Originally Posted by joshsonofjohn
Hi guys: I'm a fan of your designs and mounting approach and as your neighbor a few miles south would be happy to support a local business. Any chance you're planning to offer (or can make to order) a half rack similar to your Antero model (3d gen compatible) to put on a 2021 4Runner? I don't really need a full one, and prefer the look of a half-rack anyway, so if a 5th gen half rack was available, I'd be ready to order one.
Sent a message via your website as well...
We do not have any current plans for a half rack for the 5th gen, but, I won't say we will never do it as it may be something we do down the road!
Originally Posted by david05111
How many adapt plates do you need if you are going to mount four maxtrax boards?
Tempted to order a roof rack and whatever I need to mount the trax
Youll just need a single set of our Traction Board Mounts and some Maxtrax Pins all which can be bought as a set if you order your Maxtrax from us.
Originally Posted by Camping4R
Is there a diagram somewhere showing the spacing of the mount points on the base plate?
I see in the Base Plate installation video that there is a fridge slide (looks like from Dometic) mounted. I have a slide already but I can't tell from the pictures if the holes on the slide will line up with those on the base plate.
We have them setup specific to our drawers but as stated, you can simply drill new holes and install t-nuts to accommodate any spacing that your slide requires.
