Old 08-04-2019, 02:53 PM #1
Dr. Monkeypants Dr. Monkeypants is offline
Real Name: I didn't go to Monkey Medical School for 8 years to be called Mr. Monkeypants
Dr. Monkeypants is a jewel in the rough Dr. Monkeypants is a jewel in the rough Dr. Monkeypants is a jewel in the rough
Clean rear dashcam mount
I can’t recall who, but one of the forum members made a sweet plexi or polycarb bracket to mount his rear BlackVue camera to. I liked it but thought a v2.0 could clean the whole thing up and hide the wire better so it wasn’t coming out from the weather stripping.
As usual with my goofy, quick mods, I got out the rivet nuts and decided to figure the rest out later...
I put an M4 nut in the spot the left plastic roof liner clip goes then designed & printed a bracket that had a wire clearance groove and would hold the cam as flush as possible to the roof liner. I ended up making it a bit too flush so I added a couple washers notched to clear the wire. It’s plenty rigid enough but should give if it gets a good whack.
I’ll send the file if anyone wants, but it’s sized for a Blackvue camera. I can also update the file and send a printable version for any camera mount if you send me the dimensions.
Josh
2019 Nightshade with a little custom stuff
Dr. Monkeypants is offline   Reply With QuoteReply With Quote
Old 08-04-2019, 03:35 PM #2
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
that looks great, right now I just have a single channel dashcam but I'm saving this for when I have a rear camera.
jhguth is offline   Reply With QuoteReply With Quote
Old 08-04-2019, 03:45 PM #3
Thanks! Here’s a couple shots with better perspective:
Old 08-04-2019, 03:46 PM #4
sfall sfall is offline
sfall is on a distinguished road
could you use a right angle usb cable to reduce or eliminate the cable loop?
sfall is offline   Reply With QuoteReply With Quote
Old 08-04-2019, 04:53 PM #5
d.hamstr d.hamstr is offline
d.hamstr is on a distinguished road
Blackvues use a coaxial cable for connecting the front & rear and don't sell a 90º to 90º. BUT I did notice that they labeled Front DOES have a 90º and would wonder if you can swap ends... or at the very least re-sleeving the Rear end for a 90º.
Coaxial Cable | BlackVue
d.hamstr is offline   Reply With QuoteReply With Quote
Old 08-04-2019, 05:55 PM #6
even easier use a coaxial 90 degree fitting
Old 08-04-2019, 09:57 PM #7
I checked the cable in both orientations before picking the straight side for the cable loop. I didn’t like how tight the bend would have been with the 90° fitting. The reinforcement was almost to the roof liner, making it more of a kink than a bend.
This may be the less compact of the two, but the cable will be happier long term with the larger bend radius, and the 90° looks better in the front anyway.
Old 08-04-2019, 09:59 PM #8
I think it’s a proprietary fitting. It’s not a full size coaxial like a modem uses.
Old 08-05-2019, 09:12 AM #9
it's not proprietary, it's RG-174 cable with MCX connectors
Old 08-05-2019, 12:47 PM #10
lossgenius lossgenius is offline
lossgenius is on a distinguished road
Josh,
What size bolt did you use to mount it?
Thanks
lossgenius is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 02:35 PM #11
Originally Posted by lossgenius View Post
Josh,
Thanks
I used a flat head M4x16 but a #8 would probably also be fine if you’re not down with metric Clean rear dashcam mount
Old 08-05-2019, 02:53 PM #12
Ok, BlackCamBracket(TM) v1.1 is a thing
Increased the neck height to there’s no need for washers and it has 2.2° of angle so the camera is axially level when mounted.
New hotness on the left. Old-n-busted on the right.
Old 08-05-2019, 04:35 PM #13
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
Want to give us all a link to the part file when you're done so we can print (or have printed) our own?
llDemonll is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 04:59 PM #14
pookguy pookguy is offline
pookguy will become famous soon enough
Interested in this...haven't installed my rear thinkware cam yet till I found a good way!
pookguy is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 07:10 PM #15
DarkPassenger's Avatar
DarkPassenger DarkPassenger is offline
DarkPassenger is on a distinguished road
I like that a lot. I just used a hanger bolt threaded in the universal camera mount / tripod size. I didn't have the courage to remove the headliner to feed the power cord underneath, though. I routed mine in the weather stripping.
It looks as though your headliner survived just fine. Any issues with looseness or wonky clips? I'm guessing you've removed them a few times as you've developed new mounts, and from what I can see, the headliner isn't cranky about it.
Thanks!
DarkPassenger is offline   Reply With QuoteReply With Quote
blackvue , camera , mount , send , wire
My new dashcam scanny 5th gen T4Rs 41 06-01-2018 05:38 PM
1993 SR5 4runner $1200 great body/clean leather interior clean title builder project zidaro For Sale: Vehicles 2 02-06-2015 03:09 PM
Keeping the rear window clean.... Help! MadeInMaine 5th gen T4Rs 25 12-15-2014 05:57 PM
Rear-facing aux lights - Outside mount or inside mount? Nashvegas34 3rd gen T4Rs 1 02-21-2012 08:14 PM
For Sale = 2004 SR5 4Runner 2WD, clean, Clean, CLEAN... w/ maintenance records... 4runDiZZLe Classifieds - buy & sell (no commercial ads please) 1 01-19-2010 03:53 AM
