Old 10-30-2019, 03:31 PM #46
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
Originally Posted by Jivewalker View Post
Yes 4x4, not sure if that's what you are experiencing but sounded similar.
it sounds exactly the same..the shifting between two gears is a good analogy..
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 11-23-2019, 07:53 PM #47
coffeeshield coffeeshield is offline
coffeeshield is on a distinguished road
Originally Posted by JAXJeremy View Post
Continuing to monitor the "shudder", noticed it a bit driving home yesterday and then again this morning on my way into work. For reference my trip each way is about 7 miles.
What I've observed is that at the point in the pedal travel where I'm feeling the shudder it's almost like there is a flat spot in the acceleration. I'm going to disconnect the PC to see whether that makes a difference and then planning to make another trip back to the dealership, can't really say if it's gotten worse, but I'm definitely noticing it which in my mind is not good.
So I wanted to follow up. I took my 2010 Trail to the dealer. They confirmed the shudder between 30-45 (and 40-50 as well) as the torque converter.
He was a straight shooter, said that they don't do trans flushes there, but they do at another Toyota Dealer.
I took it to that Dealer, did the full flush (important: not just a fluid exchange or change), and 2 days later I have no shudder. It was happening multiple times a day prior to that.
I will come back and let you know if it resurfaces -- but I knew how to reproduce it before, and couldn't do it for the last two days. Very hopeful, and might be worth the $300 gamble for you guys.
coffeeshield is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 02:02 PM #48
2012sr5's Avatar
2012sr5 2012sr5 is offline
2012sr5 will become famous soon enough 2012sr5 will become famous soon enough
2012sr5's Avatar
Originally Posted by ChivaLRy9mm View Post
I have had the same issue with my 4R for a little while now. Here's my story. Mine is a 2011 Limited with 14x,xxx miles. I've owned it for about a year now. Same exact issue as far as not happening all the time, no shudder over about 50. I've spent about 8-10 hours personally under the vehicle checking U-joints, suspension mounts, basically anything and everything that moves or shouldn't move but might have worked itself loose. Finally after beating my head over the issue, I took mine into the 'stealership'. I took them for a test drive and replicated the issue for them multiple times. The way that I get mine to 'shudder' is by driving like a grandma. Very light on the gas while cruising in the 25-40 mph range. They looked it over and said it could possibly be the drive shaft being out of balance. They removed the rear driveshaft and drove it that way (AWD, so it can drive with just the front wheels). They still made the problem occur. They told me it's the torque converter and quoted me over $2,000 to replace it. So I parked the vehicle and have been riding my CBR for basically the entire summer. I got tired of riding there for about a week and drove the 4R and it seemed to have went away, but after a day or so the shudder came back. I think there's something to the torque converter idea.
Similar to yours, when I put the vehicle in 4S the problem is less pronounced. If you look at the graph, when in 4S, the acceleration Flex Lock-up is off, but the Deceleration Flex Lock-up is still on. I believe that is why the issue seems less pronounced. Like I said, my issue seems to happen the most, not when I am accelerating heavily, but when cruising and being very light on the gas (basically trying to up the fuel economy). I think that while being so light on the pedal, it is really difficult to tell whether the vehicle is actually accelerating or decelerating. Unfortunately for me, my vehicle is out of warranty. Yours isn't, I dunno, it just seems like the most likely possibility to me from my experience. I'm currently saving up to take mine to our trusted family mechanic to have the TC replaced and while he's in there flush the Trans and replace the filter because, why not? Definitely interested in what happens with your situation.
Good Luck!
I know you traded the 2011 in...but did you solve the issue beforehand?
2012 SR5 4WD 3rd Row
Build/Adventure thread
Nitto TG G2 LT265/70R17 review thread
2012sr5 is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 02:04 PM #49
2012sr5's Avatar
2012sr5's Avatar
Did this solve it for good for you?
Old 02-23-2020, 05:02 AM #50
SolidPooP's Avatar
SolidPooP SolidPooP is offline
SolidPooP is on a distinguished road
SolidPooP's Avatar
I have a bit of a shudder as well, but it only started once I installed the PC. Every time
I turn off the PC or unplug it, shudder goes away. Hopefully that solves the issue you’ve been chasing.
SolidPooP is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 10:45 PM #51
Try the transmission flush
It worked for me. I'm 1500-2000 miles on it, haven't felt it once since.
Make sure it's a full flush, and that you do it at a toyota dealership (not all of them will do a full flush either, most of them will just do a fluid change)
Old 04-09-2020, 11:42 PM #52
CMH_TX CMH_TX is offline
CMH_TX is on a distinguished road
Question
Have you ever checked issues with the emergency brake system? I once had mine inadvertently turned on and it caused shuddering at speeds up to 50 mph. May be unrelated, but worth checking.
CMH_TX is offline   Reply With QuoteReply With Quote
Old 04-10-2020, 09:59 AM #53
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Never checked the e-brake, but I don't think it has anything to do with it. This is definitely in the drivetrain. What's interesting is over time I've actually gotten accustomed to it and don't even really notice it any more. From everything I've read, and in talking to the tech at the dealer it's just the way the trannys in the 4runners feel and not a symptom of anything wrong.
Old 04-10-2020, 10:51 AM #54
I just asked a Honda and Toyota master mechanic. He said the shudder is due to the transmission fluid needing to be changed out.
Old 04-10-2020, 12:50 PM #55
blakjack23's Avatar
blakjack23 blakjack23 is offline
blakjack23 is on a distinguished road
blakjack23's Avatar
Definitely get your tranny fluid exchange. I had a the rumble strip issue, dealer said the torque converter was toast and would be $2900 to replace it. I had them do a full fluid exchange the problem went away completely after driving for a couple days.
blakjack23 is offline   Reply With QuoteReply With Quote
Old 11-17-2021, 06:12 PM #56
Chrisgoehle Chrisgoehle is offline
Chrisgoehle is on a distinguished road
2018 4runner trd pro. 57,000 miles, torque converter/tranny went. Sticks in 4th. Toyota replacing entire thing no cost to me. Guess this is common?
Chrisgoehle is offline   Reply With QuoteReply With Quote
Old 11-17-2021, 06:15 PM #57
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
it is not common at all.
Old 02-21-2022, 01:29 PM #58
Blue4ever Blue4ever is offline
Blue4ever is on a distinguished road
I'm in the same boat now. 2018 TRD Pro always kept up on maintenance. 96K miles. Shudder started last week Feb 14, between 20-40mph.
My extended warranty expired Feb 7.
t's in Toyota Katy today and they said it's the Torque Converter / Tranny needs to be replaced = $6k.
Keep reading about the tranny flush, but doesn't seem like a long term fix on here from what I have seen...
This sucks.. I had a 05 Tacoma new that I put 250K miles and never any problems. But it was a manual tranny.
Blue4ever is offline   Reply With QuoteReply With Quote
shudder , sr5 , steering , time , wheel
Driveline shudder during braking ultimatt 3rd gen T4Rs 13 02-25-2015 08:34 PM
Intermittent Shudder While Braking slimatic 3rd gen T4Rs 7 09-30-2013 11:45 PM
SR5 shudder question palooka23 5th gen T4Rs 2 11-22-2012 12:49 AM
tranny shudder? firsttoyo 3rd gen T4Rs 2 08-15-2009 09:05 AM
'03 T4R V8 HWY Shudder swartzy 4th Gen T4Rs 9 06-16-2006 07:36 AM
