Old 08-10-2019, 11:45 PM #1
doxiedad's Avatar
doxiedad doxiedad is offline
Real Name: James
doxiedad is on a distinguished road
doxiedad's Avatar
Real Name: James
When to change front diff oil?
So I changed front/rear/t-case oil on my 2016 4Runner @ 20K miles. She's at 60K miles now. I changed out the rear diff fluid today, Using Mobil 1 Synthetic 75W90 Gear oil again.
Do I need to change the front out as well? I don't get to use 4X4 nearly as much as I'd like.
thanks
2016 SR5 Premium 4x4 Nautical Blue
doxiedad is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 05:10 AM #2
pahaf91 pahaf91 is offline
pahaf91 is on a distinguished road
I would. Its only $12.99 a quart where i am at. I would do Front and Center diff together. Cost is $39 plus tax. Why not have the extra protection?
pahaf91 is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 11:55 AM #3
pointman pointman is offline
Banned
pointman will become famous soon enough pointman will become famous soon enough
Banned
Simple DIY? Simple as a flush and fill?
pointman is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 11:56 AM #4
doxiedad's Avatar
Real Name: James
doxiedad's Avatar
Real Name: James
Yeah pretty simple. I've done it before. Problem is it's August in the South east so hot and humid as hell for a couple more weeks.
May wait till a little cooler weather.
Old 08-11-2019, 11:57 AM #5
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a jewel in the rough 1000MPH is a jewel in the rough 1000MPH is a jewel in the rough 1000MPH is a jewel in the rough
1000MPH's Avatar
Nope. I changed my front diff and T/C at 48k then at 94k. Should be easily able to do 60k intervals if you don’t do water crossings. Up to you.
2010 Trail - 114k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Michelin Defender LXT M/S 36psi - Oil: M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - ScanGauge - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
1000MPH is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 02:42 PM #6
Yes it is. For the center diff, it's a 24mm plug for drain and fill.
Front diff is a hex key. And you have to remove the front skid plates to get to them. The only issue.
The front and center diff both take about 1.5 quarts.
Old 08-11-2019, 08:20 PM #7
Banned
Banned
Perfect detail. Thank you!
Old 08-12-2019, 08:16 AM #8
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
I get lazier on the front diff than on the T case and the rear. The rear gets nasty by 30K, the T case, well, that's so easy why not do it when doing the rear. The front though, it always comes out perfectly clean so I go a little longer. Same for the wifes ride.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 10:32 AM #9
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
I changed my diffs and TC at around 60k. Rear diff and T-case were dark. The front diff was pretty clean though. I'll probably end up changing all again at around 100k.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 11:52 AM #10
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I agree with this, I like doing my own maintenance. However, on a selectable driveline, you don't need to change the front now. You're in a good spot to drive 30,000 miles, then do both.
2015 4runner Limited
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 04:27 PM #11
Shingo Shingo is offline
Shingo is on a distinguished road
Had a little whine in the rear diff in my 2018 SR5.
Changed lube at 15k miles using Valvoline synthetic 75w-90 (highest MIL Specs). Really surprised there was almost 1/8" of babbit on magnetic drain plug. Rear end pretty quiet now,.. will do front & transfer case at 30k miles as an insurance policy. Transmission @ 50k miles and will add aftermarket cooler (or earlier if I start to tow).
Good luck!!
Shingo is offline   Reply With QuoteReply With Quote
change , diff , front , miles , oil
Front and Rear Diff fluid change Mijfwb23 5th gen T4Rs 563 03-30-2021 09:42 PM
Which fluids for transfer case, front/rear diff change? hawkcharmer 3rd gen T4Rs 23 02-07-2021 02:40 PM
Change front diff to match the rear gearing Angry_4runner 3rd gen T4Rs 5 02-10-2019 05:40 PM
Front diff gear ratio verification - diff removed and no vehicle info SDmtnbkr 3rd gen T4Rs 6 07-26-2017 09:39 PM
front and rear diff fluid change Tombguardgirl 3rd gen T4Rs 7 06-10-2014 02:51 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
