Old 08-08-2019, 12:10 AM #1
MaddoxPics's Avatar
MaddoxPics MaddoxPics is offline
MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough
MaddoxPics's Avatar
Clunk Noise Help
Looking for a little help and maybe a direction to look with some new clunks/creaks I've been hearing with the 4Runner. It is definitely coming from the driver side, and appears to be somewhere in the front end.
I have a baby on the way this Sunday and am wanting to get this taken care of ASAP. My issue is I work every day except for Friday, so while it could be something simple that I'm planning on going over, I'd like some other possibilities to look at in case they are them.
For some current specs on my setup.
2017 - 60,000 miles
Total Chaos UCA
King 2.5 Extended Travel Shocks
Stock LCA
No Sway Bar
31M Battery w/ Pelfrey Tray
That's the only things I feel are important to note.
The battery I haven't felt any extra shaking nor noticed anything, but I have heard the 31M's with the Pelfrey cage can cause cracking on the inner sheet metal. Not sure if that's what it sounds like, but possibly could be it?
The UCA was greased roughly 1,000 miles ago. Bushings then and currently look fine (I loosened the bolt before greasing). The ball joint more than likely needs to be lubed up which I will be taking care of Friday, but with that said I've never heard it make that kind of noise when dirty.
LCA's look good. Recently had it aligned and was told they still look fine and nothing to worry about.
The shocks have roughly 30,000 miles on them, but still feel great when driving. Do they make these noises when they need rebuilt? That would be something I could be overlooking.
The sway bar has been off for awhile, but while I've read the tierods go out, they appear to be in good shape and nothing wrong.
Because of the recent alignment I decided to check the torque on everything in case something wasn't torqued to spec and came loose. Everything was correct and not out of spec.
My guess right now is it could be one of the skids. I know my OEM black steel skid is bent pretty good from wheeling trips, but nothing new has hit them so not sure if changed or something has happened. My TRD skid is also on, perhaps they are contacting each other somewhere.
My CV axle on the driver side was leaking so I had that fixed as well as put in the ECGS bushing. CV I was told looks good as well. No binding or anything.
Is there anything I could be over looking? Should be thinking about checking? Could this be a steering rack issue (I haven't noticed any issues with steering, or anything else).
MaddoxPics is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 12:54 PM #2
sparkyy192 sparkyy192 is offline
sparkyy192 is on a distinguished road
Interesting. I have the same exact issue. Also around 60k miles on my '15. Recently lifted on bilstein 5160/6112 with new tires and got alignment. Issue started after that. I have RCI skids and thought that front stock piece might be rubbing but not so sure. My sound seems to be coming from right behind the pedals somewhere.
sparkyy192 is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 02:02 PM #3
halflife78's Avatar
halflife78 halflife78 is offline
halflife78 will become famous soon enough
halflife78's Avatar
Welcome to the club, please PM your address for the clunk shirt to be sent to.
2016 TRD Pro: C4 Rock Sliders | Victory 4x4 Roof Rack | Ellis Precision Shifters | Blackvue 650s 2 CH | Full Front Clearbra | 20% Tint | Beavertail | Borla S-Type | Pedal Commander | Tail as Turn | DRL LED Foglights | ArcLight Triple State Voltage Booster | Victory 4x4 Front Winch Bumper | Victory 4x4 Front Skid | TRD CAI | SCS Stealth 6 | Dobinsons Lift & UCA | Warn Zeon 10s | Northstar 31m | Factor55 Flat Link | ARCLightLED Hatch/Map/Dome Lights | Lock'er Down Console Safe | XD Door Light / License Plate Bulbs
halflife78 is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 02:11 PM #4
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
It could be any number of things. I would try to be a methodical as possible. Front to back. Top to bottom. Test every component for loose nuts, bolts, missing or damaged parts. Put your hands on everything and try to manipulate them (I usually use a pry bar.). Then put it up on stands and do it all again.
Sounds like your on top of it. Could be hard to trace. One of those situations where those sound sensor kits would come in handy.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 02:36 PM #5
dot_tom's Avatar
dot_tom dot_tom is offline
Real Name: Tom
dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all
dot_tom's Avatar
Real Name: Tom
I agree with Halflife. Welcome to the club. I have been chasing a low speed squeak on the driver side for 40k miles and a clunk in the steering for the last 10k or so. All part of it I guess.
2017 4Runner TRD OR - Progress Thread
295/70/17 BFG KM3, SCS F5 17x9 -38, Front 5100 Rear MT Icon, Dobinson 314 & 701V, Gobi Stealth, RSG Sliders, ECGS 4.56's, Demello Front bumper, Coastal Off Road Rear Bumper
IG: dot_tom
dot_tom is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 03:19 PM #6
lenkerg's Avatar
lenkerg lenkerg is offline
lenkerg is on a distinguished road
lenkerg's Avatar
2017 - 60,000 miles
Total Chaos UCA
Stock LCA
No Sway Bar
Check to make sure there is grease in your CV Joint. Ends up that I didnt have it done in mine properly and it developed two days ago after 10k miles. Just a thought....
TC +2 Long Travel with the Triple Bypass, 35x12.5 Nitto Ridge Grapplers, Fuel Vector Wheels, Full Length FrontRunner Roof Rack Hefty Fab Rear Aluminum Bumper, Hefty Fab Front Aluminum Bumper RCI Skids.
lenkerg is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 05:27 PM #7
MaddoxPics's Avatar
MaddoxPics's Avatar
You may be having a needle bearing issue. May want to look into the symptoms and see if that's it. Typically you have clunk noises as well as some steering wheel shake.
Can I get the shirt in red to match the 4R?
That's definitely the plan, just wanted to make sure I wasn't going to be overlooking anything that I should be checking out. Have to love the everlasting search for the noise.
Tell me about it. I've had some noises here and there that I've been able to figure out. A few I haven't, but sounds like nothing serious. Granted that'll be the one that kills me probably.
I'll be sure to do that. Thanks!
Old 08-08-2019, 06:45 PM #8
jsunn jsunn is offline
jsunn is on a distinguished road
Same issue here. Brand new 2019 ORP, just lifted Bilstein 5100s in front with SPC UCA’s. Super slight clunk right behind pedals in wheel well. I’ll post back if I get it figured out.
jsunn is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 08:14 PM #9
MaddoxPics's Avatar
MaddoxPics's Avatar
Went ahead and did some stuff considering my day got all out of wack due to some unforeseen things.
Cleaned out the UCA and lubed it up. Also noticed my skid was a little loose so tightened all of that down.
Haven't heard the noise after roughly 20min of driving (I drove a good 10+ with it off and never heard it). That's with various stop and goes, speed bumps, turns, etc. I'm thinking it was the skid plate, as when I shook it left to right it was making an identical noise.
Hopefully that's all it was.
Old 08-09-2019, 03:08 PM #10
I also had a squeak that was driving me crazy. Mine was caused by the thin piece of plastic protection behind the front wheel in the wheel well. I think it's meant to keep dirt out of the suspension. Held on by those plastic clips, which come loose over time and squeak when there's any sort of wind/air flow.
Old 08-09-2019, 03:27 PM #11
dot_tom's Avatar
Real Name: Tom
dot_tom's Avatar
Real Name: Tom
That is the common issue and the first thing I looked at thanks to this forum.
Unfortunately it was not the problem. My squeak is sub 8mph that will increase from 1 mph - about 8 mph. Squeaking faster as the speed goes up. Think mattress squeak, increasing in speed as... well you know. That's exactly how it sounds, lol.
oh, and of course it won't do it when I take it in for the tech to drive.
IG: dot_tom
feel , good , miles , noticed , pelfrey
Clunk noise on TRD PRO yume316 5th gen T4Rs 5 05-07-2018 11:15 PM
New TRD Pro Clunk Noise? MaddoxPics 5th gen T4Rs 6 06-23-2017 02:04 PM
01 with clunk/pop noise 01thunder 3rd gen T4Rs 9 07-17-2013 01:34 AM
Clunk noise stlbluebmw325ci 4th Gen T4Rs 4 10-15-2012 05:58 PM
Clunk noise from 4H - 2H kolo Problems & Warranty Issues 1 10-31-2003 12:15 PM
