Old 08-12-2019, 02:57 PM #1
gibburnz's Avatar
gibburnz gibburnz is offline
Real Name: Ryan
gibburnz has a spectacular aura about gibburnz has a spectacular aura about
gibburnz's Avatar
Real Name: Ryan
Side Mirrors (14+)
Hey guys--
I have 14+ aftermarket side mirrors on my 2011 TE. They are powered for mirror control, but they don't have the signals built into them.
Then, I found on Car Trim Home that they're making sequential replacement lights for those with the signals built into the mirrors. I dig the look and would like to pick them up, but my assumption is that I'd need the harness that runs through the door panel into the signal controls.
Any suggestions on how to achieve that or what harness I need to be looking for?
2011 Trail Edition. Black. '17 RRW RRH-6's. w/285 KO2's. Rago molle panels. C4 Fabrication lo pro with 25" Xtreme LED, Smittybilt X20 winch and Agency 6 fairlead/shackle. RRW V3 rock sliders. TRD front skid. Spidertrax spacers. Gobi Stealth rack and ladder. ARB Safari snorkel. AnzoUSA 14+ tails. Blacked out projector/retro-fit head lights. Baja Designs pro fogs, S2 ditches and rear dust lights. Eibach 2.5" lift w/ ICON delta joint UCA's. C4 dual-swing rear bumper.
Check out Trail4Runner.com for more Installs and Write-Ups. Find my author link here.
gibburnz is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 03:10 PM #2
r1verf3nix r1verf3nix is offline
r1verf3nix will become famous soon enough
Originally Posted by gibburnz View Post
Hey guys--
We've all been patiently waiting on the harness to be released from @Old Red . You can read up where we are currently on this issue in the following threads.
Side mirrors with turn signals
TRD Pro Side Mirror Swap/Upgrade
r1verf3nix is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 03:21 PM #3
gibburnz's Avatar
Real Name: Ryan
gibburnz's Avatar
Real Name: Ryan
Damn dude, what a coincidence and shame on me for not searching the forum beforehand. Thanks - I'll subscribe to the other thread!
Old 08-12-2019, 03:21 PM #4
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
You also could just tap the turn signals
YouTube
Old 08-12-2019, 03:46 PM #5
YouTube
And I don't disagree but with Oldred's harness you get the connector that cannot be purchased that matches the OEM TRD PRO mirror 5-pin. Then he has done all the research as to where the (4)four wires land to serve the walk up puddle lights and turn signals within the door.
If you know where to land the puddle lamps power wire, I could probably come up with a writeup myself.
Old 08-12-2019, 05:32 PM #6
Phil Frames Phil Frames is offline
Phil Frames is on a distinguished road
You can find power and ground locations for puddle lamps here: http://toyotaparts.sparkstoyota.com/...17-4runner.pdf
Phil Frames is offline   Reply With QuoteReply With Quote
Old 08-12-2019, 06:09 PM #7
Old Red Old Red is offline
Real Name: I no longer post or contribute to site that doesn't value members or their contributions.
Old Red is just really nice Old Red is just really nice Old Red is just really nice Old Red is just really nice Old Red is just really nice
YouTube
Yes, if you are looking for the grounding points, etc. the OEM wiring diagrams will give it to you. The only reason to go with the harness I am making is if you want a plug and play solution without having to mess with the factory harness. So it can be DIY, or you can go with a harness set when they are released after Labor Day. Either way will get you the desired result.
Old Red is offline   Reply With QuoteReply With Quote
Old 08-13-2019, 12:26 PM #8
YouTube
So I went ahead and worked through the wiring diagrams to understand the connections as provided above. What follows is a quick and dirty connection to provide the rough signal wires and a not so clean installation. Personally I can continue to wait a few more weeks to see what @Old Red's research comes up with as running all these wires all over the dash instead of within the door doesn't sound as appealing.
  1. Puddle Lamps:
    Pin #7 and #8 of the 11-pin Premium mirror to be connected to FS1 pins #13 and #15 to provide constant +12V (FS1 pin #13) and a switched ground (FS1 pin #15) for the entry only lights.
    Wiring Diagram:
    FS1 Location:
    FS1 Connector:
  2. Turn Signal:
    Pin #10 of the 11-pin Premium mirror to be connected to F11 pins #2 and #8 (respectively) to provide Driver Side Turn Signal (F11 pin #8) and Passenger Side Turn Signal (F11 pin #2).
    Pin #11 of the 11-pin Premium mirror to be connect to the door grounding point.
    Wiring Diagram:
    F11 Location:
    F11 Connector:
Old 08-13-2019, 01:12 PM #9
Real Name: Chris
Real Name: Chris
Just to clarify, I'm a big fan of Old Red and all the things that he makes and researches for us 4Runner owners. The only reason I suggested tapping the turn signals was because OP was asking if he needed a whole different harness when he's already switched to the newer model mirrors. Just wanted to clarify that, I'm in no way trying to take away from what Tanner is doing, he's the man
Old 08-13-2019, 01:35 PM #10
I know I didn't take it as you were, and agreed he is definitely the man.
Old 08-15-2019, 11:37 AM #11
gibburnz's Avatar
Real Name: Ryan
gibburnz's Avatar
Real Name: Ryan
I'll patiently wait until after Labor Day then!!
Old 08-15-2019, 07:31 PM #12
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Hey guys--
Do you still have the Original Trail Mirrors?
nglayton is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 10:27 PM #13
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
The sequential lights look awesome
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 11:59 PM #14
Not bad, I am sure it will cost 99$ like everything aftermarket does.
Old 08-16-2019, 09:29 AM #15
Real Name: Chris
Real Name: Chris
60 bucks, I paid the same for a spare stock set when I tinted them
built , harness , mirrors , side , signals
Side mirrors Mod losso 3rd gen T4Rs 5 02-19-2019 02:49 PM
Looking for better “blind spot” mirrors for my side mirrors Rancho5 3rd gen T4Rs 18 11-29-2018 10:14 AM
Side Mirrors on SR5 4runnerlabr 4th Gen T4Rs 5 01-01-2011 11:48 AM
side mirrors BROOKLYN Classifieds - buy & sell (no commercial ads please) 0 11-30-2005 12:41 AM
