Old 08-05-2019, 07:24 PM #16
Soneill's Avatar
Soneill Soneill is offline
Soneill will become famous soon enough
Soneill's Avatar
This is the plexiglass mount I made for mine. Works like I charm.
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
Soneill is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 08:42 PM #17
Dr. Monkeypants Dr. Monkeypants is offline
Real Name: I didn't go to Monkey Medical School for 8 years to be called Mr. Monkeypants
Dr. Monkeypants is a jewel in the rough Dr. Monkeypants is a jewel in the rough Dr. Monkeypants is a jewel in the rough
Originally Posted by DarkPassenger View Post
I like that a lot. I just used a hanger bolt threaded in the universal camera mount / tripod size. I didn't have the courage to remove the headliner to feed the power cord underneath, though. I routed mine in the weather stripping.
It looks as though your headliner survived just fine. Any issues with looseness or wonky clips? I'm guessing you've removed them a few times as you've developed new mounts, and from what I can see, the headliner isn't cranky about it.
I like your solution. Nice and simple.
Yeah, the headliners can be pretty sensitive. You can flex them a little bit before they get angry and permanently crease. Just to be extra careful, I pulled all three pins, the coat hooks, and the plastic panels away from it before carefully prying it down. They go back in place just fine if you're conscientious. It's a fair bit of extra work, but I'm hyper anal retentive about tucking wires.
The fortunate thing is the holes in the headliner for the plastic pins are the same diameter as the M4 rivnut flange, and I designed the post of the bracket to fit inside that diameter as well. Ends up being very little messing with it aside from pushing the cable through, which wasn't really too challenging once it was loose.
Cheers!
2019 Nightshade with a little custom stuff
Dr. Monkeypants is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 08:47 PM #18
Originally Posted by llDemonll View Post
Want to give us all a link to the part file when you're done so we can print (or have printed) our own?
Sure! PM me your email and the dimensions you want and I'll send you an STL file
Josh
Old 12-22-2019, 02:39 PM #19
BigCountryT4R's Avatar
BigCountryT4R BigCountryT4R is offline
BigCountryT4R will become famous soon enough
Anyone want to make me one and send it to me? I don't have a 3d printer. Willing to pay!
2019 4Runner Limited in Magnetic Gray Metallic, w/Redwood Interior, and 3rd row. Mods: Lastfit 7440/7443 Led Blinkers | JDM ASTAR LEDs throughout the interior and backup/license plate bulbs | OEM Tundra LED Fog Lights | Morimoto Elite HID 5500k 35w | Xenon Depot Led Pro 9005 w/LED Driver for DRL / XPLORE OFFROAD USA Flag rear windows | Adams Polishes UV Ceramic Paint coating
BigCountryT4R is offline   Reply With QuoteReply With Quote
Old 12-22-2019, 05:22 PM #20
CasperS CasperS is offline
CasperS is on a distinguished road
That is an elegant and simple solution, nicely done!
Originally Posted by Dr. Monkeypants View Post
I can’t recall who, but one of the forum members made a sweet plexi or polycarb bracket to mount his rear BlackVue camera to. I liked it but thought a v2.0 could clean the whole thing up and hide the wire better so it wasn’t coming out from the weather stripping.
As usual with my goofy, quick mods, I got out the rivet nuts and decided to figure the rest out later...
I put an M4 nut in the spot the left plastic roof liner clip goes then designed & printed a bracket that had a wire clearance groove and would hold the cam as flush as possible to the roof liner. I ended up making it a bit too flush so I added a couple washers notched to clear the wire. It’s plenty rigid enough but should give if it gets a good whack.
I’ll send the file if anyone wants, but it’s sized for a Blackvue camera. I can also update the file and send a printable version for any camera mount if you send me the dimensions.
Josh
CasperS is offline   Reply With QuoteReply With Quote
Old 12-23-2019, 01:18 AM #21
Snacks Snacks is offline
Snacks is on a distinguished road
Same here. I would GLADLY pay someone for a similar mount. I just had a Thinkware U1000 installed and looking for a clean way to mount the rear camera.
Snacks is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 06:24 PM #22
Waepek Waepek is offline
Waepek is on a distinguished road
I 2nd this @Dr. Monkeypants
Waepek is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 06:58 PM #23
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
I just screwed in the mount that came with camera. Made it a little tight to slide the camera onto the mount, but it’s solid.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 03-01-2020, 10:10 PM #24
SparkySparks83 SparkySparks83 is offline
SparkySparks83 is on a distinguished road
Made a little bracket to mount mine up high and close to the window.
Sent from my SM-N976V using Tapatalk
SparkySparks83 is offline   Reply With QuoteReply With Quote
Old 03-13-2020, 10:05 AM #25
aceee aceee is offline
aceee is on a distinguished road
Originally Posted by 9runner View Post
if you don't want to touch the trim and mount the rear camera from the side then you can use something like this
5th Gen 2014+ 4Runner Rear Facing Dash Camera Mount | eBay
i like the concept but my goodness does that look horrible. I just used a plain money clip, slide it onto my headliner and double sided taped the dash cam mount onto it. looks just as good as these custom mounts people are making.
aceee is offline   Reply With QuoteReply With Quote
Old 03-13-2020, 08:04 PM #26
Mello03's Avatar
Mello03 Mello03 is offline
Mello03 is on a distinguished road
Mello03's Avatar
OP make a few and I’ll buy one for sure. Mine’s clean, but not that clean.
2020 Nautical Blue ORP ADS suspension, Icon Deltas, FN Pro wheels, Ridge Grapplers, CBI skids....
Mello03 is offline   Reply With QuoteReply With Quote
Old 03-19-2020, 08:29 AM #27
Anonymous4Runner Anonymous4Runner is offline
Anonymous4Runner is on a distinguished road
Alright fella...time to show a pic of this plain money clip used to help mount the rear cam. Just curious to see how it looks compared to other mounts already mentioned in this thread!
Anonymous4Runner is offline   Reply With QuoteReply With Quote
Old 03-19-2020, 10:43 AM #28
Big Daddy K's Avatar
Big Daddy K Big Daddy K is offline
Real Name: Kevin
Big Daddy K will become famous soon enough Big Daddy K will become famous soon enough
Real Name: Kevin
Double sided tape here in AZ generally doesn't survive the summer. Had more than one phone mount fail in the past.
I want a rear view camera that can work as a replacement for the mirror. I have a great view of my spare tire, and while I'm okay with it my wife complains every time she drives the 4Runner. Keeps her from driving it I suppose, but sometimes it needs to happen.
2016 Trail Edition Supa Dupa White
Dobinson's IMS lift, SPC UCAs, 285/70R17 Yokohama X-AT tires on Icon Rebound wheels, RCI Sliders and Skid Plates, Prinsu full length rack, C4 Fabrication rear bumper and fuel tank skid, and BPF molle panels.
Big Daddy K is offline   Reply With QuoteReply With Quote
Old 03-19-2020, 11:19 AM #29
The clips i had weren't wide enough for the base of the mount for my cam so i actually just stuck two money clips side by side. cheap solution and not noticeable. cut/trim the clips as you wish for a more minimalist look but i just left them as is. (**EDIT** i dont know why my pics always uplaod sideways)
Clean rear dashcam mount-img_8567-jpg  Clean rear dashcam mount-img_8566-jpg
Old 03-19-2020, 07:00 PM #30
Looks great! definitely can have a sleek look at the end like you said. Been looking for a solution so I can have an excuse to get the Blackvue 2Chan system of some sort, not really seeing any benefits going with the Cloud compatible cameras myself. BTW You can select options on the photo uploaded onto the website and click on rotate. Afterwards, the picture should be rotated to your liking!
blackvue , camera , mount , send , wire
My new dashcam scanny 5th gen T4Rs 41 06-01-2018 05:38 PM
1993 SR5 4runner $1200 great body/clean leather interior clean title builder project zidaro For Sale: Vehicles 2 02-06-2015 03:09 PM
Keeping the rear window clean.... Help! MadeInMaine 5th gen T4Rs 25 12-15-2014 05:57 PM
Rear-facing aux lights - Outside mount or inside mount? Nashvegas34 3rd gen T4Rs 1 02-21-2012 08:14 PM
For Sale = 2004 SR5 4Runner 2WD, clean, Clean, CLEAN... w/ maintenance records... 4runDiZZLe Classifieds - buy & sell (no commercial ads please) 1 01-19-2010 03:53 AM
