Old 09-29-2013, 05:25 PM #1
esto70 esto70 is offline
esto70 is on a distinguished road
Help moving USB from center stack to glove box
So, I recently traded my '11 LE for a '13 LE. Yep, I'm "that guy." As you know, the '13s have the USB port in the center stack, and I'm wishing it was still in the glove box. I started to dig (just a little) into the glove box and center stack area today...to see what might be involved in moving the USB connector into the glove box. Before you flame me, yes I've searched. I think I've read every thread on adding switches and removing the center stack and stock radio. I more of less know how the center stack comes apart.
In a nutshell, here's what I'd like to do: I want to switch the USB/aux plug in the center stack with the blank switch cover (USB plug on older models) in my glove box. Possible? No?
I guess what I need help with is how the current USB plug attaches to the back of the center stack below the heat controls. Will the USB/aux plug just pop out once I get everything torn apart? I'm sure in can buy the USB/aux plug and the blank cover (might want an extra) but where the heck is is listed in the oem parts catalog? Any thoughts on how to extend the USB/aux over to the glove box?
Any help or pics would be appreciated! Thanks!
esto70 is offline   Reply With QuoteReply With Quote
Old 10-08-2013, 08:44 PM #2
mikey2times mikey2times is offline
mikey2times is on a distinguished road
I want to do the same thing. I'd also like it so I could have BOTH. One in the glove box for my iPod and one in the centerstack so I can charge my phone.
2013 SR5, 2WD, Magnetic Gray Metallic, NAV, Cloth, Sunroof
mikey2times is offline   Reply With QuoteReply With Quote
Old 10-09-2013, 05:31 PM #3
hamburglar210 hamburglar210 is offline
hamburglar210 is on a distinguished road
I've noticed that mine won't charge my phone if the battery is too low... so I keep a cig charger in there.
2013 Trail - has never been in the rain
hamburglar210 is offline   Reply With QuoteReply With Quote
Old 10-10-2013, 06:17 PM #4
derekp's Avatar
derekp derekp is offline
derekp is on a distinguished road
derekp's Avatar
Have you made any progress here? I'm not sure if you could pull the port behind the dash and place a splitter there to route one to the glove box (or the console) and route one back to the original position. A few websites to check for parts would be microcenter and partsexpress.
13 4Runner, SR5, Bright Silver, Leather, Moonroof, 3rd Row, Tint, Weathertech, Goodyear Duratracs*
Prev: 01 Taco X-Cab 4x4 V6 TRD (Silver), 05 Dodge Quadcab Hemi 4x4 (Mineral Gray), 00 Taco X-Cab 4x4 V6 TRD (White)
Texarkana--Dayton--Izmir--Cabot--Some Place Sandy--Germantown--Grand Forks--GTMO--So. MO
derekp is offline   Reply With QuoteReply With Quote
Old 10-10-2013, 09:41 PM #5
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
How about this...
3ft USB 2.0 Panel-Mount Type A Male to Type A Female Cable for only $1.83 | Cables
nglayton is offline   Reply With QuoteReply With Quote
Old 10-10-2013, 09:55 PM #6
Done!
Sorry for the slow reply to those of you that asked. I finished the project last weekend, and it turned out MUCH better than I expected. I have never done anything like this before, so my pucker-factor was sky high. I was literally sleepless the night before thinking about tearing into new brand new 40k truck.
I uploaded and attached some pics:
Pic 1:
I started by opening the glove box to see how easy it was to remove the plug where the USB/AUX port was "supposed" to be. The plug came right out. I was worried that I might have to remove the glove box, but it's not necessary.
Pic 2:
I took the center console apart to have a look at the wires. This is surprisingly easy. I thought that I could maybe just re-route the USB/AUX wire harness up to the glove box, but I don't think it's possible. It's too short and secured in a bunch of places behind the dash. The wires have to be cut re-wired.
Pic 3:
I cut the USB/AUX connector off. The USB part has 4 wires (red, white, purple, brown). The AUX part has 5 wires (3 different blacks, white, red). I had to mark all of the wires and go to radio shack to get wire, shrink tube, a soldering tools. I marked, cut, spliced, and soldered all of the wires. I basically made wire a wire harness extension and routed that through the glove box hole and behind the dash into the center stack. That was spliced and soldered to the existing wires.
Pic 4:
Here's the USB/AUX plug dangling out of the hole in the glove box right before I tested it.
Pic 5:
Everything works fine! I really can't believe the I didn't royally eff something up, but so far so good! And no, I did not leave that stubby little USB cable in there.
Overall, this project is quite do-able. Like I said, I was REALLY apprehensive about it, and it turned out fine. My ipod is safely out of sight and out of mind in the glove box!
Old 01-24-2014, 10:32 PM #7
Mikes-13's Avatar
Mikes-13 Mikes-13 is offline
Mikes-13 is on a distinguished road
Mikes-13's Avatar
This is a planned project for me too. Did you consider finding a male and female harness connector and just make an extension cable?
Is it still working good?
2002 SR5 Sport
2016 Jeep GC Summit
2011 Harley Fat Bob
Android
Mikes-13 is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 04:09 AM #8
fraggy fraggy is offline
fraggy is on a distinguished road
Hi:
I traded my 11 for a 13LE as well, and would preferred the USB port in the glove box. Did you leave the USB port in the dash but non functional.
fraggy is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 08:21 AM #9
Still working fine
The USB port is still working perfectly. I haven't touched my iPod in months, and it plays fine with good sound. In fact, I just brought it back inside for the 1st time a few days ago to update iTunes.
Honestly, I never thought about a harness to bridge the distance from the center console to the glove box. A plug-n-play solution would have been fantastic. Please post up if you find something that works.
Old 01-25-2014, 11:07 AM #10
Gabex35's Avatar
Gabex35 Gabex35 is offline
Gabex35 is on a distinguished road
Gabex35's Avatar
Subd. Great idea
Gabex35 is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 03:31 PM #11
noncontributingzer noncontributingzer is offline
noncontributingzer is on a distinguished road
Did you consider putting a USB hub inside the dash where the original plug was, and then ruining a USB cable extension to the globe box? That way, there is no cutting or soldering involved, and you can retain usage of both ports. The OM says that you can use two drives simultaneously this way.
noncontributingzer is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 04:56 PM #12
Go JayBee's Avatar
Go JayBee Go JayBee is offline
Real Name: Joe Bloomstone
Go JayBee is on a distinguished road
Go JayBee's Avatar
Just an idea. I mess with computers at work...I'm that "IT Guy". The Front USB ports on most boxes, connect to the MotherBoard with a multi-pin header. I'm wondering if that would connect to the existing wiring???
Nice job of figuring out the wiring though, @esto70
I have the Glove Box USB in my 2012 TE and like it there. I did find a USB hub/cable w/ one male and 4 female connectors which allows more than one item to be connected. i.e. i-Pod for music, and cable for charging i-Phone. Think it was around $5 from China. Nice to have for other stuff as well...want to expand your LapTop for example.
2012 Trail Edition, Magnetic Grey, NAV, EnTunes, KDSS, Factory Running Boards, Stainless Exhaust Tip, HuskyLiner Weather Beaters, CravenSpeed Stubby, Toyota Emblem Black-Out, Ifinity Kappas throughout, LED Upgrade for Interior, LED Exterior: Tail/Brake, Reverse, Rear Turn, Front Turn/DRL, & Front Parking. Built-In Compressor (AntMan Style), Painless Fuse-Box, Cup Holders (AntMan Style), LED Under Hood Lights, NAV Override, Hella Horns x 4!!!
I've been a T4R owner since 1997....
Go JayBee is offline   Reply With QuoteReply With Quote
Old 01-25-2014, 05:41 PM #13
Bimmer-Bob's Avatar
Bimmer-Bob Bimmer-Bob is offline
Bimmer-Bob is on a distinguished road
Bimmer-Bob's Avatar
Wow, I had no idea that the USB hub used to be in the glove box (I have a '14 SR5). One of the first things I wondered was why Toyota located the damn thing on the center stack. So dumb IMO, even more so since they apparently got it right the first time. I guess they maybe moved it so folks could charge their phones easier, but you can always use one of the 12V sockets for that. Actually, I think the ideal place for the USB port would've been the center console. Oh well.
Anyway, to the OP, I'm wondering if you have an "after" pic of the center stack? Or did you just leave the stock cover over the USB port? I don't so much mind seeing the port there, it's just that using it becomes problematic since you can't stow an iPod out of sight.
Bimmer-Bob is offline   Reply With QuoteReply With Quote
Old 01-26-2014, 10:15 AM #14
Bimmer-bob,
Sorry, I don't have an after pic of the center stack. When I moved the usb/aux port to the glove box, I plugged the hole in the center stack with the original blank from the glove box. Easy, cheap, and it retains the stock look.
Like you, I was unhappy with having my iPod in plain sight sitting in the cubby in the center stack. I tried all sorts of tricks to make that work. I even bough a right angle usb adapter so that I could stuff my iPod in the cubby behind the cover, but it wouldn't close all the way. That bothered me (yay, OCD!) so I knew I had to move the usb to the glove box.
Old 06-01-2015, 12:45 AM #15
Trails4 Trails4 is offline
Trails4 is on a distinguished road
Very Easy to Move USB in '15 TPE
As an update to this thread for anyone looking for info on the '15s:
I completed the center stack to glovebox swap in my '15 TPE today. Took all of 20 minutes, and mostly due to removal of the console.
It was hard to find a clear writeup on trim removal from the center stack, so I'll touch on that here.
To remove the trim from the A/C and lower center stack, start on the passenger side. Remove the side trim piece that fits around the temp knob and passenger airbag light by pulling gently from left to right on the inside (better purchase with fingers, no tool needed.) This should pop out fairly easily. Next, the driver's side piece actually houses the A/C knobs themselves and is shaped like an upside down 'L' (this is what got me for a while as I didn't want to break anything...) You can start removing it by pulling the trim/baseplate behind the temp knob and work your way across the top of the panel to the airflow knob. The whole piece will pop out and will be connected to 1 harness clip behind - just remove the clip and the piece is free.
Next remove the center console: unscrew the shift knob and the transfer case knob by hand, I found the transfer case knob to be fairly stuck on there. Then, start on the passenger cupholder side and just pull gently outward and upward on the center console trim, this should pop up fairly easily too. On the TPE and I'm assuming the SR5P, the seat heater harness is on the outside of the passenger cupholder. Disconnect this so you can remove the whole trim piece easily.
Next, remove the small strip of trim below the center stack storage slots. Then unscrew the 2 phillips screws holding the storage slots/USB/12V socket. This piece will then pop out from top to bottom, and just requires an extra tug to get the bottom free. Remove the USB harness and the 12V harness.
From there, I removed the tape holding the USB wire onto the back of the mounting plate. I found it only needs to be removed up to the right hand corner where the wire turns up toward the head unit. From this point, it's just a matter of opening the glove box, popping the switch cover out, and opening the access point on the left interior of the box. You can easily fish the USB wire around and through the now open switch hole. Plug the harness back into the USB/AUX outlet and pop it into place.
Reverse all the steps to get things buttoned back up and you're done. The process was so quick I didn't think to take photos at the time - esto70 has it well covered though.
Trails4 is offline   Reply With QuoteReply With Quote
Removing center glove/storage compartment toiday 4th Gen T4Rs 5 06-10-2013 12:50 PM
Center Stack Stack Clips batmant 3rd gen T4Rs 2 01-18-2013 11:35 PM
Airbag Light in Center Stack Fleethammer 4th Gen T4Rs 4 11-01-2012 07:27 PM
WTB: 4th Gen - interior dash center stack storage box/bin/door bstaneland Want to Buy/Trade 3 04-26-2011 02:14 PM
How does Toyota stack up? Dbone 5th gen T4Rs 10 01-09-2010 10:09 PM
