Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 08-11-2019, 12:06 AM #1
NC[4]Runner's Avatar
NC[4]Runner NC[4]Runner is offline
Member
NC[4]Runner is on a distinguished road
Member
KDSS - Is there an Aftermarket Repair Option
Hi, I did a little research on this as...you guessed it.... That knocking sound in the front end. Shifts side to side over bumps. 5.5 years old, under 55,000 miles. 5th Gen 2014 Trail 4x4.
Toyota: Cylinder needs to be replaced... diagnostics $300.00... Repair bill just under $3000. I read that even Toyota dealers having to special order a tool to work on it, so... yeah.. feeling a little kicked in the face.
There has not been much chatter on the subject on t4r lately, so I'll ask it...
Does anyone know of an aftermarket replacement ... upgrade ? to the massive repair bill proposed by Toyota ? For the sakes of the thread, I am not looking at ripping it out and putting a sway bar in.
Thanks in advance
__________________
2014 Trail Premium, RevTec, Black Rino Wheels with 33" Dick Cepek Fun Countrys, Gobi Rack, Raingler Net, WeatherTech, C4Fab LoPro (FINALLY installed) with Warn 10S Winch, C4Fab Rock Sliders, WaterPORT Day Tank, Switch Pro (to install) [user name change from WWBRT-4Runner]
NC[4]Runner is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 12:16 AM #2
wcjeep's Avatar
wcjeep wcjeep is offline
Member
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
Member
wcjeep's Avatar
There was someone recently with a 5th gen kdss that under warranty Toyota changed quite a bit of parts when the rubber bushing was bad. Dealer refused to take the easy way.
__________________
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 09:05 AM #3
nb rob's Avatar
nb rob nb rob is offline
Senior Member
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
Senior Member
nb rob's Avatar
well, all the GX's have KDSS, so the special service tool (SST) is present at a lexus shop. Whether or not they would help you out is a different story.
The KDSS does move around all over the place. Check out this great video from a forum member (check out around 2:56):
YouTube
What about the front piston is knocking? Is it the connection to the frame at the top, or the connection to the swaybar? Have you replaced the swaybar bushings and the KDSS bushings? They are all very cheap and easy to replace on the ground, in the driveway
Is the cylinder (front or rear?) leaking?
__________________
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 02:12 PM #4
MrGainzz's Avatar
MrGainzz MrGainzz is offline
Member
MrGainzz will become famous soon enough MrGainzz will become famous soon enough
Member
MrGainzz's Avatar
Get rid of it to make it a trd pro.
MrGainzz is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 02:31 PM #5
jrandom's Avatar
jrandom jrandom is offline
Senior Member
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
Senior Member
jrandom's Avatar
Replace your bushings first, they're cheap. $15 each and the job is relatively easy DIY, or if you trust them, have those folks do it for you.
I find it hard to believe the piston went out, not that it couldn't happen, it seems much more likely that one of the solenoids in the valve body would fail before a piston.
Pistons are dead simple tech, if anything you should be able to pull it and rebuild it yourself, or have a motorcycle/shock shop do it for under $100.
Last someone looked into it the KDSS SST is roughly ~$550. It is basically used to depressurize, pressurize and bleed the system.
__________________
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 05:43 PM #6
cb1111's Avatar
cb1111 cb1111 is offline
Member
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
Member
cb1111's Avatar
That failure seems a bit early. I'd contact Toyota customer service (preferably by mail if you have the time), explain that although you realize that you are out of warranty, you believe that this is a manufacturers defect as the failure occurred so early and you ask for a goodwill repair.
Perhaps the dealer will support you.
There are three outcomes:
Toyota pays for the repair
Toyota pays for part of the repair
Toyota tells you to take a flying leap
All it costs is the postage for a registered letter. Worst case is that you get pissed off because they turn you down.
I've done this a couple of times with mixed results. One time the manufacturer paid the whole thing, the other time they split the bill and paid the parts - in that case it was over half.
It does help if the dealer believes that it is an unusual failure.
__________________
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 07:46 PM #7
Jetboy's Avatar
Jetboy Jetboy is offline
Elite Member
Jetboy has a reputation beyond repute Jetboy has a reputation beyond repute Jetboy has a reputation beyond repute Jetboy has a reputation beyond repute Jetboy has a reputation beyond repute Jetboy has a reputation beyond repute Jetboy has a reputation beyond repute Jetboy has a reputation beyond repute Jetboy has a reputation beyond repute Jetboy has a reputation beyond repute Jetboy has a reputation beyond repute
Elite Member
Jetboy's Avatar
I put together a list for a suggested kit to bleed and pressurize the system from off the shelf parts for about $300 or so IIRC. I'll see if I can find it. There's thousands of GX and Kdss 4runners in salvage yards so a cylinder shouldn't be terribly hard to find. I don't know what fluid it uses.
Edit: https://www.amazon.com/dp/B00460UDK2...2&linkCode=asn
This plus a correct fitting (not sure what style is used) plus the proper fluid would get you there. Iirc bleed like brakes then pressurize to 500psi. Double check the FSM on pressure. My guess is that it uses something like 5 weight shock oil, but again I'd see what the Toyota manual requires. Part number is 08886-01805. It's only $35 ish for 2.5l of the OEM fluid so I'd use that.
Ultimately I think $250 plus the replacement parts would get you back in action.
Jetboy is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 11:03 AM #8
20164runner's Avatar
20164runner 20164runner is offline
Member
20164runner will become famous soon enough
Member
You're a bad ass.
20164runner is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 02:35 PM #9
Member
Member
Sorry for the time delay in replying to everyone's contribution, its very much appreciated and good for the community.
My local Toyota has the SST already and has done the repair too.
I've had no leaking of any kind (front/rear). No bushings replaced. Its really hard to pinpoint the origin of the knocking. Two capable buddies and I got up on the sliders and rocked the rig side to side to repeat the knocking. We concluded that taking it to Toyota needed to happen.
The failure does seem early to me as well, miles-wise and considering that I do not beat the s**t out of it. I wheel, but i'm not bajaing the thing. Regardless, it's too soon.
My Toyota adviser contacted Toyota Corporate on my behalf. I [try to] speak to the same person over there when I bring th Runner in and he's went to bat for me on several occasions. After about a week he heard from them and they took $1000.00 off of the repair. Not sure that more would come of it if I did contact them direct. Do you think I should pursue it further ? or take it and run ?
.....This plus a correct fitting (not sure what style is used) plus the proper fluid would get you there. Iirc bleed like brakes then pressurize to 500psi. Double check the FSM on pressure. My guess is that it uses something like 5 weight shock oil, but again I'd see what the Toyota manual requires. Part number is 08886-01805. It's only $35 ish for 2.5l of the OEM fluid so I'd use that.
Thank you for this. The capable person would find this info extremely helpful. Unfortunately the time-cost, for me, does not work out. I'd spend way more of my time getting it all figured out than would make since. Someone will do this and its great information for the community. I hope someone does and posts up.
The dealer said in their repair write-up that they disconnected something, did a test drive and the knocking went away.... I'll post that specific wording tomorrow as I left the paperwork at my office.....
Thanks again everyone....
__________________
Old 02-11-2024, 10:19 PM #10
dom42 dom42 is offline
Member
dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light
Member
I’m cooking up an aftermarket version that’s full rebuildable , will come with 1-2 rebuild kits and is less likely to fail. Testing in the next 1-2 months.
dom42 is offline   Reply With QuoteReply With Quote
Old 02-12-2024, 04:43 PM #11
Okusputokus's Avatar
Okusputokus Okusputokus is offline
Member
Okusputokus will become famous soon enough
Member
Thanks so much for developing this, Dom! If you need a testor I'm happy to help. Also, please make sure the front bleeder valves are easy to get to ;)
Quote:
__________________
2014 T4R Trail👉*LOTS of MODS
Okusputokus is offline   Reply With QuoteReply With Quote
Reply
Tags
aftermarket , bill , repair , side , toyota
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
CV boot repair - which option is right for me? ShooterMcGavin 3rd gen T4Rs 21 03-25-2021 03:22 PM
Best single KDSS-compatible suspension option for slight lift, soft ride 1996_Valencia_Owen 5th gen T4Rs 52 09-09-2018 01:05 PM
KDSS Repair Dealer? Marcocopuffs So Cal 4 06-01-2016 04:57 AM
Kdss trail option question ejT4Rm 5th gen T4Rs 1 05-28-2012 07:52 AM
Best stock HU option for aftermarket nav and amp/speakers? malmgren Engines / Suspension / Wheels / Tires / Audio / Accessories 6 08-10-2007 10:30 AM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
