Old 08-10-2019, 03:16 PM #1
chetJ's Avatar
chetJ chetJ is offline
chetJ is on a distinguished road
chetJ's Avatar
155000 Miles, 8 years and still going strong!!!
Been a while since I logged on here and posted anything. Was doing my summer cleaning and figured I would post. My 2011 T4R, Limited has 154000 miles and still going strong. Not a single issue! Love it!
155000 Miles, 8 years and still going strong!!!-s2-jpg  155000 Miles, 8 years and still going strong!!!-s3-jpg  155000 Miles, 8 years and still going strong!!!-s4-jpg  155000 Miles, 8 years and still going strong!!!-s5-jpg  155000 Miles, 8 years and still going strong!!!-s1-jpg
2011 Magnetic Grey -Limited
chetJ is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 04:05 PM #2
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
Thumbs up
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 04:08 PM #3
chetJ's Avatar
chetJ's Avatar
Thanks!
Originally Posted by progress4m View Post
Old 08-10-2019, 04:10 PM #4
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Are you on the original shocks and control arms bushings?
Our 2008 Subaru Tribeca is now at 152,000. I don't call shocks replacement an issue but we replaced the factory ones at 145,000. I replaced the control arms just a little earlier (easier than just bushings).
Old 08-10-2019, 04:24 PM #5
chetJ's Avatar
chetJ's Avatar
Still on the original
Yes, still on the original shocks and control arms. Have only done the regular maintenance and changed the tires once. My mechanic has not recommended that change as yet.
Why did you get your changed? Was there an issue with the Subaru's shocks and control arms? Did you notice any changes that caused you to change them?
Old 08-10-2019, 07:30 PM #6
Keith M Keith M is offline
Keith M is on a distinguished road
I Too....
am in for the long haul. You got nuthin on me. ;o)
Check my sig.
30 years of 4runner ownership and counting. #1 1987-2001, 220k, #2 2001-2017, 215k, #3 2017 Off Road 50k, #4 2020 ORP. I'm done.
Keith M is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 08:09 PM #7
AGS92 AGS92 is offline
AGS92 is on a distinguished road
Looks great. What tires are you running now. We have a 2018 Limited as well as a 2019 SR5P. After my first tire rotation on the Limited, I'm starting to consider what tires I'll eventually buy to replace the factory Yokohamas.
AGS92 is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 10:58 PM #8
chetJ's Avatar
chetJ's Avatar
Tires
Am using Michelin ms2 LTX I believe (can confirm tomorrow). These tires are bigger than the factory originals. But, the ride is great. I swapped my Yokohamas out at 60 K and put these on. The first four lasted until 153K (almost 90K). Just put these on (exact same ones as the ones that lasted 90K).
Old 08-10-2019, 10:59 PM #9
chetJ's Avatar
chetJ's Avatar
Smile True
Check my sig.
Very true !
Old 08-10-2019, 11:25 PM #10
TacoRunn0517's Avatar
TacoRunn0517 TacoRunn0517 is offline
TacoRunn0517 will become famous soon enough
Clean! Looking forward to seeing how my 'Runner holds in Year 8/Year 9. Routine maintenance does make a significant difference. For me, its worth the small cost(s) upfront instead of dealing with something more sudden/costly down the road.
2016 Toyota 4Runner Trail Edition - Magnetic Gray Metallic - 4x4 *** Trailfinder AT 265/70-178 *** 3M Obsidian Tint (30%) *** LASFIT LA Plus Series H11 H9 H8 LED Bulbs *** XenonDepot Xtreme LED Pro 9005/HB3 Bulbs (w/ DRL Driver) *** LASFIT LD Plus Switchback H8 H11 H16 LED Fog Light ***
TacoRunn0517 is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 05:07 AM #11
pahaf91 pahaf91 is offline
pahaf91 is on a distinguished road
amazing. as long as you keep up the maintenance, should last you a long time. The car looks amazing. Did you ceramic coat it or do you wax it regularly?
pahaf91 is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 07:08 AM #12
Drobs Drobs is offline
Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light
Time to add some modifications...
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
Drobs is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 07:56 AM #13
chetJ's Avatar
chetJ's Avatar
Couldn't agree more
I couldn't agree more. Doing the basic maintenance has definitely helped. BTW, love your trail 4R.
Old 08-11-2019, 07:58 AM #14
chetJ's Avatar
chetJ's Avatar
Regular detailing
There was a time when I used to wax it twice a year. That became hard with little kids. Nowadays, I get it professionally detailed once a year and the treatment seems to last for the whole year. The detailer uses high quality products. I then wash it regularly by hand.
Old 08-11-2019, 08:01 AM #15
chetJ's Avatar
chetJ's Avatar
Totally agree
Agree! Have wanted to add mods, but time, money, and other priorities have gotten in the way constantly. At the very very least, I want to get rid of those running boards!!! With the kids- I dont see that happening though.
limited , miles , post , strong , t4r
19 years and 364,000 miles... StreetCreeper 3rd gen T4Rs 5 01-29-2015 01:14 AM
14 years old and 90K miles what do I need to do? Former_Jeeper 3rd gen T4Rs 8 12-21-2013 07:53 PM
2005 Limited 191,000 miles still going strong David Jeffers 5th gen T4Rs 1 02-04-2013 01:29 PM
27 years, 311,000 miles later.....85 T4R 93toy Gallery 4 05-18-2012 03:30 PM
