Old 10-16-2019, 09:50 PM #1
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
Plastic Oil filter housing replacement
Mods, please move if you think a different section is better.
Been doing a lot of reading on the site lately, and it seems like there's a split between "the OEM plastic housing is fine" vs "you should replace that plastic with the metal one"
So far I haven't seen any compelling reason to get the metal housing. Just one report of a plastic one cracking, but it was the result of a dealership tech overtorquing. Other than that, no issues. And after all it IS protected by a skid plate.
So to ask -- for those that have gone metal, what was your reasoning behind the change? If I am missing the "cracked housing" thread, point me to it
Appreciate any and all perspective.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 10:02 PM #2
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
Just buy a new OEM plastic housing every 2-3 years whether good or bad and dont make it a project of research.
Old 10-16-2019, 10:15 PM #3
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
Also ill rather have the plastic housing break during install or removal instead of the other piece it screws onto. Kinda like a FUSE.
Old 10-16-2019, 10:36 PM #4
gp55445's Avatar
gp55445 gp55445 is offline
gp55445 is on a distinguished road
gp55445's Avatar
I replaced with metal because it’s metal, I change my own oil, and like metal vs plastic.
gp55445 is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 11:31 PM #5
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
I changed mine to metal because I was worried about the plastic cracking. I unfortunately got mine at NAPA so it wasn't Toyota approved. It leaked. I put the plastic one back on and don't intend on changing it to metal unless it cracks.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 10-17-2019, 12:07 AM #6
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Mine cracked from the dealer not using the proper tool. So I went metal Plastic Oil filter housing replacement
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 09:01 AM #7
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough
Real Name: Jason
My experience - not with Toyota.
I had an Audi prior to my 4R and it was equipped with a plastic oil filter housing as well. It took 11 years and over 130k miles before developing a slight leak, which was either the housing gasket or warping of the housing itself (common). At that point, I swapped with another OEM unit and moved on.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 09:11 AM #8
ProfessorP's Avatar
ProfessorP ProfessorP is offline
ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough
ProfessorP's Avatar
I went with a Toyota factory metal filter housing on my 2009 Tundra and really hated it. Torqued to spec, it would seize up by the next oil change. Removing it was a real pain in the a$$! Almost felt like it was welded shut sometimes.
My paranoia about a plastic part cracking or leaking lead to creating a guaranteed problem for myself at each oil change. Nothing worse than a bored, OCD car or truck forum member looking for a solution to an issue that hasn’t yet occurred.
I’m sticking with the factory plastic housing on my T4R.
ProfessorP is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 09:37 AM #9
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
Right after I bought my 4R I read all the threads about metal versus plastic..I'm sure there's a reason why Toyota used plastic, cheaper would be my guess..Regardless, I'm sure the plastic units will last a long long time so it boils down to preference. For me, I preferred the metal, so new housing that I'll switch to when I start doing my own oil changes.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 09:58 AM #10
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Honestly, just because I like metal better than plastic. I'm sure the plastic would have functioned fine.
I put anti seize on the aluminum threads. Next oil change will be the first time I remove the metal canister.
You guys have me wanting to put the plastic one back in
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 10:21 AM #11
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Metal is used by Toyota in cars without skid plates such as Camry where it prevents road damage if something is to hit that housing. 4Runner has skid plate and therefore there is no need for reinforced oil filter housing and plastic one is used (it is not cheaper to buy, it's is just cheaper to produce meaning it makes more financial sense to Toyota). I replaced my with aluminum alloy for many reasons such as softer plastic always gets stuck in the filter cup wrench, plastic (any plastic) gets dry and brittle as it ages and many more I wouldn't bore you with technical reasons and specs. Keep stock plastic and all will be fine. Metal is just an upgrade and will yield little of benefit to most here.
<<<< is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 10:38 AM #12
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
No reason to replace something that isn't broken.
I bought a new plastic housing some years back - stuffed away in a closet.
My money says the breakage is most likely to occur during removal/installation. Dealers are closed on Sunday + none in my area stock this part - special order.
If and when it breaks - I'm ready.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 10:49 AM #13
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
I used to live in the desert.
I drove the piss out of my 2010 2.3 ranger in 120 plus weather ac cranked max during 5 HOT SUMMERS. My ranger now has over 250k miles im original owner. Plastic intake manifold never cracked, still has original off the assembly line plastic thermostat housing leak proof and crack proof. Only thing im changing next is the plastic oil filler cap just because.
Most possible chance of damage is during install and removal.
Old 10-17-2019, 10:52 AM #14
spartacus's Avatar
spartacus's Avatar
Its not difficult but never the less a complex oil draining procedure and the first time I did the oil change I was reluctant to tighten the plastic housing to 18 ft lbs torque. Métal over plastic is my preference when offroading although plastic might be perfectly adequate.
Old 10-17-2019, 11:01 AM #15
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
BobsTrail is offline   Reply With QuoteReply With Quote
housing , metal , overtorquing , plastic , tech
Seat belt buckle housing plastic Disassembly 949r6 5th gen T4Rs 0 01-03-2018 02:09 AM
Broken plastic housing on remote key ALTAHLC 4th Gen T4Rs 9 08-04-2017 08:57 PM
WTB: 3rd Gen Air Filter Housing Run 4 Fun Want to Buy/Trade 6 02-26-2016 02:51 PM
Metal indicator tab on plastic oil filter housing; toyslug 5th gen T4Rs 7 07-09-2012 11:00 AM
Plastic rear heater housing grey Hogan Classifieds - buy & sell (no commercial ads please) 0 11-30-2003 09:18 PM
