Old 12-22-2019, 01:17 PM #16
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
It's like the old Timex commercials -- it takes a licking, but keeps on ticking.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 12-22-2019, 02:24 PM #17
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
Originally Posted by lockshi3 View Post
Hi all-
I'm hoping to get some opinions on the idle/park noise I'm hearing from my rather new 19 TRD Pro. It sounds a bit rattly/vibration like.
If you have a few seconds I'd appreciate you listening to the link below and hopefully quelling some of my fears. thanks!
YouTube
Your engine is fine, I personally love the way it sounds. If you hear that noise get louder under load then maybe you should worry. This is not a Hyundai engine, do your oil changes on time and your engine is happy.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 12-22-2019, 02:40 PM #18
lockshi3 lockshi3 is offline
lockshi3 is on a distinguished road
Thank you for confirming!
I do like the throaty - ness of the engine. I thought it sounded a bit “tinny” but to your point will keep an eye out if it ever gets louder/changes.
lockshi3 is offline   Reply With QuoteReply With Quote
Old 12-22-2019, 02:43 PM #19
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
Unfortunately I really can’t hear the noise enough to tell what it is. But with my vehicle I have a tapping/ticking noise that sounds like it’s coming from the lifters.
I tried using multiple types of engine cleaners. I’d added Mystery oil to my engine oil and I also used the type you add to your engine and run it for 5 min just before your oil change. I also used multiple types of fuel additives/cleaners every time I filled my gas tank for several months with no noticeable reduction to the ticking noise. Also, after extensive research online and comparing my vehicle engine noise to other 4Runner, it appears the ticking/tapping noise is normal. I’ve had my vehicle for about a year now and I haven had any engine issues.
One thing that I did notice that reduced the ticking noise significantly was putting in heavier oil. So I’ve come to the conclusion that the reason the 4Runner engine has a ticking noise is because of the thin oil Toyota recommends with the engine. I think they recommend it for improved mileage. I get about 17-18 mpg but when I used thicker oil it dropped down to 15 mpg.
Lexington is offline   Reply With QuoteReply With Quote
Old 12-23-2019, 05:55 AM #20
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
Here's mine singing along.. maybe a bit louder than average
Engine noise
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 12-23-2019, 08:16 AM #21
yota1976's Avatar
yota1976 yota1976 is offline
yota1976 is on a distinguished road
yota1976's Avatar
My new 2019 TRD OR has the little tick at idle as well. That doesn't other me. You should hear my wife's Hyundai Santa Fe. It's got injector tick that's alot more noticeable and it's been like that since new as well. One noise I thought was different on the 4runner is the massive rush of air at the front of the vehicle when you first start it up. These things must have awesome electric fans!
2019 TRD Off Road, Barcelona Red, Predator Steps, Sprint Booster V3
yota1976 is offline   Reply With QuoteReply With Quote
Old 12-23-2019, 10:35 AM #22
upperleftguy's Avatar
upperleftguy upperleftguy is offline
upperleftguy is on a distinguished road
Engine noise
I would hear that and think something is wrong. Glad I know it’s nothing to be concerned about. My new to me SR5 has the most minimal knock/tick ( like I have to REALLY) listen for me to notice.
upperleftguy is offline   Reply With QuoteReply With Quote
Old 12-23-2019, 01:54 PM #23
17KT4R 17KT4R is offline
17KT4R will become famous soon enough
Personally I love the sound of the rockers at low idle in the drive through between walls, the click clack sounds they make and the way you can hear the timing chains whirring away, lets you know everything is turning! Enjoy it LoL. Like someone said - the only way to quiet that down is sound deadening of which there isn't much up front. With the temperature changes we experience in these parts I wouldn't stray from 0W-20, small oil passages in these engines are likely the reason that weight is specified so I'd rather not have thicker oil in it unless you live in climates where it's never a cold start.
2017 TRD OR / KDSS / Canuckistan Edition
17KT4R is offline   Reply With QuoteReply With Quote
Old 12-23-2019, 11:33 PM #24
Lexington's Avatar
Lexington's Avatar
Engine noise
Yeah mine sounds about the same. It’s louder on the right side like it’s coming from the lifters or fuel injection pump.
Old 12-24-2019, 02:38 AM #25
Originally Posted by yota1976 View Post
My new 2019 TRD OR has the litle tick at idle as well. That doesn't other me. You should hear my wife's Hyundai Santa Fe. It's got injector tick that's alot more noticeable and it's been like that since new as well. One noise I thought was different on the 4runner is the massive rush of air at the front of the vehicle when you first start it up. These things must have awesome electric fans!
That’s the air injection system you’re hearing on start up.
Old 12-24-2019, 04:00 AM #26
borfoo3's Avatar
borfoo3's Avatar
I still suspect some debris is stuck in there.. engine gulped a bit of sand once and sounds were louder ever since that day.
Old 12-24-2019, 07:49 AM #27
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
You sure? I have the massive rush of the fan too, didn't think I had SAI with mine being a 2012 and all.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 09:07 AM #28
xcalbr2 xcalbr2 is offline
xcalbr2 will become famous soon enough
2012 here too and we do NOT have the air injection. Mine seems to be high speed idling with the colder temps and I do not remember it doing so last winter.
Also seems a bit louder until warm.
X
xcalbr2 is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 10:07 AM #29
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Anyone using a 5W20 rather than the 0W20 called for? I live in MD so we get 0* days and we get 100* + days. Just curious if the 5W20 made any difference in the way the engine runs. Seems like the 5W20 oil is also half the price of the 0W20 in terms of Toyota brand oil.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 12:51 PM #30
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I listened, sounds fine, don't worry.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
engine , i’m , noise , oil , toyota
Weird metal tapping/clicking noise from engine zzzzzzz7zzzzzzz 3rd gen T4Rs 3 01-20-2019 03:52 PM
4.7L Engine Ticking Noise TheWhighet 4th Gen T4Rs 2 10-30-2017 11:14 AM
RE: Engine Noise, Ticking tonlun 4th Gen T4Rs 1 03-28-2008 04:06 PM
Clicking/Ticking noise from the engine GuardianBU 4th Gen T4Rs 6 02-21-2007 11:51 PM
Tapping noise in engine rosmith2 4th Gen T4Rs 4 04-05-2004 09:33 PM
