09-24-2019, 10:22 PM
#121
Real Name: Duane
Real Name: Duane
Never mind I dont even have a space for it....
09-25-2019, 02:33 AM
#122
side note: Meso custom Tacoma 3rd gen LED dome light works on 5th gen 4Rs as well. I replaced mine for the the red led and its much easier on the eyes than any white led.
'19 TRD Off Road Premium w/kdss| King shocks 2.5 w/adjusters| Total Chaos uca| Icon 2" rear coil| Nitto Ridge Grapplers 305/70/17| stealth custom series Ray 10 17x9 -38| Rigid Industries D-series amber fog lights| Morimoto HID & LED| Outgear Solutions full roof rack| Outgear Solutions rock sliders| RCI Steel Skid Plate| Drawer System
09-28-2019, 01:25 AM
#123
Originally Posted by 97BlackAckCL
The Lasfits are REALLY bright, they're actually the same Lumen rating as these Meso pods
Right now the Last fit T10/194/168 at 400 Lumens are at the top of my list for the puddle lights however still waiting on a Lumen number on these ( see below).... being that the emitters are all on the same plane and would all be directly pointed to the opening on the bottom of the side mirror this may turn out to have even more light.
2 Pcs - Advanced Bright LEDs - T10/194/168 - 180 T-Shape 8-SMD White Light - OPT7
09-28-2019, 09:32 AM
#124
I did the Lastfit on my 4R last week.... Great LEDs
Sent from my SM-G975U using Tapatalk
09-28-2019, 03:05 PM
#125
Originally Posted by Superjet
Best video I found at 8:57 mark:
YouTube
Excellent video. Thanks for posting it.
09-28-2019, 03:07 PM
#126
Originally Posted by ElectroBoy
Yes, very good advice. As with so many other clipped-in pieces inside and outside the 4R, if you know where to grab and pull, and you go slow and deliberately you will be OK. But the first time attempt is kind of nerve wracking, with all the noise of clips releasing.
What I found daunting was the idea of pulling off the mirror. I didn’t trust myself to not break something. I was more comfortable with the painted cover removal method. I’ve used this method four times with no problems. (The main grab point to start is the pointy section toward the window). It gets easier each time. See post 20 below for more info.
2014 Side Mirror Bulb Access
Either way, you will be successful.
Thanks,
@ ElectroBoy
. I’ve seen this method as well and like the idea of not having to remove the glass.
09-28-2019, 04:30 PM
#127
I've done both FyreFlyz LED bulbs
And Lasfit LED T10 bulbs, highly recommend the Lasfit bulbs, they're bright as hell
Pretty much any wedge bulb will fit
Where did you get the t10 lasfit...thinking about not doing meso and maybe just doing lasfit led
Sent from my ONEPLUS A6013 using Tapatalk
09-29-2019, 08:07 PM
#128
Real Name: Chris
Real Name: Chris
https://www.amazon.com/LASFIT-Non-Po...9801799&sr=8-6
09-29-2019, 09:35 PM
#129
Just an FYI brighter means hotter, I would check the housing if they have been on for a while, you don't want to melt inards. (if you are using them as a switched light, LED's can get super hot)
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
09-30-2019, 02:09 AM
#130
The Meso lights are nice.
10-01-2019, 06:43 AM
#131
Real Name: Billy
Real Name: Billy
I recently added the meso much better then just putting an led in the stock slot. the light is way, way brighter. if your going to take the time to brake down the mirror to change the bulb just spent the 100 bucks and buy the kit. I had to keep changing the amazon led bulbs they don't seem to last.
2018 Trd ORP , 1997 Fzj80 , 1985 Fj60
11-04-2019, 02:01 PM
#132
Real Name: Chris
Real Name: Chris
This weekend I replaced my Lasfit T10's with the Meso LED pods, and my God what a difference. The Lasfit T10 bulbs are great, and very very bright, but I couldn't believe the difference with the VLED pods from Meso.
Here's a before as I was installing them
And here is a side by side before and after, the new Meso on the right, and the Lasfit on the left
Further back
These are the same lumens, however the panel being out with no lens or diffuser produces so much more outward light.
Here's the Lasfit only, very bright on it's own, but nowhere near the throw of the VLED
05-03-2020, 01:42 AM
#133
FYI the MESO puddle lights are currently available.
2015 Magnetic Gray SR5P
05-03-2020, 12:09 PM
#134
I have had Opt7 and Lasfit. Green and red, both great colors for out in the woods. Both work great, just make sure you get the right shape size or they will get knocked out of the socket when you put the mirror back on.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
05-04-2020, 01:56 PM
#135
I want these for my Pro!!!
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
