and rotors and cleaned everything up and put back with new pins and springs). Dealer replaced drivers side wheel bearing over 2 months ago but pass side is original.
No play/noise from CV axles etc...
Edit: Front tires are NEW and have been swapped side to side and pull remains to right when let off accel.
Any ideas?
Thanks
X
xcalbr2 is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 11:54 AM #2
T4R_KAI's Avatar
T4R_KAI T4R_KAI is offline
Real Name: Josh
T4R_KAI will become famous soon enough
T4R_KAI's Avatar
Real Name: Josh
Drainage gradient typically slopes to the right for all roads.
2017 TRD Off-Road -- Dobinsons 3/2 Lift w/ Camburg UCAs, Method 701s, Falken Wildpeaks AT3W, SSO Roof Rack, Xenon HID Low / LED High, Cali Raised LED, N-Fab Nerfs, Pro Grill
T4R_KAI is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 11:58 AM #3
ScarfaceT4R's Avatar
ScarfaceT4R ScarfaceT4R is offline
Real Name: Christoph
ScarfaceT4R will become famous soon enough
^This.
*Especially in Missouri where there's actually rain/water.
Unlike...
3" lift up front courtesy of 5100 Billys & Toytec HD coils + top hat spacers, 5160 Billys in rear w/ Toytec Superflex 2" coils, front Wheelers bumpstops/2" rear Toytec bumpstop drop, TRD Pro skid, Icon UCA's, Pelfreybilt sliders, HID's & LED's galore, full MBRP Catback, K&N CAI, Fuel Tactic 17x9's -12mm , 285/70/17 Cooper STT Pros, Total Chaos BMC kit, etc..etc..blah, blah
ScarfaceT4R is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 12:08 PM #4
I understand the crown of the road etc.
What I dont understand is it drives straight as long as you are on the go pedal.
If let off (coasting) it very noticeably pulls to the right.
Braking has no effect/pull.
Note this is a limited AWD model
Thanks
Old 08-02-2019, 06:05 PM #5
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
There is a torque reaction ON throttle......it is probably just enough to cancel the crown effect. On my locked truck it is very pronounced and I can actually ''steer'' the truck with throttle application!
83Mule is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 07:12 PM #6
gbarr gbarr is offline
gbarr is on a distinguished road
Check out the Lexus GX460 site. There are a number of folks on that site who have had to dial in a few more degrees of caster to one side, I don't remember if the added caster is to the driver side or the passenger side. You might check with the service dept at Sterling McCall Lexus in Houston Texas as they do this a lot on the GX460 to correct this exact problem you are having. I know I know it might take some talking with a REAL alignment shop To have this done, but whatever works right.
gbarr is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 07:18 PM #7
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Originally Posted by gbarr View Post
might take some talking with a REAL alignment shop To have this done, .
Those are becoming harder and harder to find every day... I got a great guy; You can have a conversion with him about what ur experiencing and their experience translates directly into what and where to adjust.
I go out of my way to give him business.
Old 08-04-2019, 03:04 PM #8
Gbar- thank you. I am fine with talking with anyone about anything so not a problem there. Hard part is to get someone to actually listen and not just know what you need to fix the issue you think you have.
Bumbo- mind sharing the guys/ shops name?
Thanks.
Weird thing is no one can get me more than 3.9 caster with the JBA UCAs now. Something has changed.
Would having old wheel bearings on pass side and new on driers cause something like this?
Or a dragging back brake?
I don’t remember it pulling right with normal alignment prior except for radial pull which I had with two bad Wildpeaks on front.
Thanks all
Old 08-04-2019, 08:14 PM #9
83Mule's Avatar
83Mule's Avatar
I had mine aligned at 4wheel parts and it was set to 3.9 on one side and 4.2 on the other I believe........call them and see.
Old 08-07-2019, 11:06 AM #10
Anyone around St. Louis area have a good alignment shop/guy to recommend?
Also a top notch Toyota dealer while your at it.
Thanks
X
Old 08-07-2019, 12:15 PM #11
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
check your LCA bushings. ive had issues with pulling right under accel and pulling left under hard decel since installing a lift on my limited. have had numerous alignments, both from dealer and a good shop from a tech who is a member here, so its not that. i've also nitced that its pretty easy to knock my car out of alignment too. I think the UCA bushings are the culprith as mine have significant lateral play when turning lock to lock at a standstill. I occasionally get a pop noise under load when turning sharply at low speed too. Getting them looked at by the dealer over the weekend to see if i can get the LCAs covered under warranty. If not, ill prob be ordering a set of dirt king LCAs. hoping that helps solve my steering wobble/vibration too.
tm965 is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 01:05 PM #12
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Does it behave the same if you lock the center diff?
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 08-07-2019, 02:14 PM #13
I have not tried that (limited awd) but will tonight.
How does one check the lca bushings?
Thanks
Old 08-07-2019, 04:30 PM #14
samwhich's Avatar
samwhich samwhich is offline
samwhich has a spectacular aura about samwhich has a spectacular aura about
samwhich's Avatar
Usually a really experienced alignment guy will slightly tweak the toe on the passenger side to avoid road crown drift rather than just go strictly on spec numbers.
Even if not done I wouldn't think it would be as noticeable as what you are describing.
| - 2016 Turd Bro - |
SSO Slimline / x20 | Dobinsons 314/327 - Airlift 1000 | Gobi Stealth Rack W/ Ladder | Dobinsons Snorkel | All Pro Sliders | Shrockworks Rear Bumper | 285 BFG KO2
samwhich is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 09:52 AM #15
LCA's
So do these look ok? Seemed to have some play if manipulated with pry bar.
A lil help... perfect alignment but pulls right-1-jpg  A lil help... perfect alignment but pulls right-11-jpg  A lil help... perfect alignment but pulls right-10-jpg  A lil help... perfect alignment but pulls right-9-jpg  A lil help... perfect alignment but pulls right-8-jpg  A lil help... perfect alignment but pulls right-7-jpg  A lil help... perfect alignment but pulls right-6-jpg  A lil help... perfect alignment but pulls right-5-jpg
alignment , back , pulls , side , springs
Got an alignment and it still pulls both ways?? tjhaf2007 4th Gen T4Rs 14 10-06-2014 08:43 PM
pulls to the right when in 4WD DRVNGENTHUSIAST 3rd gen T4Rs 24 02-13-2014 09:07 PM
4WD pulls Runge17 Classic T4Rs 4 09-14-2011 02:59 AM
how do u act when a cop pulls up next to you t4r4life Off Topic 42 02-14-2010 01:44 AM
4runner pulls to the right hulk311 General Discussions 2 08-08-2008 11:02 AM
