Old 09-30-2020, 01:30 AM #181
FourT6and2 FourT6and2 is offline
FourT6and2 is on a distinguished road
Originally Posted by SherpaEquipmentCo View Post
We actually have a aluminum spacer inside the rubber. So, inside our seal is no different than any other rack on the market. This what most rack companies on the market uses to keep the foot up off the roof and what most tell you to glob silicone all around to keep your roof from leaking. In our design, the rubber is not what supports your load, but what creates the seal on your roof.
The problem with over tightening the feet is the metal on the roof is thin, and when you take a big wrench with leverage, you turn that spacer into a punch, you can easily keep tightening that bolt and pushing the spacer through your roof until it bottoms out on the nut inside the roof. The rack does not need to be as tight as say your lug nuts, the hardware isn't made for it, the factory nuts in the roof are not made for it and the metal on your roof is not made for it. But, once all 4 points are snug, rubber is compressed down a bit, you have a fully sealed roof, plenty strong rack system, and hassle free no mess install.
Hoping to just shed some light on the design, and clear up any confusion on the subject. I appreciate the question as well, lets us explain our thinking and how the system works.
Thank you
So if the metal insert is what really supports the rack and load, then over-tightening the mounting bolts isn't really compressing the rubber more and more after a certain point? It's sending the metal inserts through the roof's sheet metal? Then why doesn't this happen on other rack systems? I've at least never heard of it happening. When watching mounting videos for other racks, you can see people torque down their mounting bolts (with metal standoffs) until they basically can't apply any more torque by hand and it doesn't seem to damage the roof as you explain.
I'm not arguing against what your'e saying, I just don't understand how this actually works in practice and I'd like to before making a decision on what rack to buy.
FourT6and2 is offline   Reply With QuoteReply With Quote
Old 10-01-2020, 11:21 AM #182
SherpaEquipmentCo's Avatar
SherpaEquipmentCo SherpaEquipmentCo is offline
official vendor
SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold
official vendor
Originally Posted by FourT6and2 View Post
Thank you
To push it through the roof requires a good bit of force, you'll absolutely know that you are doing it. The one time we have seen it happen the customer was installing their rack with an impact wrench. So, they had no idea of torque and just assumed the impact would stop itself once tight. It is not something you should have to worry about when installing the rack, just good to be aware of, especially if you use air wrenches or electric wrenches. It could happen when any other rack that uses a round spacer but definitely a rare occurrence caused by lack of attention.
Industry Leading Modular Storage Systems that allow you to Adventure with Confidence.
Our WebsiteOur InstagramOur Facebook
SherpaEquipmentCo is offline   Reply With QuoteReply With Quote
Old 10-01-2020, 11:46 AM #183
Muff Muff's Avatar
Muff Muff Muff Muff is offline
Muff Muff will become famous soon enough
Muff Muff's Avatar
A question not about installs for once... @SherpaEquipmentCo
Would y'all ever consider partnering with Affirm to offer financing on your products? I've personally been really satisfied with their service from the buyer's end, but I'm not sure what it looks like from the seller's end. If it makes business sense for you to offer it, I think it would allow many more people to buy your products because they can spread out the cost over several payments with little to no interest who otherwise couldn't afford to drop ~$1,000 all at once.
Muff Muff is offline   Reply With QuoteReply With Quote
Old 10-01-2020, 11:47 AM #184
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Is there a published torque spec for these bolts?
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 10-01-2020, 12:41 PM #185
official vendor
official vendor
Yes there is, we have it on the install instructions found on the product page.
Old 10-01-2020, 01:37 PM #186
That's great. Should address any issues or concerns. Tighten to spec, enjoy the rest of your life. Check semi-annually.
Gone
Old 10-01-2020, 03:14 PM #187
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
If someone can point me at a torque wrench that measures inch-pounds accurately, I'll buy you a beer sometime. The only one I could find at the local auto parts store was accurate +-100% from my testing ...
rageandlove is offline   Reply With QuoteReply With Quote
Old 10-01-2020, 04:04 PM #188
NotaTRD's Avatar
NotaTRD NotaTRD is offline
NotaTRD will become famous soon enough NotaTRD will become famous soon enough
NotaTRD's Avatar
Borka Tools makes an in-lbs torque driver. I mainly use it for torquing down scope ring caps, but it will work for getting the 22 in-lbs the rack calls for. It’s a bit pricey, but it’s an option.
2017 SW SR5
NotaTRD is offline   Reply With QuoteReply With Quote
Old 10-01-2020, 04:05 PM #189
official vendor
official vendor
Capri Tools makes an awesome inch pound torque wrench but it is on the pricey end of them. If you find yourself needing one often I would recommend it. To reiterate, snug is plenty good on these bolts, a torque wrench is nice but not a necessity for the install.
Capri Tools 31200 20-150 Inch Pound Industrial Torque Wrench, 1/4" Drive, Matte Chrome - - Amazon.com
Old 10-02-2020, 01:26 AM #190
I use an awesome in-lb torque driver from Wiha for my rifles. It's accurate to +/- 6%. Wiha Adjustable Screwdriver Torque wrenches
Also, 22 in-lbs seems suuuuper light for something like a roof rack, but that's just me I guess lol
Old 10-02-2020, 09:58 AM #191
We use them in the shop to assemble various rifle components. Haven’t had any parts fall off yet so they must be good
Gone
Old 10-07-2020, 12:59 PM #192
cripes's Avatar
cripes cripes is offline
cripes is on a distinguished road
cripes's Avatar
Just ordered a crestone today. Can't wait.
cripes is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 01:43 PM #193
sl0wd0wn sl0wd0wn is offline
sl0wd0wn is on a distinguished road
I'm on the other side of 8 weeks for my order. It seems like the combination of COVID-19 and the increased demand for camping, etc. has really slowed things down.
sl0wd0wn is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 02:28 PM #194
NotaTRD's Avatar
NotaTRD's Avatar
Thanks for the heads up.
Coming up on 4 weeks of the 8 week lead time for mine. Hoping it’s not too much more than 8.
2017 SW SR5
Old 10-08-2020, 04:19 PM #195
JoshDub JoshDub is offline
JoshDub is on a distinguished road
I'm on week 6. Looks like I'll be another week or so before it ships.
JoshDub is offline   Reply With QuoteReply With Quote
equipment , mounting , rack , racks , roof
Sherpa Equipment Company - 4th Gen SherpaEquipmentCo 4th Gen T4Rs 68 12-02-2023 12:24 PM
Sherpa Equipment Company Rack Systems Flemster 3rd gen T4Rs 512 12-31-2022 08:26 PM
FS: Smittybilt Defender Roof Rack and Sherpa Bag (never used, $300 obo) Phoenix AZ dilip4runner1 For Sale: T4R Items 5 07-05-2020 09:01 PM
