Old 08-06-2019, 01:51 AM #1
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
Engine Tapping/Ticking Noise
Hi All
I知 a new Toyota owner. I owned a nothing but Isuzu Troopers the last 25 years. But my last faithful steed has gone to pasture. So I replace her with a 2016 4Runner TRD Pro. But there are new sounds that I知 not accustomed too.
The one I致e had the most concern about is a light tapping/ticking noise coming from the engine. A Toyota Dealer mechanic told me that it痴 fairly common for these engines with 30k+ miles. He said these engines tend to get a varnish build up on the fuel injection and valves but it nothing to be too concerned about.
I知 wondering if there are ways to reduce the noise. I did add Lucas Oil for synthetic oil and it was noticeably quieter. Someone also said I could run Miracle Oil in the oil and engine and that it would help remove the varnish. I talked to a customer service guy for Toyota about it and said using different oil might help too. He said his Tundra runs quieter on Valvoline synthetic oil. Right now I知 running Castro Synthetic Oil.
I壇 like to know how many people have had this issue and what you did to get rid of that tapping noise or at least make it quieter.
Thanks
Lexington is offline   Reply With QuoteReply With Quote
Old 08-06-2019, 06:09 AM #2
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
There is another recent thread here discussing engine ticking. Best results I've seen in my neighbor's 5th gen were with Toyota 0W-20 oil which has significantly more molybdenum anti-wear additive than other oils, zero ticking. In the case of my 4th gen which calls for 5W-30, the quietest are Quaker State Ultimate Durability and Pennzoil Platinum High Mileage.
There's also a large body of testimonial evidence on spiking gas with TC-W3 two cycle oil at 640:1 (1oz to 5 gallons of gas) as an upper cylinder lubricant. I've been doing this on my '07 4Runner for the past 30K miles with no ill effects, idles so smooth you can't tell it's running without looking at the tachometer. Injector tick is nonexistent.
Here's some light reading on the subject of TC-W3 mixing: Been testing Oil
waypoint is offline   Reply With QuoteReply With Quote
Old 08-06-2019, 06:10 AM #3
JP421's Avatar
JP421 JP421 is offline
JP421 is a jewel in the rough JP421 is a jewel in the rough JP421 is a jewel in the rough JP421 is a jewel in the rough
JP421's Avatar
Well the Toyota tech must not know Toyotas. It is common in these engine right from the start. I have had the tick since the day I drove it off the lot. Nothing to worry about. As far as reducing the noise you could add some sound deadening insulation to the engine compartment.
2019 TRD Off-Road Premium
285 Cooper STT Pros - Tandem Offroad 612 Charlie in bronze
Dobinsons - Front: C59-300, GS59-574 Rear: C59-505, GS59-701 - JBA UCAs
RSG Metalworks Sliders - Angled - RCI Skids
JP421 is offline   Reply With QuoteReply With Quote
Old 08-06-2019, 04:15 PM #4
Globetrotter78's Avatar
Globetrotter78 Globetrotter78 is offline
Globetrotter78 has a spectacular aura about Globetrotter78 has a spectacular aura about
My wife and I both have 2018s and they are both ~20k miles. Both have ticking and mechanical noises I would better attribute to a diesel or some other noisier motor. Definitely not Honda motors or smaller Toyota car motors that whisper or sound like little sewing machines when you pop the hood.
This motor is absolutely NOT a quiet runner but as long as it keeps chugging along for the next 300k+ miles it can tick and clank all it needs to.
*2018 White SR5 4x4, Icon 2.5 Exten Travel w/ res, JBA High Caster UCAs, 1.25 Spidertraxx, SSO Sliders and Bumper (on route), Icon Rebounds and 285/70 Falken Wildpeak A/Ts
*2013 Maserati GranTurismo Sport
*2013 Fiat 500 Abarth- the rocket powered go-kart!
Globetrotter78 is offline   Reply With QuoteReply With Quote
Old 08-06-2019, 07:27 PM #5
callihan_44 callihan_44 is offline
callihan_44 is on a distinguished road
I noticed some ticking but only when the engine is cold, once driving the sound goes away. I was thinking the recommended oil weight seemed kinda low 0 -20w ? Normally in my other engines I run 5-30w and 10-30w syn in summer
callihan_44 is offline   Reply With QuoteReply With Quote
Old 08-06-2019, 09:12 PM #6
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
Wife's 2014 SR5 is pushing 95K miles. No tick. Fairly quiet engine
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 08-06-2019, 10:33 PM #7
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
My engine has sounded like a diesel since day one and I love it. My coworker bought a new Canyon and when he starts it up it ticks, chirps and rattles for about 5 minutes. I make fun of him because of it. Shouldn稚 have bought a GMC.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 12:02 AM #8
Sonoran_Desert Sonoran_Desert is offline
Real Name: Jo
Sonoran_Desert will become famous soon enough
Real Name: Jo
Sounds like little sewing machines! Bwahahahaha. Great analogy.
Sonoran_Desert is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 01:13 AM #9
Just to be clear, there should be no LOUD ticks or noises that are CLEARLY a sign of something awry. Valves needing adjusting or mechanical failure of some internal component would be far more evident than anything these trucks normally produce and highly unlikely at such low mileage. These engines dont seem like they are designed with extremely tight tolerances and as such they are inherently more noisy. I listened to 5 different 4 Runners today after work just for curiousity. Not one of them sounded like a civic or a corolla motor and I dont think they were meant to. So with that, no worries.
Old 08-07-2019, 03:13 AM #10
Lexington's Avatar
Lexington's Avatar
Thanks Gents for your replies. Much appreciated.
I ran into another 4Runner owner today and listen to his motor. It sounded the same. If I find anything else out I値l post it here.
Old 08-07-2019, 07:04 AM #11
johnbt's Avatar
johnbt johnbt is offline
johnbt will become famous soon enough johnbt will become famous soon enough
johnbt's Avatar
I think I heard mine tick a little once. I was at the drive-up bank teller and had the volume turned off on the radio and heater fan wasn't on high. That was 20k miles ago, so maybe it's gotten worse. Or better.
Fwiw, I use whatever oil the dealer puts in it because I got 4 years of free oil changes when I bought it.
2023 TRD ORP w/KDSS. Red again.
This 2016 TEP w/KDSS is a big step up from the 1986 Subaru GL wagon I used on the Outer Banks beaches for 14 years. That thing would go anywhere in the sand on 185/70-13 tires. Dual range 5 speed, factory skid plate, 3 position manually adjustable rear shocks and armored exhaust. All factory, including the white spoke wheels. The front sub frame finally rusted apart.
johnbt is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 08:58 PM #12
kami37 kami37 is offline
kami37 is on a distinguished road
What about this? There's a thread in 4Runner.com and the opinions are all over the place. The video is mine.
YouTube
kami37 is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 09:11 PM #13
Tejas Tejas is offline
Tejas is a jewel in the rough Tejas is a jewel in the rough Tejas is a jewel in the rough
All of my 4.0L Toyota's have had the "tick" since new (five different vehicles to date including the current TRD Pro). While it can be a tad unsettling and annoying there is nothing wrong with the motor, that's just how they run.
Tejas is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 11:00 PM #14
Horsethief Horsethief is offline
Horsethief will become famous soon enough Horsethief will become famous soon enough
My 13 with 91k miles does it. Sounds like garbage. I can't believe I didn't notice this when I bought it, otherwise I probably wouldn't have.
I can't believe Toyota thought this was acceptable. Damn thing sounds like a rocker is going to come shooting though the hood.
I cringe everytime I hear it idle.
Horsethief is offline   Reply With QuoteReply With Quote
Old 12-22-2019, 01:00 PM #15
lockshi3 lockshi3 is offline
lockshi3 is on a distinguished road
TRD Pro 2K miles - more rattly / vibration like?
Hi all-
I'm hoping to get some opinions on the idle/park noise I'm hearing from my rather new 19 TRD Pro. It sounds a bit rattly/vibration like.
If you have a few seconds I'd appreciate you listening to the link below and hopefully quelling some of my fears. thanks!
YouTube
lockshi3 is offline   Reply With QuoteReply With Quote
engine , i知 , noise , oil , toyota
Weird metal tapping/clicking noise from engine zzzzzzz7zzzzzzz 3rd gen T4Rs 3 01-20-2019 03:52 PM
4.7L Engine Ticking Noise TheWhighet 4th Gen T4Rs 2 10-30-2017 11:14 AM
RE: Engine Noise, Ticking tonlun 4th Gen T4Rs 1 03-28-2008 04:06 PM
Clicking/Ticking noise from the engine GuardianBU 4th Gen T4Rs 6 02-21-2007 11:51 PM
Tapping noise in engine rosmith2 4th Gen T4Rs 4 04-05-2004 09:33 PM
