Old 08-08-2019, 10:47 AM #1
DeserTrek DeserTrek is offline
Real Name: Garrett
DeserTrek is on a distinguished road
Real Name: Garrett
Fire extinguisher (5lb) mount... Ideas?
Looking for opinions on where to mount my 5lb Amerex fire extinguisher. I'd prefer something near the bottom of the rear passenger seat. Any mount or mods out there that would support this? I see plenty for 2.5lb unit mounts, but not much out there for the 5 pounder.
2019 4Runner ORP w/ KDSS l RSG Rock Sliders l SSO Slimline Hybrid Front Bumper l Bud Built Full Skids l 285/70/17 BF KO2 l SCS Stealth 6 Wheels l Victory 4x4 Rear Molle Panel l Bilstein 6112/5100 Combo l 2.5''/1.5'' lift l ARB Rear Diff Breather
DeserTrek is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 11:26 AM #2
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
I have seen many 2.5 vehicle mount bracket kits. You could fit one near the seat or side trim area. A 5lb I have not seen a vehicle support kit for (generally the kits are for forktrucks and other equipment to mount 2.5s). A 5lb is also alot of keep still in the event of a collision as the mass moves forward.
Grug556 is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 11:49 AM #3
Whippersnapper02's Avatar
I also have only seen 2.5lb mounts. I figure spend more on the extinguisher since I'm limited on size.
Old 08-08-2019, 02:56 PM #4
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
wits end
Old 08-08-2019, 03:06 PM #5
DingusGoziña's Avatar
DingusGoziña DingusGoziña is offline
DingusGoziña is on a distinguished road
I have the exact same 5lb amerex fire extinguisher which I purchased through ebay with a vehicle/boat mount included. I plugged a hammer drill into my 2016 and started drilling through some panels in the trunk area. I kept saying "why are you drilling yourself" to humiliate her the whole time. At first I attached it to that panel which opens up revealing the tire jack, but it is not secure enough. I have decided instead to mount it just to the left of that panel and I will attach pictures when I get home from work. The fire extinguisher sits there perfectly and is easily accessible through the rear. Furthermore, I have the 3rd row seating model and it does not interfere with the mount.
DingusGoziña is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 03:54 PM #6
t6pilot t6pilot is offline
t6pilot is on a distinguished road
I did the exact same thing, used some wide area washers to stiffen up panel on backside works fine
t6pilot is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 04:52 PM #7
Real Name: Garrett
Real Name: Garrett
From Wits end's website:
Will the Amerex B386T Halotron fire extinguisher fit in your seat bracket?
The potential the issue is that this is the 5lb. I have not tested with any 5lb extinguishers but I do have room to clear the nozzles of the 2.5s. Now it looks as though the body does not go past the length of the nozzle so that is good news. If you are using the bracket 818S then the holes will line up just fine. If you are using the 821, 821S or 807 brackets then you would have to drill new holes. The 807 altogether though I don't think is a good choice for up front anyway.
Im glad to see this as an option. I feel more comfortable having it attached to a solid anchor point. That said, the mount only works on the driver's seat, so I'd have to play around first to see exactly how much leg space I would be giving up.
Old 08-09-2019, 09:41 AM #8
Please explain how you used the washers. I assume you mean that the fire extinguisher is mounted on that removable panel behind the wheel well on the left side. If you have any pics... Also does it rest on the ground? or is it slightly suspended? I had to rest mine on the ground for mounting because I did not want it to interfere with the cargo cover (vinyl pull out thing for trunk) which slides into a notch right above this area.
Thanks man!
Old 08-09-2019, 10:50 AM #9
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Could you mount the fire extinguisher on something like this.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 08-09-2019, 04:13 PM #10
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
I'd caution that you'd want to make sure to mount the extinguisher in a spot where it can't do any damage to you in an accident.
Mounting it on a removable panel (or any interior panels) may be a very bad idea as the forces in an accident will turn that 8lb slab of very hard metal (most 5lb [fill] extinguishers weigh about 8lbs) into a missile.
Accordingly, ask yourself "where will this thing go in an accident?" Consider snugging it up against the back seat and mount it to something solid. If it can move, then it will move in an accident and it will rip out of any trim panels.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 08-09-2019, 04:40 PM #11
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
How about a 21st century solution?
Element Media
I keep it under my seat.
Old 08-09-2019, 11:51 PM #12
Ray Dunakin's Avatar
Ray Dunakin Ray Dunakin is offline
Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold Ray Dunakin is a splendid one to behold
Element Media
Very cool -- thanks for posting that. I just ordered two!
Ghost towns, mines, and more: www.raydunakin.com
2016 silver Trail Edition w/KDSS; BudBuilt sliders w/full tread plate; upgraded rear hatch lift struts;
BFG KO2 265/70/17; Gobi "no-rise" Stealth rack w/ladder; MetalTech front bumper;
King coil overs, upgraded springs, ~1.5" lift; RCI skid plates.
Megaweapon's build/adventure thread
Ray Dunakin is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 11:59 AM #13
Thanks man!
No, not mounted on removable panel, just forward of it
There is room between panel and body. Used 1/8x half inch bolts
1 1/2 inch wide area washers with a self locking nuts
4 bolts total
5lb , extinguisher , fire , mount , mounts
Where to mount fire extinguisher in 3rd gen? SnowRambler 3rd gen T4Rs 30 12-19-2023 02:47 AM
5th Gen Fire Extinguisher Hidden Mount jrmjeff 5th gen T4Rs 4 09-25-2017 12:56 PM
Fire extinguisher mount 4thgenblake 4th Gen T4Rs 21 03-05-2016 03:55 PM
Anyone use these to mount a Fire Extinguisher? GVL 3rd gen T4Rs 5 07-20-2014 09:28 AM
