Old 10-02-2019, 11:19 AM #31
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
Update
Been paying extra close attention to when I feel the "shudder" trying to see if I'm able to get it to do it at will by modulating the throttle between 40 and 50 MPH..what I'm noticing is that even when I lift off the throttle between that speed I can sometimes feel it..This leads me to believe maybe it's a tire issue, possibly in the rear, because I don't feel any sort of vibration or shake in the steering wheel.
'18 SR5 4WD, magnetic gray metallic, stock
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 10-02-2019, 11:57 AM #32
JPL's Avatar
JPL JPL is offline
JPL is on a distinguished road
JPL JPL is offline
JPL's Avatar
Found this:
How to Fix a Transmission Shudder | It Still Runs
Also I tried this with my older 4Runner, it worked for about 2 months, then the problem cane back:
https://www.amazon.com/Lubegard-1961.../dp/B0002JMLQU
19T4RTRDOR4X4NY
JPL is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 10:59 AM #33
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Just got back from the dealership. Finally, feel like I may have some answers. The tech took my 4R for a lengthy test drive (about 15 miles). Varied driving, including highway (up to 80), stop and go traffic and cruising between 40 and 50 (where I notice the problem). He wasn't able to get it to replicate the "shudder".
Couple of things he mentioned, first is the way the tranny locks up. He said the lock-up pattern has changed (for fuel economy reasons) and that can actually happen at any speed. When the lock-up occurs that might be when I notice the shudder. He also said, depending on the type of car I previously owned that it might seem more noticeable. He also said that the way the power is transferred from the engine to the transfer case can feel like there is play in it..I call BS on that..I've driven plenty of 4wd vehicles and play in the driveline is not even remotely close to a shudder.
Another thing he noticed was that I was driving with the Hum device plugged into my OB2. He suggested the Hum might potentially be causing interference with the CAN-BUS because it's constantly communicating back and forth with the controllers in the vehicle that provide diagnostics. It seems plausible, so I unplugged the Hum device and will see whether that makes a difference.
Old 10-07-2019, 11:06 AM #34
JPL's Avatar
JPL JPL is offline
JPL JPL is offline
JPL's Avatar
Then wouldn't everyone have that?
Another thing he noticed was that I was driving with the Hum device plugged into my OB2. He suggested the Hum might potentially be causing interference with the CAN-BUS because it's constantly communicating back and forth with the controllers in the vehicle that provide diagnostics. It seems plausible, so I unplugged the Hum device and will whether that makes a difference.
A lot of people have the shutter without anything being plugged into their ob2. Funny how that additive that I posted earlier worked, if only for a couple of months and that additive...."A concentrated friction modifier formulated specifically for instantly eliminating torque converter lock-up shudder"
19T4RTRDOR4X4NY
Old 10-07-2019, 12:42 PM #35
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Don't know. I guess it depends on how you drive it. Some people might notice it more, some not at all.
He did say that the Tacomas recently had a software update for the transmissions to address some issues, but the Tacos evident;y have a newer/completley different tranny than the 4R. At least that was my understanding.
Old 10-15-2019, 10:26 AM #36
coffeeshield coffeeshield is offline
coffeeshield is on a distinguished road
Just wanted to say I have the exact same issues as described here JAXJeremy. Just took the last half hour to read this entire thread.
I have a 2010 Trail edition. Have the same exact rumble as you, the same conditions bring it on.
Had it for 3 months, 75k miles on it, I've put on 3k. Brought it in to a different dealer for oil change, told them about the shudder.
They ran the VIN and said they'd actually seen this car earlier this year, previous owner brought it in with these symptoms. (In my head: "Oh ****.")
I will quote the National Service Record they printed for me:
"CLUTCH / TRANSMISSION C/S THERE IS A SHUDDER WHEN ACCELERATING 30-40MPH -- LOW REV AND PRESS ON GAS SLIGHTLY -- SHUDDERS -- WHEN PRESSING ON GAS HARD THERE IS NO SHUDDER ~~ CONFIRMED FAULT -- FOUND INTERNAL FAILURE STARTING IN TORQUE CONVERTER ~~ REQUIRES TORQUE CONVERTER REPLACEMENT -- DECLINED"
So he brought it in, didn't fix it, and sold it to a different dealer (the one I bought it from) without disclosing this.
I have an appointment with the dealer I bought the vehicle from later this week. Will keep you posted.
Any updates with yours?
coffeeshield is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 11:14 AM #37
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
No new updates, it still does it at random times. From that national service record, I don't know how you identify an internal failure that's starting in the TC. The last tech that drove mine pretty much indicated it's just the way they drive. I'd still like to get behind the wheel of another one to see if that's the case. who knows, could be software or maybe a random bad batch of torque converters..my step-dad bought a 2019 limited that I'll be able to drive in December, not sure if it will feel the same considering the limited has the FT 4WD..
Old 10-15-2019, 03:16 PM #38
So I just called to ask the dealer -- apparently the "confirmation" was them seeing there was a TSB out from Toyota with this described issue, which calls for replacing the torque converter. Then the previous owner declined the service.
So it seems it's still a mystery. I'm going to try flushing fluids and changing spark plugs and see what happens next week.
Old 10-17-2019, 01:11 PM #39
NJRimple NJRimple is offline
NJRimple is on a distinguished road
Making me think twice about getting one of these... was originally looking for a 17-19 Tahoe and they also had torque converter shuddering and vibration issues.. yikes
NJRimple is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 01:40 PM #40
JPL's Avatar
JPL JPL is offline
JPL JPL is offline
JPL's Avatar
Then don't look at these either:
transmission shudders slightly at acceleration. Transmission fluid change? | Drive Accord Honda Forums
Fixed: Automatic Transmission Shudder When Shifting From 2nd to 3rd | 8th Generation Honda Civic Forum
Honda CR-V Questions - 2014 Honda CRV transmission seems to shudder or jump when shifting bet... - CarGurus
Ford Transmission Shudder in Overdrive - Type A motorhomes - FMCA RV Forums – A Community of RVers
https://www.classlawgroup.com/camaro...ction-lawsuit/
https://www.cadillacforums.com/threa...udder.1073146/
https://www.turbodieselregister.com/...4-48re.242222/
https://www.cargurus.com/Cars/Discussion-t872_ds522654
https://www.corvetteforum.com/forums...-lucky-me.html
https://www.e90post.com/forums/showthread.php?t=1201992
https://forums.swedespeed.com/showth...ission-Shudder
https://www.benzworld.org/threads/tr...udder.1722880/
https://www.transmissionrepaircostgu...g-and-shudder/
http://www.carproblemzoo.com/buick/l...r-problems.php
https://forums.tdiclub.com/showthread.php?t=305195
https://www.subaruoutback.org/thread...shakes.419834/
https://www.kia-forums.com/threads/t...ipping.288137/
https://acurazine.com/forums/4g-tl-p...le-fix-954170/
https://landroverforums.com/forum/ge...shudder-37452/
https://www.jeepforum.com/forum/f309...udder-1323175/
https://xoutpost.com/bmw-sav-forums/...n-shudder.html
https://www.300cforums.com/threads/t...-30-mph.65651/
I guess I'll stop here.
19T4RTRDOR4X4NY
Old 10-17-2019, 03:12 PM #41
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
That's amazing there are that many different brands with similar issues..I wonder if some people don't even notice it..I seriously doubt that my wife would..
Old 10-30-2019, 10:29 AM #42
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Continuing to monitor the "shudder", noticed it a bit driving home yesterday and then again this morning on my way into work. For reference my trip each way is about 7 miles.
What I've observed is that at the point in the pedal travel where I'm feeling the shudder it's almost like there is a flat spot in the acceleration. I'm going to disconnect the PC to see whether that makes a difference and then planning to make another trip back to the dealership, can't really say if it's gotten worse, but I'm definitely noticing it which in my mind is not good.
Old 10-30-2019, 02:06 PM #43
Jivewalker's Avatar
Jivewalker Jivewalker is online now
Jivewalker is a jewel in the rough Jivewalker is a jewel in the rough Jivewalker is a jewel in the rough
Jivewalker's Avatar
Mine has been doing this at around 40-45 mph with a very light foot on the pedal for 183,000 miles. I chalked it up as normal after a while. To me it feels like the cruising speed when you're around 40 is in between 2 gears and its going back and forth between them.
The only other time I had any shuddering was when the OCV filter screen was clogged up, but that threw up a code.
2012 TE w/ KDSS, Black, 265/70R17 C KO2's, 192,000 miles
Inside Fishing Rod Holder Mod
"How can you shoot a poor innocent 3-legged cat?"
"Easy, you just don't lead him as much..."
Jivewalker is online now   Reply With QuoteReply With Quote
Old 10-30-2019, 02:25 PM #44
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Thanks for the info. You have 4WD as well?
Old 10-30-2019, 02:50 PM #45
Jivewalker's Avatar
Jivewalker's Avatar
Yes 4x4, not sure if that's what you are experiencing but sounded similar.
shudder , sr5 , steering , time , wheel
Driveline shudder during braking ultimatt 3rd gen T4Rs 13 02-25-2015 08:34 PM
Intermittent Shudder While Braking slimatic 3rd gen T4Rs 7 09-30-2013 11:45 PM
SR5 shudder question palooka23 5th gen T4Rs 2 11-22-2012 12:49 AM
tranny shudder? firsttoyo 3rd gen T4Rs 2 08-15-2009 09:05 AM
'03 T4R V8 HWY Shudder swartzy 4th Gen T4Rs 9 06-16-2006 07:36 AM
Copyright © 2019
