View Poll Results: Which Tire ?
Michelin Defender P Rated 255/75 3 33.33%
3 33.33%
BFG K02 C rated 255/75 4 44.44%
4 44.44%
BFG K02 265/70 Stock 2 22.22%
2 22.22%
Voters: 9. You may not vote on this poll
Old 08-10-2019, 08:53 PM #1
JPK_NJ JPK_NJ is offline
JPK_NJ is on a distinguished road
Which BFG/Michelin Tire ? 255/75/17 or Stock 265/17
Warranty credit so I can only pick from BFG/Michelin offerings. Running 7" TRDP Sema's on a 19 ORP Barcelona KDSS. NJ 95% road miles. Currently on 255/17 K02 C rated that keep balance on 7.5" trail rims.
Try again with K02 255/75s and hope for a better batch and fit with the 7" TRD Rim?
Go grandpa style with Defender M/S highway tire but in 255/75 ? (risky since I can't seem to find any pics of that actual tire )
Really liking the 32" height of 255/75 but might be open to stock size if it means less problems with my KDSS that was just repaired.
JPK_NJ is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 09:50 PM #2
Forgot to add the biggest pro I see on paper... Defenders are 38lbs vs 46lbs for K02. So 8lbs x4, 32lbs rotating mass. Not chump change when it comes to the turtle V6 4Runner engine
Which BFG/Michelin Tire ? 255/75/17 or Stock 265/17-screen-shot-2019-08-10-5-32-03-pm-png  Which BFG/Michelin Tire ? 255/75/17 or Stock 265/17-screen-shot-2019-08-10-5-24-22-pm-png
Old 08-10-2019, 10:23 PM #3
TNRunner99's Avatar
TNRunner99 TNRunner99 is offline
TNRunner99 is on a distinguished road
TNRunner99's Avatar
KO2s look so good on 4 Runners. I prefer Coopers but if those are your only choices go with the stock size.
1999 4Runner SR5 4x4 Desert Dune
Lift- 3" Toytec/Bilstein-front, LC Coils/LC Tokico Blacks-rear
285 Maxxis Bighorns on 16" ATX Mojaves
ARB-front, CBI plate w swingout-rear
1997 LX450 Black OME 2.5" 315 ST Maxx 2016 4Runner 4x4
TNRunner99 is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 12:52 PM #4
Agreed on K02 being the best looker. But given my redo chance, Im trying to be logical and see if its still the way to go for my given function / NE weather. Here are the 255/75/17's that Im warrantying due to balance issues. I like the somewhat skinny/tall look in all but the rear mudflap comparison. This will also shift over another .5" towards fender when I mount the TRDP Rims. What says the forum???
Which BFG/Michelin Tire ? 255/75/17 or Stock 265/17-image1-30-jpg  Which BFG/Michelin Tire ? 255/75/17 or Stock 265/17-image2-11-jpg  Which BFG/Michelin Tire ? 255/75/17 or Stock 265/17-image3-3-jpg
Old 08-11-2019, 02:49 PM #5
johnbt's Avatar
johnbt johnbt is offline
johnbt will become famous soon enough johnbt will become famous soon enough
johnbt's Avatar
The stock size Defenders have a wider Section Width and wider Tread Width than the skinny ones you're looking at.
Why would you want to put less rubber on the road when you're spending 95% of your time on the pavement? The tires are what keeps you on the pavement.
Grandpa says, come on out in the sand and the mud and have some fun sonny boy. The stock size Defender M/S get the job done easily and are good highway tires too.
2023 TRD ORP w/KDSS. Red again.
This is a big step up from the 1986 Subaru GL wagon I used on the Outer Banks beaches for 14 years. That thing would go anywhere in the sand on 185/70-13 tires. Dual range 5 speed, factory skid plate, 3 position manually adjustable rear shocks and armored exhaust. All factory, including the white spoke wheels. The front sub frame finally rusted apart.
johnbt is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 05:40 PM #6
The only thing that’s steering me away from the MS Michelin is our aspect ratio in stock size 70 or even 75. That’s a lot of sidewall height and I’m fearing the Michelin will just look like a goofy smooth round donut in our 4Runner size. Maybe their AT2 tire might look somewhat better and be a good compromise.
I was only putting less rubber width down in order to gain 32” height on stock suspension. Hence the 255/75 skinnies. Given my recent KDSS repairs, maybe I should just go stock size so they can’t potential screw me if something pops up again.
Also, the measuring rim width on most of these tires is 8”, so mounting on a 7” rim will cause that sidewall / section width to bulge even more. Heard to expect .2” for every .5” in rim difference
255/75 , bfg/michelin , k02 , kdss , tire
NEW TIRE: Michelin LTX M/S-2 Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 86 06-03-2020 08:03 PM
crack on michelin tire tcpoob 4th Gen T4Rs 9 03-27-2013 07:20 PM
Stock Tires or used Michelin LTX M/S's? brownc72 5th gen T4Rs 3 02-23-2012 02:26 AM
Swap Stock for Michelin LTX MS2? chatham 5th gen T4Rs 4 12-05-2010 07:51 PM
Michelin tire availability lockerc18 4th Gen T4Rs 16 12-22-2007 09:39 PM
