Old 02-11-2020, 12:39 PM #76
SherpaEquipmentCo's Avatar
SherpaEquipmentCo SherpaEquipmentCo is offline
official vendor
SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold
official vendor
Originally Posted by 4R4Trout View Post
Looks awesome!
Thank you!
Industry Leading Modular Storage Systems that allow you to Adventure with Confidence.
Our WebsiteOur InstagramOur Facebook
SherpaEquipmentCo is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 06:55 PM #77
RoamingScott RoamingScott is offline
RoamingScott is on a distinguished road
Originally Posted by SherpaEquipmentCo View Post
Thank you!
What's lead time on the Crestones right now? Leaving for Utah 4 weeks from today and scrambling to get a rack, go me for waiting till the last second!
Secondly, would you recommend powder coated or not if i'll be taking a roof tent on and off a lot, in terms of wear and durability.
RoamingScott is offline   Reply With QuoteReply With Quote
Old 02-17-2020, 06:43 PM #78
carlodonz's Avatar
carlodonz carlodonz is offline
Real Name: Carlo
carlodonz will become famous soon enough
carlodonz's Avatar
Real Name: Carlo
The team installed a Crestone Rack on a 2020 5th Gen 4runner the other day.
The customer purchased a Crestone Rack with a half fairing to accommodate a 40” Extreme Led Lightbars Stealth Bar, a Tepui Tents Kukenam 4 person tent, and 4 extra crossbars to allow for easy mounting of different accessories.
Check out the images for a quick overview of the install, as well as the finished product!
Looks great!
A couple of questions:
  • how is the lightbar wired? Can't see any cable
  • the top of the fairing seems to cover a bit the bottom of the lightbar. Is the light output affected at all?
Thank you.
2014 4Runner Trail Super White
carlodonz is offline   Reply With QuoteReply With Quote
Old 02-17-2020, 08:42 PM #79
official vendor
official vendor
Originally Posted by carlodonz View Post
Looks great!
Thank you.
The lightbar was not wired so that the customer could do their own wiring solution. Most people either run them down the A-pillar or back to the hatch grommet. Or you could go as radical as putting in a marine grommet and dropping the wires directly into the headliner.
The fairing covers the outer lip of the light bar and when adjusted properly does not affect light output whatsoever, but does however aid in removing any sort of hood glare that could be made present from the light.
We are sitting right at 4-5 weeks right now so we could not in guarantee delivery by the departure of your trip. We recommend the powder coat, it holds up quite well. The only wear point you'll get from taking a tent on and off if you remove the crossbars the tent is mounted to is where the crossbars contact the rack on the inside. Outside of that, you won't have any wear issues.
Old 02-18-2020, 12:49 AM #80
No worries, you guys are still top of my list. How are most mounting their giant 3-4 man RTT? adding crossbars like your recent build, directly to your crossbars, etc?
Old 02-18-2020, 12:45 PM #81
official vendor
official vendor
That is the most common method yes. Makes it painless for removal and installation without having to mess with the rack much.
Old 03-06-2020, 04:09 PM #82
official vendor
official vendor
I wanted to share a recent install on a local 5th gen. @aimlessadventure_ on Instagram.
We installed a powder-coated Crestone rack with black crossbars as well as made some custom brackets for his Autohome hardshell tent. This tent was not like most hard shells and had a flush-mounted track system. It also had a very noticeable amount of fiberglass flex when bouncing around, so we whipped up some custom brackets for it. These brackets raised the tent about an 1" off the rack and also allowed it to mount to 4 crossbars as opposed to 2. Overall we are really happy with the finished install and glad we could use some ingenuity so we didn't leave Joe hanging due to his more unique style of tent. We also managed to keep everything sleek and tight to avoid any unsightly gaps between the rack and the tent that are common on a lot of the other tent brackets on the market.
His truck is just badass so enjoy these photos of it.
Old 03-08-2020, 11:04 PM #83
Aznwolf118 Aznwolf118 is offline
Aznwolf118 is on a distinguished road
Any pics of the solution or how you guys got it to mount so tight? does it rub the side rails? and will it work for other size hard-shells?
2002 - trd s/c, header, exhaust, urd 7th...armored and expo set up
http://www.toyota-4runner.org/3rd-ge...ml#post2355344
1989 - 1UZ swap Cali Bar'd --SOLD--
http://www.toyota-4runner.org/classi...xperiment.html
Aznwolf118 is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 10:22 AM #84
official vendor
official vendor
Heres the best photo I have of them, we were in a hurry to get the install finished so we did not take any photos of them prior to installing. This is just a screengrab from our Instagram story.
It does not rub the side rails.
They are basically a fancy L bracket that lifts the tent off the crossbars and allow the tent to mount to 4 bars instead of 2 being we are using 8 mounts.
We also bumped into Joe while out and about this weekend and he reported that everything is working awesome!
Old 03-09-2020, 12:53 PM #85
Brownfaux Brownfaux is offline
Brownfaux will become famous soon enough
Excellent design on the mounts. I tried to fab a similar thing when I mounted my Prinsu, but ended up with rubber washers to seal. The silicon blobs people do are insane and show they don’t understand how the roof rack seals.
You guys clearly understand. Wish I knew about this rack last October.
Brownfaux is offline   Reply With QuoteReply With Quote
Old 03-23-2020, 01:37 PM #86
official vendor
official vendor
Thank you for the kind words! We worked for a long time to design these because we hate silicone with a passion!
Old 04-07-2020, 02:34 PM #87
official vendor
official vendor
I just wanted to share a blog by one of our customers, he also did a nice write up about our rack.
Check out his website.
Overlanding with PaleoMarine – Camping with a vehicle, but not necessarily in the vehicle. But maybe sometimes.
Old 04-07-2020, 05:16 PM #88
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
Installed your Crestone rack on my 2019 last Saturday, placing the front mounts over the rubber channel guards. I had a hard time adjusting the front mounts to stretch them out and get them all tight - there's a little flex at the front end. I'm thinking part of the solution is to cut the rubber channel guards and put the front mounts directly on the body. Second observation is that the rubber guards lift rather easily off the roof - I fear that they will fly off or flap around at highway speed now that the factory rack mounts aren't holding them in place.
So a few questions:
- Any tips for getting things tight at the front?
- Should I use two-sided tape to hold the front mount down on the body?
- Should I use two-sided tape to secure the rubber channel guards in place? 30 pound tape is rather permanent, and Toyota may have left those rubber strips loose for a reason.
Old Tanker is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 12:19 PM #89
official vendor
official vendor
So a few questions:
When we tighten the front mounts during installs, we usually use either two people, or use a rag or towel to lift the front of the rack from the front corner. It also helps to loosen the rear mounts so that once you tighten them back down with the front feet set it sucks them down a little more. You can stuff a folded up towel or microfiber under the rack to lift it up. Then while its held uptight the front foot while lightly pushing the lower section into the rubber trim. This method works great for us. You could also place it on the roof where you want it and mark the bolt head locations with a pencil and set the feet up off of the truck and simply bolt the front crossbar in with them at the right tension. That is what a few customers have told us they have done. The feet do not have to be crazy tight, but when set up properly it will take quite a lot of force to get the front of the rack to budge.
I would avoid any kind of double-sided tape. The rubber channel guards should not move. We have never had an issue with those.
Old 04-08-2020, 12:52 PM #90
Very helpful. Thank you.
equipment , mounting , rack , racks , roof
Sherpa Equipment Company - 4th Gen SherpaEquipmentCo 4th Gen T4Rs 68 12-02-2023 12:24 PM
Sherpa Equipment Company Rack Systems Flemster 3rd gen T4Rs 512 12-31-2022 08:26 PM
FS: Smittybilt Defender Roof Rack and Sherpa Bag (never used, $300 obo) Phoenix AZ dilip4runner1 For Sale: T4R Items 5 07-05-2020 09:01 PM
